Animate using Spreadsheet Value
veryevil
Postby veryevil » Thu Apr 16, 2020 9:13 am
Hi, I have two parts I want to move based on a value in a spreadsheet with the alias lift. I would like to run a script to change lift from 0 to 50 in 0.25 intervals and update the display.
I have the spread sheet set up fine and I can manually edit the value and the parts move as the formula specifies but I would like to be able to run a macro and have it update. So I can animate the objects travel to look for clearances etc.
Is this possible?
Thanks
microelly2
Re: Animate using Spreadsheet Value
Postby microelly2 » Thu Apr 16, 2020 10:00 am
You can use the animation workbench
https://youtu.be/AQjAa5JxmOg
There is a way to use expressions to get the data from a spreadsheet into the parameters of the placer as expressions.
Postby Kunda1 » Mon Apr 27, 2020 2:55 am
Caveat: not for v0.19 py3 qt5
