This is the final code (for the moment) and the file.ico to add in the toolbar.
# -*- coding: utf-8 -*-
## Form generated from reading UI file 'widget_2D_functions2.ui'
## Created by: Qt User Interface Compiler version 5.14.1
## WARNING! All changes made in this file will be lost when recompiling UI file!
#https://forum.freecadweb.org/viewtopic.php?f=22&t=43341
#riga inserita da me
import sympy
#riga (from sympy import *) aggiunta da me
from sympy import *
from PySide2.QtCore import (QCoreApplication, QMetaObject, QObject, QPoint,
QRect, QSize, QUrl, Qt)
from PySide2.QtGui import (QBrush, QColor, QConicalGradient, QCursor, QFont,
QFontDatabase, QIcon, QLinearGradient, QPalette, QPainter, QPixmap,
QRadialGradient)
from PySide2.QtWidgets import *
#QUESTA RIGA O BLOCCO SOTTO LA/LO AGGIUNGO DOPO AVER DEFINITO LA FUNZIONE. LA FUNZIONE SI CHIAMA createSolidFunction
#se faccio run da python mi da errore perche' FreeCAD non e' un modulo Python
import FreeCAD, FreeCADGui, Part
import math
from FreeCAD import Base
class Ui_Dialog(object):
def setupUi(self, Dialog):
if Dialog.objectName():
Dialog.setObjectName(u"Dialog")
Dialog.resize(396, 300)
self.insert_function = QLabel(Dialog)
self.insert_function.setObjectName(u"insert_function")
self.insert_function.setGeometry(QRect(20, 0, 81, 20))
self.insert_X = QLabel(Dialog)
self.insert_X.setObjectName(u"insert_X")
self.insert_X.setGeometry(QRect(20, 80, 47, 13))
self.insert_A = QLabel(Dialog)
self.insert_A.setObjectName(u"insert_A")
self.insert_A.setGeometry(QRect(20, 120, 47, 13))
self.insert_Nb = QLabel(Dialog)
self.insert_Nb.setObjectName(u"insert_Nb")
self.insert_Nb.setGeometry(QRect(10, 160, 61, 16))
self.insert_OFFSET = QLabel(Dialog)
self.insert_OFFSET.setObjectName(u"insert_OFFSET")
self.insert_OFFSET.setGeometry(QRect(10, 240, 81, 16))
self.insert_XT = QLabel(Dialog)
self.insert_XT.setObjectName(u"insert_XT")
self.insert_XT.setGeometry(QRect(170, 20, 47, 13))
self.insert_YT = QLabel(Dialog)
self.insert_YT.setObjectName(u"insert_YT")
self.insert_YT.setGeometry(QRect(170, 60, 47, 13))
self.insert_ZT = QLabel(Dialog)
self.insert_ZT.setObjectName(u"insert_ZT")
self.insert_ZT.setGeometry(QRect(170, 100, 47, 13))
self.insert_RX = QLabel(Dialog)
self.insert_RX.setObjectName(u"insert_RX")
self.insert_RX.setGeometry(QRect(170, 140, 47, 13))
self.insert_RY = QLabel(Dialog)
self.insert_RY.setObjectName(u"insert_RY")
self.insert_RY.setGeometry(QRect(170, 180, 47, 13))
self.insert_RZ = QLabel(Dialog)
self.insert_RZ.setObjectName(u"insert_RZ")
self.insert_RZ.setGeometry(QRect(170, 220, 47, 13))
self.insert_VX = QLabel(Dialog)
self.insert_VX.setObjectName(u"insert_VX")
self.insert_VX.setGeometry(QRect(290, 20, 47, 13))
self.insert_VY = QLabel(Dialog)
self.insert_VY.setObjectName(u"insert_VY")
self.insert_VY.setGeometry(QRect(290, 60, 47, 13))
self.insert_VZ = QLabel(Dialog)
self.insert_VZ.setObjectName(u"insert_VZ")
self.insert_VZ.setGeometry(QRect(290, 100, 47, 13))
self.insert_EXT = QLabel(Dialog)
self.insert_EXT.setObjectName(u"insert_EXT")
self.insert_EXT.setGeometry(QRect(280, 140, 47, 13))
self.insert_function_2 = QLineEdit(Dialog)
self.insert_function_2.setObjectName(u"insert_function_2")
self.insert_function_2.setGeometry(QRect(20, 20, 104, 41))
self.insert_X_2 = QLineEdit(Dialog)
self.insert_X_2.setObjectName(u"insert_X_2")
self.insert_X_2.setGeometry(QRect(80, 70, 41, 31))
self.insert_X_2.setText("-10")
self.insert_A_2 = QLineEdit(Dialog)
self.insert_A_2.setObjectName(u"insert_A_2")
self.insert_A_2.setGeometry(QRect(80, 110, 41, 31))
self.insert_A_2.setText("10")
self.insert_Nb_2 = QLineEdit(Dialog)
self.insert_Nb_2.setObjectName(u"insert_Nb_2")
self.insert_Nb_2.setGeometry(QRect(80, 150, 41, 31))
self.insert_Nb_2.setText("100")
self.insert_OFFSET_2 = QLineEdit(Dialog)
self.insert_OFFSET_2.setObjectName(u"insert_OFFSET_2")
self.insert_OFFSET_2.setGeometry(QRect(80, 230, 41, 31))
self.insert_OFFSET_2.setText("5")
self.insert_XT_2 = QLineEdit(Dialog)
self.insert_XT_2.setObjectName(u"insert_XT_2")
self.insert_XT_2.setGeometry(QRect(220, 10, 41, 31))
self.insert_XT_2.setText("10")
self.insert_YT_2 = QLineEdit(Dialog)
self.insert_YT_2.setObjectName(u"insert_YT_2")
self.insert_YT_2.setGeometry(QRect(220, 50, 41, 31))
self.insert_YT_2.setText("0")
self.insert_ZT_2 = QLineEdit(Dialog)
self.insert_ZT_2.setObjectName(u"insert_ZT_2")
self.insert_ZT_2.setGeometry(QRect(220, 90, 41, 31))
self.insert_ZT_2.setText("0")
self.insert_RX_2 = QLineEdit(Dialog)
self.insert_RX_2.setObjectName(u"insert_RX_2")
self.insert_RX_2.setGeometry(QRect(220, 130, 41, 31))
self.insert_RX_2.setText("0")
self.insert_RY_2 = QLineEdit(Dialog)
self.insert_RY_2.setObjectName(u"insert_RY_2")
self.insert_RY_2.setGeometry(QRect(220, 170, 41, 31))
self.insert_RY_2.setText("0")
self.insert_RZ_2 = QLineEdit(Dialog)
self.insert_RZ_2.setObjectName(u"insert_RZ_2")
self.insert_RZ_2.setGeometry(QRect(220, 210, 41, 31))
self.insert_RZ_2.setText("0")
self.insert_VX_2 = QLineEdit(Dialog)
self.insert_VX_2.setObjectName(u"insert_VX_2")
self.insert_VX_2.setGeometry(QRect(340, 10, 41, 31))
self.insert_VX_2.setText("0")
self.insert_VY_2 = QLineEdit(Dialog)
self.insert_VY_2.setObjectName(u"insert_VY_2")
self.insert_VY_2.setGeometry(QRect(340, 50, 41, 31))
self.insert_VY_2.setText("0")
self.insert_VZ_2 = QLineEdit(Dialog)
self.insert_VZ_2.setObjectName(u"insert_VZ_2")
self.insert_VZ_2.setGeometry(QRect(340, 90, 41, 31))
self.insert_VZ_2.setText("0")
self.insert_EXT_2 = QLineEdit(Dialog)
self.insert_EXT_2.setObjectName(u"insert_EXT_2")
self.insert_EXT_2.setGeometry(QRect(340, 130, 41, 31))
self.insert_EXT_2.setText("5")
self.invio_OK = QPushButton(Dialog)
self.invio_OK.setObjectName(u"invio_OK")
self.invio_OK.setGeometry(QRect(290, 240, 75, 23))
#UI Dialog
self.retranslateUi(Dialog)
#inserisco questa riga tra le due righe per dire a FreeCAd di collegare il bottone alla funzione
QtCore.QObject.connect(self.invio_OK,QtCore.SIGNAL("pressed()"),self.createSolidFunction)
QMetaObject.connectSlotsByName(Dialog)
# setupUi
def retranslateUi(self, Dialog):
Dialog.setWindowTitle(QCoreApplication.translate("Dialog", u"Dialog", None))
self.insert_function.setText(QCoreApplication.translate("Dialog", u"insert function", None))
self.insert_X.setText(QCoreApplication.translate("Dialog", u"insert X", None))
self.insert_A.setText(QCoreApplication.translate("Dialog", u"insert A", None))
self.insert_Nb.setText(QCoreApplication.translate("Dialog", u"insert Nb", None))
self.insert_OFFSET.setText(QCoreApplication.translate("Dialog", u"insert OFFSET", None))
self.insert_XT.setText(QCoreApplication.translate("Dialog", u"insert XT", None))
self.insert_YT.setText(QCoreApplication.translate("Dialog", u"insert YT", None))
self.insert_ZT.setText(QCoreApplication.translate("Dialog", u"insert ZT", None))
self.insert_RX.setText(QCoreApplication.translate("Dialog", u"insert RX", None))
self.insert_RY.setText(QCoreApplication.translate("Dialog", u"insert RY", None))
self.insert_RZ.setText(QCoreApplication.translate("Dialog", u"insert RZ", None))
self.insert_VX.setText(QCoreApplication.translate("Dialog", u"insert VX", None))
self.insert_VY.setText(QCoreApplication.translate("Dialog", u"insert VY", None))
self.insert_VZ.setText(QCoreApplication.translate("Dialog", u"insert VZ", None))
self.insert_EXT.setText(QCoreApplication.translate("Dialog", u"insert EXT", None))
self.invio_OK.setText(QCoreApplication.translate("Dialog", u"OK", None))
# retranslateUi
#QUESTA SOTTO E' LA FUNZIONE PER FARGLI FARE QUALCOSA
#XT,YT,ZT sono parametri di traslazione; RX,RY,RZ sono parametri di rotazione
#attorno agli assi; VX,VY,VZ sono parametri che indicano un vettore rispetto al
#quale si posizione il solido; i parametri X indicano il punto iniziale del
#dominio di f; Nb e' un parametro da cui dipende il numero degli step; EXT mi
#da la dimensione da estrudere
def createSolidFunction(self):
x = symbols('x')
A = float(self.insert_A_2.text())
X_INIZ = float (self.insert_X_2.text())
Nb = int (self.insert_Nb_2.text())
Step = A/Nb
Y = 0
EXT = float (self.insert_EXT_2.text())
OFFSET = float (self.insert_OFFSET_2.text())
####devo scambiare x con z nelle rotazioni
XT = float (self.insert_XT_2.text())
YT = float (self.insert_YT_2.text())
ZT = float (self.insert_ZT_2.text())
RX = float (self.insert_RZ_2.text())
RY = float (self.insert_RY_2.text())
RZ = float (self.insert_RX_2.text())
VX = float (self.insert_VX_2.text())
VY = float (self.insert_VY_2.text())
VZ = float (self.insert_VZ_2.text())
# F = float(self.insert_function_2.text())
### riga modificata da me
F = sympify(self.insert_function_2.text()).subs(x,X_INIZ).evalf()
Z = F + OFFSET
#definisco i vettori
points = [Base.Vector(X_INIZ,Y,0)]
for I in range(Nb):
XX=X_INIZ+I*Step
F = sympify(self.insert_function_2.text()).subs(x,XX).evalf()
ZZ=F + OFFSET
points.append(Base.Vector(XX,Y,ZZ))
points.append(Base.Vector(XX,Y,0))
points.append(points[0])
poly = Part.makePolygon(points)
face = Part.Face(poly)
E = face.extrude(Base.Vector(0,EXT,0))
P = E.Placement=App.Placement(App.Vector(XT,YT,ZT), App.Rotation(RX,RY,RZ), App.Vector(VX,VY,VZ))
# Gui.activeDocument().activeView().viewIsometric()
# Gui.ActiveDocument.ActiveView.setAxisCross(True)
Part.show(E)
#QUI FINISCE LA FUNZIONE
#aggiunta di Mario per visualizzare la finestra in freeCAD
from PySide2 import QtWidgets, QtCore
if __name__ == "__main__":
MainWindow = QtWidgets.QMainWindow()
ui = Ui_Dialog()
ui.setupUi(MainWindow)
MainWindow.show()
#MainWindow.hide()
