[Help] How to get WBs, Toolbars, Tools
Re: [Help] How to get WBs, Toolbars, Tools
Post by Kunda1 »
wmayer wrote: git commit 8663e724f
wb=Gui.activeWorkbench()
wb.getToolbarItems()
Thanks @wmayer :D
HakanSeven12
Post by HakanSeven12 »
It works :)
https://forum.freecadweb.org/viewtopic. ... 37#p384479
HakanSeven12
wmayer wrote: Sat Apr 04, 2020 9:49 am git commit 8663e724f
Hi. I can get every command by using this code. But some commands are command groups. How can I get the commnds of command group?
For example I want to get this commands.
command group.png (11.69 KiB) Viewed 820 times
workbenches = Gui.listWorkbenches()
for wb_name in workbenches:
    Gui.activateWorkbench(wb_name)
    wb = Gui.getWorkbench(wb_name)
    items = wb.getToolbarItems()
    for i in items:
        #if i in pass_list: pass
        tb_name = i
        toolbar = items[i]
        for cmd in toolbar:
            command = Gui.Command.get(cmd)
            print(command)
Founder
Post by wmayer »
HakanSeven12 wrote: Sun Nov 22, 2020 7:21 pm Hi. I can get every command by using this code. But some commands are command groups. How can I get the commnds of command group?
I see. This is currently not possible. What we need is a way to check if a QAction has a QMenu and if yes also list its items.
HakanSeven12
When I created Modern UI, I accessed to qpushbuttons in toolbars. But İt's just a work around. So I don't like this method. If there is another way, it would be good for me.
Founder
Post by wmayer »
git commit b3200a8a9 implements a way to get the QAction of a Command. This function always returns a list which can
  • be empty if the command is not used yet in a workbench
  • have a single element which is the case for the majority of commands
  • have several elements for an action group
cmd = Gui.Command.get("Sketcher_CompCreateRegularPolygon")
cmd.getAction()
cmd = Gui.Command.get("Sketcher_CreatePoint")
cmd.getAction()
From a QAction you should get all the additional information you need. See https://doc.qt.io/qt-5/qaction.html
HakanSeven12
That was realy quick :) thanks
Post by Kunda1 »
Anybody game to document this?
HakanSeven12
Kunda1 wrote: Mon Nov 23, 2020 7:13 pm Anybody game to document this?
I think there must be an UI api for python which UI developers can reach, edit or disable UI objects. Then we can talk about a documentation. Otherwise there is just some code that can reach wbs and their commands.
