Contradicting number of faces
orxshi
Post by orxshi »
In the following code, I make a face and extrude it. Resultant number of faces is expected to be 20. In GUI, I hovered over and saw the names of each face (see blue semi-circle in image). Indeed there were 20 faces. But when I do geometry check on the solid (extrusion), it says there are 19 faces (see red circle in image). I am sure that there are actually 19 faces because using this geometry in my code causes problem due to missing face. My question is why I count 20 faces in GUI but actually there are 19 faces? Why there is a missing face?
import sys
import math
import numpy
sys.path.append('/usr/lib/freecad/lib/')
import FreeCAD
import Part
doc = App.newDocument('newdoc')
chord = 2.61
thick = 12 * chord / 100;
wing_z_start = 0
wing_z_end = 33.88
nx = 10;
x = numpy.linspace(0, chord, nx)
def y(x):
    C1 = 0.2969
    C2 = 0.1260
    C3 = 0.3516
    C4 = 0.2843
    C5 = 0.1036
    xc = x / chord
    y = thick * chord / 0.2 * (C1 * xc**(1/2) - C2 * xc**(1) - C3 * xc**(2) + C4 * xc**(3) - C5 * xc**(4))
    return y
# make points
points = []
for i in range(len(x)):
    points.append(App.Vector(x[i], y(x[i]), wing_z_start))
for i in reversed(range(1, len(x)-1)):
    points.append(App.Vector(x[i], -y(x[i]), wing_z_start))
points.append(points[0])
# polygon -> face -> extrude
polygon = Part.makePolygon(points)
face = Part.Face(polygon)
wing = face.extrude(App.Vector(0,0,wing_z_end))
Part.show(wing)
https://ibb.co/wyK63Ch
Re: Contradicting number of faces
Pasting your code in the Python console yields an error:
>>> # make points
>>> points = []
...     points.append(App.Vector(x[i], y(x[i]), wing_z_start))
... for i in reversed(range(1, len(x)-1)):
  File "<input>", line 3
SyntaxError: invalid syntax
orxshi
Post by orxshi »
I don't know how you paste in python console but I tried both freecadcmd and freecad itself and did not get any error.
EDIT: I also pasted into python console (didn't know I can do this) and also got the same error. I don't know why.
EDIT2: Adding newline before and after the problematic error line gets rid of the python error. But still does not show the solid. Why don't you do "freecad thefilename" directly?
openBrain
Post by openBrain »
Looks like the content given by geometry checker is totally wrong.
There are 20 faces :
>>> len(App.ActiveDocument.Shape.Shape.Faces)
20
It's worth regarding vertices. Checker states shape has 18 vertices while it actually has :
>>> len(App.ActiveDocument.Shape.Shape.Vertexes)
36
EDIT : shameful error. :)
orxshi
Post by orxshi »
Yeah looks like geometry checker gives false numbers. BTW, I take back one of the things I said:
There are 20 faces for sure. The problem with my code was due to forgetting that numbering starts from 1 and I forgot to add last face. Such as
temp = []
for i in range(4, len(cut_object.Shape.Faces) + 1): # +1 is important
    temp.append((cut_object, 'Face' + str(i)))
TheMarkster
Post by TheMarkster »
It is interesting if you do draft downgrade (to faces) then draft upgrade (to shell) and draft upgrade again (to solid) checkgeometry gives correct face count.
Is CheckGeometry within reach of FreeCAD or is it completely hidded in OCC?
vocx
Post by vocx »
chrisb wrote: Tue Jul 21, 2020 12:00 am Is CheckGeometry within reach of FreeCAD or is it completely hidded in OCC?
The Part_CheckGeometry tool is defined inside Part/Gui/Command.cpp
https://github.com/FreeCAD/FreeCAD/blob ... 2118-L2139
The only thing it does is create the task panel, inside Part/Gui/TaskCheckGeometry.cpp
https://github.com/FreeCAD/FreeCAD/blob ... ometry.cpp
However, the code that is actually called does use a bunch of OCCT functions and methods. For example, it seems to use some sort of BRepCheck_Analyzer to check the internal Shape of the selected objects. The display of the information is controlled by FreeCAD though.
void TaskCheckGeometryResults::recursiveCheck(const BRepCheck_Analyzer &shapeCheck, const TopoDS_Shape &shape,
                                              ResultEntry *parent)
    ResultEntry *branchNode = parent;
    BRepCheck_ListIteratorOfListOfStatus listIt;
    if (!shapeCheck.Result(shape).IsNull() && !checkedMap.Contains(shape))
        listIt.Initialize(shapeCheck.Result(shape)->Status());
        if (listIt.Value() != BRepCheck_NoError)
            ResultEntry *entry = new ResultEntry();
            entry->parent = parent;
            entry->shape = shape;
            entry->buildEntryName();
            entry->type = shapeEnumToString(shape.ShapeType());
            entry->error = checkStatusToString(listIt.Value());
            entry->viewProviderRoot = currentSeparator;
            entry->viewProviderRoot->ref();
            dispatchError(entry, listIt.Value());
            parent->children.push_back(entry);
            branchNode = entry;
    checkedMap.Add(shape);
    if (shape.ShapeType() == TopAbs_SOLID)
        checkSub(shapeCheck, shape, TopAbs_SHELL, branchNode);
    if (shape.ShapeType() == TopAbs_EDGE)
        checkSub(shapeCheck, shape, TopAbs_VERTEX, branchNode);
    if (shape.ShapeType() == TopAbs_FACE)
        checkSub(shapeCheck, shape, TopAbs_WIRE, branchNode);
        checkSub(shapeCheck, shape, TopAbs_EDGE, branchNode);
    for (TopoDS_Iterator it(shape); it.More(); it.Next())
        recursiveCheck(shapeCheck, it.Value(), branchNode);
void TaskCheckGeometryResults::checkSub(const BRepCheck_Analyzer &shapeCheck, const TopoDS_Shape &shape,
                                        const TopAbs_ShapeEnum subType, ResultEntry *parent)
    BRepCheck_ListIteratorOfListOfStatus itl;
    TopExp_Explorer exp;
    for (exp.Init(shape,subType); exp.More(); exp.Next())
        const Handle(BRepCheck_Result)& res = shapeCheck.Result(exp.Current());
Thanks for the information. If I understand it right FreeCAD only calls and collects the information from OCC.
TheMarkster
chrisb wrote: Tue Jul 21, 2020 7:09 am Thanks for the information. If I understand it right FreeCAD only calls and collects the information from OCC.
It does, but we can count the faces, edges, etc. ourselves and display that in the results instead of relying on OCCT. I'm working on a PR for this. The advantage of this is not only can we ensure to get accurate counts, but we can also add additional information, for example volume, area, etc.
Edit: https://github.com/FreeCAD/FreeCAD/pull/3747
