Add method to PythonObject [SOLVED]
keithsloan52
Postby keithsloan52 » Sat May 30, 2020 9:55 am
I am unable to add a method to a class for a PythonObject what am I doing wrong?
class PObject :
def __init__(self, obj,...)
def addProp(self) :
print('test')
tst = PObject(obj,...)
tst.addProp()
<class 'AttributeError'>: 'PObject' object has no attribute 'addProp'
OS: macOS 10.15
Version: 0.18.16146 (Git)
Branch: (HEAD detached at 0.18.4)
Python version: 3.6.7
Qt version: 5.6.2
onekk
Re: Add method to PythonObject
Postby onekk » Sat May 30, 2020 1:09 pm
maybe using the code tags will be a better way, the indentation is not shown, in your code, so it is difficult to see what is wrong.
It seems, that a PythonObject class must be derived from an existing FreeCAD class, to inherit some basic property, but I'm not an expert.
see maybe :
https://github.com/FreeCAD/FreeCAD/blob ... /Shapes.py
or maybe
https://github.com/FreeCAD/FreeCAD/blob ... eatures.py
or even
https://github.com/FreeCAD/FreeCAD/blob ... bspline.py
For some hint on how to make an object.
Hope it helps
Regards
Carlo D.
keithsloan52
Postby keithsloan52 » Sat May 30, 2020 6:56 pm
see maybe :
or maybe
or even
Hope it helps
Regards
Carlo D.
Well the code I tried to show is not what I have actually coded it was just an attempt to illustrate the problem.
Actual code looks like
class GDMLTessellated(GDMLcommon) :
   def __init__(self, obj, material) :
      obj.addProperty('App::PropertyBool','editable','GDMLTessellated', \
                      'Editable').editable = False
      obj.addExtension('App::OriginGroupExtensionPython', self)
      obj.addProperty("App::PropertyEnumeration","material", \
                      "GDMLTessellated","Material")
      setMaterial(obj, material)
      self.Type = 'GDMLTessellated'
      self.Vertex = []
      self.Faces  = []
      self.Object = obj
      obj.Proxy = self
   def onChanged(self, fp, prop):
       '''Do something when a property has changed'''
       #print(fp.Label+" State : "+str(fp.State)+" prop : "+prop)
       if 'Restore' in fp.State :
          return
       if prop in ['material'] :
           fp.ViewObject.ShapeColor = colourMaterial(fp.material)
       if prop in ['editable'] :
           if editable == True :
              addProperties()
       if prop in ['lunit'] :
          self.createGeometry(fp)
   def addVertex(self,v) :
       self.Vertex.append(v)
As well as addVertex there are other functions that I wish to use.
But if in some other code I have
      tess = GDMLTessellated(obj,0)
If I then do print(dir(tess))
It does not list addVertex or any of the other similar functions.
Thing is I wish to update the GDMLTessellated object tess some time after creation.
keithsloan52
Postby keithsloan52 » Sun May 31, 2020 5:53 am
This seems to have some relevance https://forum.freecadweb.org/viewtopic. ... 1&start=10
As I don't really understand the use of proxy maybe I am missing a trick @wmayer
onekk
Postby onekk » Sun May 31, 2020 10:57 am
I don't understand, completely the post of wmayer, it is true that i don't work much on the interface part.
Generally I use the exposed python functions to make objects, so the solid part will suffice my needs, (creating 3d object for 3d printing).
The "Modelling" part of FreeCAD is what I nedd, i know (not in a too deep way), as I'm partepating in some "theoric" discussion on some interface modifications, maybe from some time i will achieve a little knowledge about the GUI and App part (They are separated, as FreeCAD is nott using the internal OCCT visualisation part and is using Coin 3D to visualize the solids).
This is mostly all the interface matters I know, from now.
Regards
Carlo D.
keithsloan52
Postby keithsloan52 » Sun May 31, 2020 1:26 pm
Tried adding @expose as per the example in the post but get error expose not defined.
Is @expose a Python 2.x facility not available Python3?
onekk
Postby onekk » Sun May 31, 2020 3:12 pm
@expose is a python decorator, (I don't know exactly what is the purpose of a decorator) I've downloaded FreeCAD sources, that I've downloaded to study them some weeks ago, (0.19 branch, not up to date, but useful, I don't want to use much bandwidth, as I'm on pay for X GB connection, and my childrens are using it for school).
A quick analysis show that #expose is not in the actual code, and the post you cite is almost old 2013 or so on.
Try to wait some more time, generally developers are around this forum tree, and maybe if the post are populated enough some of them will answer your questions.
Regards
Carlo D.
keithsloan52
Postby keithsloan52 » Tue Jun 02, 2020 2:17 pm
Seems the functions are available via the Proxy
