Render animation frame and stream to video file
Hi all. New user here. Nice to meet you all. I'm an Electrical Engineer by profession, but I tinker with robotics in my spare time. I'm planning to use FreeCAD's scripting capabilities to simulate the gait of a hexapod. I originally hand-wrote a Python-based OpenGL simulator for a 6 DOF robotic arm (here's a screenshot: https://i.imgur.com/UnfD8Fj.jpg) but it's a huge pain to rig. FreeCAD looks like a promising upgrade for complex mechanisms.
I've been playing around with script-based animation via A2Plus and I really appreciate the simplicity of joint actuation when imposing constraints. My concern, however, is slow rendering on the active view due to expensive computation at each time step.
So I had an idea. I'd like to script a job that renders one frame at a time, exporting each frame to a video stream output. I would gladly sacrifice the real-time animation for a smooth video end result. I'd imagine PySide2 can stream to a video buffer, I'm just not sure how to grab the active view (with transparent background).
Any thoughts how I could make this happen? Does this idea seem reasonable?
Note: I'd like to avoid Blender as this would require re-rigging the model.
Re: Render animation frame and stream to video file
Have you investigated Assembly4? It can also do animations, and since it doesn't use a constraint solver, it may be faster. You may give it a try.
See Challenge: Constant Velocity Joint (M. Gesik)
Thanks for the link. I suppose my question is not how to improve rendering time but rather how to capture the active view with a transparent background so that I can feed it into a video buffer stream. Sorry if that wasn't clear. According to https://forum.freecadweb.org/viewtopic.php?t=29968 I can screen-grab with:vocx wrote: ↑Sun May 03, 2020 3:46 pmHave you investigated Assembly4? It can also do animations, and since it doesn't use a constraint solver, it may be faster. You may give it a try.
activeView = FreeCADGui.activeDocument().activeView()
activeView.saveImage(fileName,1000,800,'White')
I know what you wanted to do, I just mentioned Assembly4 in case you wanted to test that as well.
As for taking pictures, you can test different options of the Std_ViewScreenShot tool. Various rendering options were added in 0.19. I haven't tested them myself. Maybe one of them helps.
See Issue with "saveImage" and Parts with Transparency Nonzero.
I had a further read and it seems that Qt5 isn't able to write a video file natively on Windows anyway. So unless I use something like OpenCV I'll be forced to export screenshots and stitch them together afterwards. Not too elegant, but not the end of the world!vocx wrote: ↑Sun May 03, 2020 8:40 pmI know what you wanted to do, I just mentioned Assembly4 in case you wanted to test that as well.
hi
try this macro Macro_Screen_Wiki (special for the wiki worker) only for FC 0.19
choice the definition image , background visualise wit Set Screen or Tile Screen (facultatif) save your first image (name path...) after, if you want create serial image for create a gif animation (with other program) click the Follow button and the image are saved with the same name, path + 00x number without passing to the window Save image. (You have also window for create Rotation)
install with AddonManager
EDIT: 15h53 PARIS uprgade Version=0.02: 2020/05/04 (correct bug color, restore)
mario
mario
Hey that's pretty neat. It's nearly what I'm looking for, except that I'll also need to animate joint movements. I had a look at the source and there's a lot of good stuff to get me started on writing a script of my own. Thanks for sharing. Out of curiosity, is there something in particular that needs PySide2 (Qt5) that I should be aware of? 0.19 has a few visual bugs so I'm planning to stick with 0.18 for now.mario52 wrote: ↑Mon May 04, 2020 9:24 am hi
mario
If you see bugs they won't be solved unless you report them.
Independently of that, Qt4 is obsolete, so you should be using Python 3 and Qt5, instead of staying with Python 2 and Qt4.
hi
for animation you have :
Animation_Workbench
here for rotate and save image step by step
Manipulator_Workbench
Placement
my other macro Macro_Rotate_To_Point
mario
natural evolution and i work for convert my all macros
Animation_Workbench
Placement
mario
- jimmihenry
