my second attempt with only one error, getting better
sibelius
Postby sibelius » Thu Feb 13, 2020 11:39 am
Good evening.
This is my second attempt to a dialog window at 10.36 pm; not bad.
Doesn't work but I'm confident; in the main time if someone likes to try, I post the code.
Thanks again to everyone.
Goodnight.
Here is the code.
# -*- coding: utf-8 -*-
## Form generated from reading UI file 'widget_2D_functions.ui'
## Created by: Qt User Interface Compiler version 5.14.1
## WARNING! All changes made in this file will be lost when recompiling UI file!
from PySide2.QtCore import (QCoreApplication, QMetaObject, QObject, QPoint,
    QRect, QSize, QUrl, Qt)
from PySide2.QtGui import (QBrush, QColor, QConicalGradient, QCursor, QFont,
    QFontDatabase, QIcon, QLinearGradient, QPalette, QPainter, QPixmap,
    QRadialGradient)
from PySide2.QtWidgets import *
#QUESTA RIGA O BLOCCO SOTTO LA/LO AGGIUNGO DOPO AVER DEFINITO LA FUNZIONE. LA FUNZIONE SI CHIAMA createSolidFunction
import FreeCAD, FreeCADGui, Part
import math
from FreeCAD import Base
class Ui_Dialog(object):
    def setupUi(self, Dialog):
        if Dialog.objectName():
            Dialog.setObjectName(u"Dialog")
        Dialog.resize(396, 300)
        self.insert_function = QLabel(Dialog)
        self.insert_function.setObjectName(u"insert_function")
        self.insert_function.setGeometry(QRect(20, 0, 81, 20))
        self.insert_Nb = QLabel(Dialog)
        self.insert_Nb.setObjectName(u"insert_Nb")
        self.insert_Nb.setGeometry(QRect(10, 160, 61, 16))
        self.insert_X = QLabel(Dialog)
        self.insert_X.setObjectName(u"insert_X")
        self.insert_X.setGeometry(QRect(20, 80, 47, 13))
        self.insert_EXT = QLabel(Dialog)
        self.insert_EXT.setObjectName(u"insert_EXT")
        self.insert_EXT.setGeometry(QRect(280, 140, 47, 13))
        self.insert_OFFSET = QLabel(Dialog)
        self.insert_OFFSET.setObjectName(u"insert_OFFSET")
        self.insert_OFFSET.setGeometry(QRect(10, 240, 81, 16))
        self.insert_A = QLabel(Dialog)
        self.insert_A.setObjectName(u"insert_A")
        self.insert_A.setGeometry(QRect(20, 120, 47, 13))
        self.view_Step = QLabel(Dialog)
        self.view_Step.setObjectName(u"view_Step")
        self.view_Step.setGeometry(QRect(10, 200, 61, 21))
        self.insert_XT = QLabel(Dialog)
        self.insert_XT.setObjectName(u"insert_XT")
        self.insert_XT.setGeometry(QRect(170, 20, 47, 13))
        self.insert_YT = QLabel(Dialog)
        self.insert_YT.setObjectName(u"insert_YT")
        self.insert_YT.setGeometry(QRect(170, 60, 47, 13))
        self.insert_ZX = QLabel(Dialog)
        self.insert_ZX.setObjectName(u"insert_ZX")
        self.insert_ZX.setGeometry(QRect(170, 100, 47, 13))
        self.insert_RX = QLabel(Dialog)
        self.insert_RX.setObjectName(u"insert_RX")
        self.insert_RX.setGeometry(QRect(170, 140, 47, 13))
        self.insert_RY = QLabel(Dialog)
        self.insert_RY.setObjectName(u"insert_RY")
        self.insert_RY.setGeometry(QRect(170, 180, 47, 13))
        self.insert_RZ = QLabel(Dialog)
        self.insert_RZ.setObjectName(u"insert_RZ")
        self.insert_RZ.setGeometry(QRect(170, 220, 47, 13))
        self.insert_VX = QLabel(Dialog)
        self.insert_VX.setObjectName(u"insert_VX")
        self.insert_VX.setGeometry(QRect(290, 20, 47, 13))
        self.insert_VY = QLabel(Dialog)
        self.insert_VY.setObjectName(u"insert_VY")
        self.insert_VY.setGeometry(QRect(290, 60, 47, 13))
        self.insert_VZ = QLabel(Dialog)
        self.insert_VZ.setObjectName(u"insert_VZ")
        self.insert_VZ.setGeometry(QRect(290, 100, 47, 13))
        self.insert_function_2 = QPlainTextEdit(Dialog)
        self.insert_function_2.setObjectName(u"insert_function_2")
        self.insert_function_2.setGeometry(QRect(20, 20, 104, 41))
        self.insert_X_2 = QPlainTextEdit(Dialog)
        self.insert_X_2.setObjectName(u"insert_X_2")
        self.insert_X_2.setGeometry(QRect(80, 70, 41, 31))
        self.insert_A_2 = QPlainTextEdit(Dialog)
        self.insert_A_2.setObjectName(u"insert_A_2")
        self.insert_A_2.setGeometry(QRect(80, 110, 41, 31))
        self.insert_Nb_2 = QPlainTextEdit(Dialog)
        self.insert_Nb_2.setObjectName(u"insert_Nb_2")
        self.insert_Nb_2.setGeometry(QRect(80, 150, 41, 31))
        self.insert_OFFSET_2 = QPlainTextEdit(Dialog)
        self.insert_OFFSET_2.setObjectName(u"insert_OFFSET_2")
        self.insert_OFFSET_2.setGeometry(QRect(80, 230, 41, 31))
        self.insert_EXT_2 = QPlainTextEdit(Dialog)
        self.insert_EXT_2.setObjectName(u"insert_EXT_2")
        self.insert_EXT_2.setGeometry(QRect(340, 130, 41, 31))
        self.view_Step_2 = QTextEdit(Dialog)
        self.view_Step_2.setObjectName(u"view_Step_2")
        self.view_Step_2.setGeometry(QRect(80, 190, 41, 31))
        self.insert_XT_2 = QTextEdit(Dialog)
        self.insert_XT_2.setObjectName(u"insert_XT_2")
        self.insert_XT_2.setGeometry(QRect(220, 10, 41, 31))
        self.insert_VX_2 = QPlainTextEdit(Dialog)
        self.insert_VX_2.setObjectName(u"insert_VX_2")
        self.insert_VX_2.setGeometry(QRect(340, 10, 41, 31))
        self.insert_YT_2 = QPlainTextEdit(Dialog)
        self.insert_YT_2.setObjectName(u"insert_YT_2")
        self.insert_YT_2.setGeometry(QRect(220, 50, 41, 31))
        self.insert_ZT = QPlainTextEdit(Dialog)
        self.insert_ZT.setObjectName(u"insert_ZT")
        self.insert_ZT.setGeometry(QRect(220, 90, 41, 31))
        self.insert_RX_2 = QPlainTextEdit(Dialog)
        self.insert_RX_2.setObjectName(u"insert_RX_2")
        self.insert_RX_2.setGeometry(QRect(220, 130, 41, 31))
        self.insert_RY_2 = QPlainTextEdit(Dialog)
        self.insert_RY_2.setObjectName(u"insert_RY_2")
        self.insert_RY_2.setGeometry(QRect(220, 170, 41, 31))
        self.insert_RZ_2 = QPlainTextEdit(Dialog)
        self.insert_RZ_2.setObjectName(u"insert_RZ_2")
        self.insert_RZ_2.setGeometry(QRect(220, 210, 41, 31))
        self.insert_VY_2 = QPlainTextEdit(Dialog)
        self.insert_VY_2.setObjectName(u"insert_VY_2")
        self.insert_VY_2.setGeometry(QRect(340, 50, 41, 31))
        self.insert_VZ_2 = QPlainTextEdit(Dialog)
        self.insert_VZ_2.setObjectName(u"insert_VZ_2")
        self.insert_VZ_2.setGeometry(QRect(340, 90, 41, 31))
        self.invio_OK = QPushButton(Dialog)
        self.invio_OK.setObjectName(u"invio_OK")
        self.invio_OK.setGeometry(QRect(290, 240, 75, 23))
    #UI Dialog
        self.retranslateUi(Dialog)
    #inserisco questa riga tra le due righe per dire a FreeCAd di collegare il bottone alla funzione
        QtCore.QObject.connect(self.OK,QtCore.SIGNAL("pressed()"),self.createPlane)
        QMetaObject.connectSlotsByName(Dialog)
    # setupUi
    def retranslateUi(self, Dialog):
        Dialog.setWindowTitle(QCoreApplication.translate("Dialog", u"Dialog", None))
        self.insert_function.setText(QCoreApplication.translate("Dialog", u"insert function", None))
        self.insert_Nb.setText(QCoreApplication.translate("Dialog", u"insert Nb", None))
        self.insert_X.setText(QCoreApplication.translate("Dialog", u"insert X", None))
        self.insert_EXT.setText(QCoreApplication.translate("Dialog", u"insert EXT", None))
        self.insert_OFFSET.setText(QCoreApplication.translate("Dialog", u"insert OFFSET", None))
        self.insert_A.setText(QCoreApplication.translate("Dialog", u"insert A", None))
        self.view_Step.setText(QCoreApplication.translate("Dialog", u"Step=A/Nb", None))
        self.insert_XT.setText(QCoreApplication.translate("Dialog", u"insert XT", None))
        self.insert_YT.setText(QCoreApplication.translate("Dialog", u"insert YT", None))
        self.insert_ZX.setText(QCoreApplication.translate("Dialog", u"insert ZT", None))
        self.insert_RX.setText(QCoreApplication.translate("Dialog", u"insert RX", None))
        self.insert_RY.setText(QCoreApplication.translate("Dialog", u"insert RY", None))
        self.insert_RZ.setText(QCoreApplication.translate("Dialog", u"insert RZ", None))
        self.insert_VX.setText(QCoreApplication.translate("Dialog", u"insert VX", None))
        self.insert_VY.setText(QCoreApplication.translate("Dialog", u"insert VY", None))
        self.insert_VZ.setText(QCoreApplication.translate("Dialog", u"insert VZ", None))
        self.invio_OK.setText(QCoreApplication.translate("Dialog", u"OK", None))
    # retranslateUi
    #QUESTA SOTTO E' LA FUNZIONE PER FARGLI FARE QUALCOSA
    #XT,YT,ZT sono parametri di traslazione; RX,RY,RZ sono parametri di rotazione attorno agli assi; VX,VY,VZ sono parametri che indicano un vettore rispetto al quale si posizione il solido; i parametri X indicano il punto iniziale del dominio di f; Nb e' un parametro da cui dipende il numero degli step; EXt mi da la dimensione da estrudere
    def createSolidFunction(self):
        X = float(self.insert_X_2.toPlainText())
        Nb = int (self.insert_Nb_2.toPlainText())
        Step = float (self.view_Step_2.toPlaintext())
        Y = 0
        EXT = float (self.insert_EXT_2.toPlainText())
        OFFSET = float (self.insert_OFFSET_2.toPlainText())
        XT = float (self.insert_XT_2.toPlainText())
        YT = float (self.insert_YT_2.toPlainText())
        ZT = float (self.insert_ZT_2.toPlainText())
        RX = float (self.insert_RX_2.toPlainText())
        RY = float (self.insert_RY_2.toPlainText())
        RZ = float (self.insert_RZ_2.toPlainText())
        VX = float (self.insert_VX_2.toPlainText())
        VY = float (self.insert_VY_2.toPlainText())
        VZ = float (self.insert_VZ_2.toPlainText())
        Z=math.sin(X) + OFFSET
    #definisco i vettori
        points = [Base.Vector(X,Y,0)]
    for I in range(Nb):
        XX=X+I*Step
        ZZ=math.sin(XX) + OFFSET
        points.append(Base.Vector(XX,Y,ZZ))
    points.append(Base.Vector(XX,Y,0))
    points.append(points[0])
    poly = Part.makePolygon(points)
    face = Part.Face(poly)
    E = face.extrude(Base.Vector(0,EXT,0))
    #E.Placement=App.Placement(App.Vector(XT,YT,ZT), App.Rotation(RX,RY,RZ), App.Vector(VX,VY,VZ))
    #Gui.activeDocument().activeView().viewIsometric()
    #Gui.ActiveDocument.ActiveView.setAxisCross(True)
    Part.show(E)
    #QUI FINISCE LA FUNZIONE
    #aggiunta di Mario per visualizzare la finestra in freeCAD
from PySide2 import QtWidgets, QtCore
if __name__ == "__main__":
    MainWindow = QtWidgets.QMainWindow()
    ui = Ui_Dialog()
    ui.setupUi(MainWindow)
    MainWindow.show()
    #MainWindow.hide()
sibelius
Re: my second attempt with only one error, getting better
Postby sibelius » Thu Feb 13, 2020 11:42 am
I just saw an error in my code while I was loading related to the button; is not OK but something else.
I'll check again tomorrow.
thanks.
sibelius
Postby sibelius » Thu Feb 13, 2020 11:22 pm
Good morning.
I correct some errors in the code but there is something I'm missing.
I get the following error
  File "<input>", line 136, in createSolidFunction
AttributeError: 'PySide2.QtWidgets.QTextEdit' object has no attribute 'toPlaintext'
Is basically the window where i insert my function.
I cant' also display the Step parameter on the window.
As usual any help would be great.
thank you in advance.
here is the code.
    QRadialGradient)
#se faccio run da python mi da errore perche' FreeCAD non e' un modulo Python
import math
    #UI Dialog
        QtCore.QObject.connect(self.invio_OK,QtCore.SIGNAL("pressed()"),self.createSolidFunction)
    # setupUi
    # retranslateUi
        Y = 0
        F = float (self.insert_function.toPlainText())
        Z = F(X) + OFFSET
        for I in range(Nb):
            XX=X+I*Step
            ZZ=F(XX) + OFFSET
        Part.show(E)
    ui = Ui_Dialog()
    MainWindow.show()
    #MainWindow.hide()
mario52
Postby mario52 » Fri Feb 14, 2020 11:01 am
hi
what to put in "insert function" ?
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
sibelius
Postby sibelius » Fri Feb 14, 2020 10:46 pm
Hi Mario
Thanks again for your precious help.
I think I made a bit of a mess of this code.
I'll try to understand the QLineEdit syntax as someone suggested, even if I think with PlainTextEdit should go well either.
Anyway in the insert function the term F(X) should go in.
I have changed this code; for example the face of the function; I putted F instead of F(X) as you can see down below.
So in the PlainTextEdit of the insert function I'd like to put something like (math.sinx(X) or another function like X*X*X or any continuous function); the term Z is basically the function+OFFSET; the OFFSET translate the function of an OFFSET in Z direction.
 #XT,YT,ZT sono parametri di traslazione; RX,RY,RZ sono parametri di rotazione attorno agli assi; VX,VY,VZ sono parametri che indicano un vettore rispetto al quale si posizione il solido; i parametri X indicano il punto iniziale del dominio di f; Nb e' un parametro da cui dipende il numero degli step; EXT mi da la dimensione da estrudere
import math
A=10
X=-10
Nb=100
Step=A/Nb
Y=0
EXT=5
OFFSET=3
XT=-X
YT=0
ZT=0
RX=0
RY=0
RZ=0
VX=0
VY=0
VZ=0
#Z=math.sin(X) + OFFSET
F=math.sin(X)
Z=F + OFFSET
for I in range(Nb):
    XX=X+I*Step
    F=math.sin(XX)
    ZZ=F + OFFSET
Part.show(E)
sibelius
Postby sibelius » Fri Feb 14, 2020 11:16 pm
hi
so far this is my last attempt; in the second code you can see the function with math.sin(x) and if you paste it in freeCAD it works.
when I paste the complete code in freeCAD, the windows appear correctly but when I insert the parameter, the python consolle give me an error (I'm sure the Python consolle is right).
I also attached a screenshot of the parameters I set in the window and the function I want to process (X*X).
thanks again.
here is the complete code.
## Form generated from reading UI file 'widget_2D_functions2.ui'
    QRadialGradient)
import math
    #UI Dialog
    # setupUi
    # retranslateUi
    #attorno agli assi; VX,VY,VZ sono parametri che indicano un vettore rispetto al
    #quale si posizione il solido; i parametri X indicano il punto iniziale del
    #dominio di f; Nb e' un parametro da cui dipende il numero degli step; EXT mi
    #da la dimensione da estrudere
        A = float(self.insert_A_2.toPlainTextEdit())
        Nb = float (self.insert_Nb_2.toPlainText())
        Step = A/Nb
        Y = 0
        F = float (self.insert_function_2.toPlainText())
        Z = F + OFFSET
        for I in range(Nb):
            XX=X+I*Step
            ZZ=F + OFFSET
        Part.show(E)
    ui = Ui_Dialog()
    MainWindow.show()
    #MainWindow.hide()
here is the function (exemple done with math.sin(x)
import math
A=10
X=-10
Nb=100
Step=A/Nb
Y=0
EXT=5
OFFSET=3
XT=-X
YT=0
ZT=0
RX=0
RY=0
RZ=0
VX=0
VY=0
VZ=0
F=math.sin(X)
Z=F + OFFSET
for I in range(Nb):
    XX=X+I*Step
    F=math.sin(XX)
    ZZ=F + OFFSET
Part.show(E)
johnwang
Postby johnwang » Sat Feb 15, 2020 2:30 am
This will not work.
"X*X" is a string. You can't convert it into a number. You can keep that string, then think of a way to programly generate that function: F=x*x+offset
sibelius
Postby sibelius » Sat Feb 15, 2020 4:43 am
thank you very much for your help.
I will look into that.
thanks again.
PS i'm looking at the syntax of QEditLine but I cant't find at the moment any example to follow.
johnwang
Postby johnwang » Sat Feb 15, 2020 4:57 am
thanks again.
The tutorial you referenced from uses QLineEdit
self.height = QtGui.QLineEdit(Dialog)
sibelius
Postby sibelius » Sat Feb 15, 2020 7:27 am
Thank you.
Do you know what happened?
I follow two different tutorials and I mixed up a bit.
I need a bit of time to reorganize.
thank you again.
I will post the code in a new post.
