Assumed:
- two identical wire
- made only from straight edges
- same start point
- the rest could be some how turned in 3D orbit
I would like to somehow save what is needed to move and turn one wire into the other. As input I only have the shapes of the wire.
Someone know how to do this?
placement transformation
Re: placement transformation
This should do it :
Assuming that the first 3 vertexes of the shape correctly define a plane (not coincident, nor colinear)
def get_relative_placement(shape1, shape2):
"returns the placement that must be applied to shape1 to move it to shape_2"
plane1 = Part.Plane(*[v.Point for v in shape1.Vertexes[0:3]])
plane2 = Part.Plane(*[v.Point for v in shape2.Vertexes[0:3]])
pl1 = FreeCAD.Placement(plane1.Position, plane1.Rotation)
pl2 = FreeCAD.Placement(plane2.Position, plane2.Rotation)
return pl2.multiply(pl1.inverse())
Great! Exactly what I need
Where did you get it from, or did you just coded it?
just coded
obj.Placement = myRelativePlacment.multiply(obj.Placement)
