Align sketch with face
I am trying to align a sketch with the face of a wall, but have a hard time understanding the Axis and Rotation logic of the sketch. Are there any resources explaining this? Or perhaps some examples?
Re: Align sketch with face
Do you mean the properties that appear in the property editor?
The display is a bit strange to grasp because internally the rotation is handled through quaternions. The best you could do is use Part_Attachment to position the sketch on the face, and let the program automatically calculate the Axis and Angle, and all those values.
See also Placement, and Tutorial_custom_placing_of_windows_and_doors.
@jaisejames
Thanks I'll have a go with that example.
@vocx
My goal is to create a macro to automate the steps described in Tutorial_custom_placing_of_windows_and_doors.
@vocx
Ultimately the example was too hard to understand for me. I have used a matrix solution instead:
import FreeCAD as App
import FreeCADGui as Gui
def WinFix():
errorMessage = "Selection error: Selection must contain exactly one window and one planar wall face\n"
selLst = Gui.Selection.getSelectionEx()
if len(selLst) != 2:
App.Console.PrintMessage(errorMessage)
return
objGui = selLst[0]
if objGui.Object.Proxy.__module__ == "ArchWindow":
win = objGui.Object
walGui = selLst[1]
wal = walGui.Object
else:
win = selLst[1].Object
walGui = objGui
wal = walGui.Object
if win.Proxy.__module__ != "ArchWindow":
return
if wal.Proxy.__module__ != "ArchWall":
return
if not walGui.HasSubObjects:
return
if len(walGui.SubObjects) != 1:
return
face = walGui.SubObjects[0]
# if not type(face.Surface) is Part.Plane:
if not face.Surface.isPlanar():
return
ske = win.Base
if not ske.isDerivedFrom("Sketcher::SketchObject"):
return
Gui.Selection.clearSelection()
# https://forum.freecadweb.org/viewtopic.php?t=420
# Calculate u, v and w vectors and t (=translation) vector.
w = face.normalAt(0, 0)
v = App.Vector(0.0, 0.0, 1.0)
u = v.cross(w)
# c = face.CenterOfMass
# t = App.Vector(c.x, c.y, ske.Placement.Base.z)
b = face.BoundBox
# Calculate 2 out of 4 possible bottom vectors:
xA = App.Vector(b.XMax - b.XMin, b.YMax - b.YMin, 0.0).normalize() # BL to TR.
xB = App.Vector(b.XMax - b.XMin, b.YMin - b.YMax, 0.0).normalize() # TL to BR.
# Compare u vector with bottom vectors to position t at left edge of face (t.z calculated later):
if u.isEqual(xA, 1e-6):
t = App.Vector(b.XMin, b.YMin, 0)
elif u.isEqual(xA.negative(), 1e-6):
t = App.Vector(b.XMax, b.YMax, 0)
elif u.isEqual(xB, 1e-6):
t = App.Vector(b.XMin, b.YMax, 0)
else:
t = App.Vector(b.XMax, b.YMin, 0)
m = App.Matrix(
u.x, v.x, w.x, t.x,
u.y, v.y, w.y, t.y,
u.z, v.z, w.z, ske.Placement.Base.z + win.Placement.Base.z,
0.0, 0.0, 0.0, 1.0)
ske.Placement = App.Placement(m)
win.Placement = App.Placement() # Reset win placement.
win.Normal = w.negative()
oldHosts = win.Hosts
win.Hosts = [wal]
# Avoid recomputing whole doc (works if there are no other windows in oldHosts):
for host in oldHosts:
host.touch() # Required!
host.recompute(True)
ske.recompute(True)
win.recompute(True)
wal.recompute(True)
return
Neither Part nor Arch are used, so you should not import them.Roy_043 wrote: ↑Sun May 24, 2020 2:04 pm Ultimately the example was too hard to understand for me. I have used a matrix solution instead:
Also, please notice that standard indentation in Python is 4 spaces. Using two spaces makes the code crowded and a bit unreadable. Python relies on whitespace to be readable. I think I've read the standard in Ruby or one of those languages is 2, but that's too little in the opinion of Python.
Right, I am still in 'Lisp mode'.
Fixed that + added reset of window placement + tried to improve the recompute.
