v1.7 -- Renamed pinger.FCMacro.py to pinger.py and added pinger_launcher.py. Use pinger_launcher.py to run the macro if you installed it in Macros/pinger using git. To install this way, enter this from a git bash terminal inside your Macros folder:
git clone https://github.com/mwganson/pinger.git
Copy the file pinger_launcher.py into your Macros folder. Run the launcher to run the macro. To update the macro, from the Macros/pinger folder in a git bash terminal, enter:
git pull
v1.5 of the macro can open the html version in a new browser window by holding shift key while launching it. This is experimental at this stage. The pinger.html file must reside in the same folder as the macro for the macro to be able to find it.
Latest version is now 1.4 for the html, macro also updated. Now with 2015 users.
Update: now includes ability to copy freecad about information to the clipboard from the macro.
Update: new there is html version, too.
See the github repo for the javascript/html version and for the latest macro source:
Pinger macro.
This will aid in pinging users on the forum. When you execute it you get a dialog prompting you to select the user to ping from the list. The selected user and his userid get copied to the clipboard for easy pasting into the forum. Paste into the forum the code generated by the macro, for example:
[quote=TheMarkster user_id=19292]
pinged by pinger macro
[/quote]
This contains currently the top 348 users, as sorted by number of posts made to the board. You can add new users by modifying the source code.TheMarkster wrote: pinged by pinger macro
You can change the variable "limitToTopNUsers" to some other value if you want fewer names in the list.
Limitations:
** Database will not be updated unless you do it manually (or if I update at some point)
If you don't want your username included in this macro ping me and let me know so I can remove it.
# -*- coding: utf-8 -*-
## Pinger macro v1.61
## By: TheMarkster
# 2020.08.12
## Aids in pinging users on the forum
## Select the user from the list and paste clipboard contents into the forum
from PySide import QtGui,QtCore
limitToTopNUsers = 10000 #change to 100 for example to use only top 100 users (by number of posts)
dict1 = {'chrisb': '5646', 'NormandC': '202', 'wmayer': '69', 'yorik': '68', 'bernd': '2069', 'jmaustpc': '611', 'triplus': '782', 'Kunda1': '12229', 'DeepSOIC': '3888', 'freecad-heini-1': '2598', 'bejant': '1940', 'sgrogan': '4252', 'microelly2': '2364', 'vocx': '21943', 'openBrain': '22265', 'wandererfan': '1375', 'quick61': '2030', 'abdullah': '3232', 'jriegel': '67', 'looo': '2349', 'mario52': '1058', 'PrzemoF': '3666', 'ickby': '686', 'meme2704': '14145', 'easyw-fc': '6387', 'shoogen': '765', 'renatorivo': '918', 'paullee': '8738', 'GlouGlou': '5772', 'kisolre': '22435', 'r-frank': '1529', 'papyblaise': '25808', 'kkremitzki': '7997', 'Jee-Bee': '6234', 'ulrich1a': '1928', 'herbk': '4353', 'sliptonic': '708', 'Joel_graff': '14673', 'thschrader': '15166', 'TheMarkster': '19292', 'rockn': '681', 'realthunder': '12167', 'uwestoehr': '23505', 'tanderson69': '208', 'saso': '3305', 'Roy_043': '22936', 'mlampert': '10163', 'freedman': '19098', 'carlopav': '23005', 'Willem': '9760', 'Chris_G': '2561', 'keithsloan52': '930', 'GeneFC': '8180', 'roerich_64': '6075', 'HarryGeier': '15774', 'UR_': '12184', 'HoWil': '6222', 'hammax': '12483', 'freman': '22524', 'HarryvL': '18062', 'drmacro': '2867', 'bitacovir': '3136', 'Forthman': '19652', 'peterl94': '1819', 'cox': '4523', 'kbwbe': '19380', 'Zolko': '22794', 'reox': '9769', 'pablogil': '4517', 'HakanSeven12': '23711', 'RatonLaveur': '24547', 'ArminF': '11953', 'thomas-neemann': '29293', 'jeno': '3508', 'flachyjoe': '984', 'regis': '6401', 'Syres': '21041', 'ian.rees': '3449', 'pperisin': '356', 'ppemawm': '1807', 'mrlukeparry': '607', 'logari81': '270', 'fc_tofu': '29038', 'ezzieyguywuf': '6058', 'emills2': '5929', 'Dirk.B': '23630', 'vejmarie': '7506', 'eivindkvedalen': '1546', 'damian': '6134', 'jrheinlaender': '997', 'Jimidi': '15956', '-alex-': '23825', 'dubstar-04': '1642', 'Gift': '6611', 'Joyas': '3582', 'Bance': '5418', 'drei': '3278', 'cappy0815': '4130', 'Russ4262': '20523', 'r.tec': '4264', 'agryson': '11337', 'dcapeletti': '3651', 'manuelkrause': '20592', 'Mar': '3434', 'JoshM': '16808', 'teobo': '2833', 'schupin': '18259', 'jpg87': '13810', 'danielfalck': '689', 'makkemal': '5932', 'Fran': '16427', 'oliveroxtoby': '11950', 'onekk': '5245', 'bill': '5185', 'johnwang': '23504', 'leoheck': '19003', 'shaise': '6188', 'blacey': '7328', 'fandaL': '3658', 'fosselius': '8591', 'fran6t': '3600', 'herrdeh': '3918', 'nemesis': '2986', 'holdi': '11560', 'piffpoof': '4556', 'adrianinsaval': '19302', 'furti': '17491', 'f3nix': '6125', 'jreinhardt': '2072', 'chakkree': '6331', 'galou_breizh': '334', 'bavariaSHAPE': '3425', 'FaDa3D': '16107', 'jaisejames': '10269', 'apeltauer': '16146', 'plgarcia': '6249', 'Sudhanshu': '21878', 'fcaduser': '2823', 'jp-willm': '7776', 'Pauvres_honteux': '2803', 'clintonsam75': '3470', 'amrit3701': '9146', 'Claud': '18797', 'ebrahi': '21433', 'OldDraftsman': '16332', 'usbhub': '24632', 'efyx': '4074', 'jbe': '2330', 'kwahoo': '2441', 'JMG': '2538', 'lemonbug': '4228', 'Repman': '3536', 'koluna': '21576', 'polymer': '3974', 'joha2': '10551', 'david69': '2566', 'Moult': '23100', 'Roland': '6638', 'Konstantin': '3649', 'Renat': '3315', 'hobbes1069': '725', 'blonblon': '10279', 'user1234': '9411', 'oldmachine': '15343', 'wega': '2347', 'salp': '2409', 'Drederwisch': '11726', 'arturromarr': '15598', 'bgoodr': '3447', 'jruiz': '4299', 'arcol': '2320', 'garya': '22407', 'Sura': '21412', 'blue0cean': '23920', 'CharlieMAC': '3179', 'kaktus': '26846', 'Marco_T': '7564', 'lainegates': '1295', 'davecoventry': '2481', 'FC-Architecter': '19079', 'chrisf': '2578', 'ceremcem': '18069', 'ediloren': '1783', 'dxp.dev': '22713', 'pl7i92LCNC': '24265', 'jean.thil': '6498', 'qingfeng.xia': '6825', 'OficineRobotica': '23938', 'catman': '23210', 'kwahooo': '254', 'j-dowsett': '652', 'memfis': '11177', 'nahshon': '1973', 'cram': '11546', 'yoshimitsuspeed': '1337', 'freecadjam': '20736', 'HartmutG': '10744', 'gdo35': '858', 'ProBowlUk': '4171', 'HBC0': '6833', 'paul18': '3622', 'rentlau_64': '4246', 'AR795': '20058', 'heilo': '12525', 'hardeeprai': '255', 'Turro75': '9800', 'joel': '12631', 'Sam': '8192', 'Fat-Zer': '4325', 'Giuli': '9935', 'kanagan': '5980', 'M4x': '13711', 'jnxd': '5734', 'papy': '21427', 'S.N.A.L': '3080', 'Markymark': '28078', 'Renato': '5905', 'm42kus': '3911', 'freecc': '18704', 'TomB19': '25136', 'Brutha': '5971', 'TopDown': '20410', 'gsandy': '23521', 'Leatherman': '12789', 'un1corn': '7434', 'psicofil': '789', 'rynn': '20919', 'dimitar': '25801', 'a3bksll47': '19044', 'crobar': '3893', 'project4': '1944', 'wsteffe': '3846', 'industromatic': '2997', 'MaurinoWeb': '15573', 'nyholku': '12058', 'wvmarle': '4214', 'derschutzhund': '3592', 'sanguinariojoe': '574', 'MSOlsen65': '29727', 'Anderl': '17746', 'crashfridh': '1483', '1D_Inc': '23696', 'hhassey': '6158', 'ektus': '1283', 'Eric': '4575', 'ikua': '14240', 'japie': '3493', 'zbigg': '17804', 'C_h_o_p_i_n': '25037', 'clytle374': '2207', 'dan-miel': '21478', 'FemUser': '16291', 'Mongrel_Shark': '10595', 'Spindoctor': '6848', 'foxint': '7589', 'aapo': '22095', 'oddtopus': '10205', 'IzzY': '14602', 'xibinke': '5703', 'lot': '25410', 'jakob': '3595', 'jonasthomas': '873', 'schnebeck': '15579', 'ajoeiam': '24132', 'JiPe38': '28975', 'scrungy_doolittle': '20416', 'eason': '5803', 'KAP': '28935', 'kcleung': '512', 'Luixx': '18322', 'iplayfast': '27301', 'roivai': '12794', 'brjhaverkamp': '6838', 'prrvchr': '4119', 'Hannu': '6761', 'mnesarco': '30314', 'bbear123': '2465', 'cnirbhay': '9824', 'kreso-t': '20975', 'more11': '4079', 'alex::freecad': '3892', 'Wsk8': '22665', 'Galahad': '20671', 'heideachim': '18226', 'vanuan': '22024', 'aguseguedre': '535', 'frecd': '5116', 'Do': '11781', 'hds': '13102', 'babaroga': '9780', 'Jos': '31258', 'rjpeek': '7415', 'etrombly': '28581', 'Norus': '6964', 'rebeltaz': '24648', 'EkaitzEsteban': '21473', 'Koemi': '17917', 'NateM': '2390', 'django013': '5218', 'sibelius': '29023', 'm0n5t3r': '12818', 'jmplonka': '11876', 'albertdela': '16540', 'lhagan': '108', 'tom': '5727', 'Daniel84': '13510', 'Andr': '7655', 'bzb.dev001': '25224', 'm.cavallerin': '20120', 'DrBwts': '4281', 'Gauthier': '3532', 'Cyril': '16289', 'neondata': '1573', 'balazs': '4211', 'atzensepp': '5514', 'spikey': '7624', 'OakLD': '18151', 'waebbl': '21119', 'oldestfox': '1910', 'jmh': '4317', 'Linden': '6627', 'Xav-83': '3750', 'Lauri': '13429', 'andre': '2370', 'j9lemmon': '2018', 'Crossleyuk': '20393', 'iogui': '24401', 'mack5': '15924', 'falviani': '25270', 'godblessfq': '6436', 'mandeep7': '8229', 'Tilli': '18331', 'Maavhamt': '6189', 'ckl6767': '24834', 'capucin': '16725', 'onesz': '729', 'Opus': '17261', 'NC3D': '10606', 'ccccrnr': '698', 'Serchu': '5411', 'foadsf': '5587', 'dave_w': '30076', 'luggw1': '13046', 'tanj': '16319', 'murdic': '2856', 'jobermayr': '769', 'abasel': '21318', 'MrRossi': '11492', 'Enyalios': '13094', 'brst': '24863', 'Tamirov.ru': '23726', 'petit_chat_noir': '27642', 'zohozer': '3684', 'christi': '22009', 'jdurston': '697', 'Quaoar': '15966', 'dino': '4044', 'svenair': '4549', 'abcb': '23151', 'dulouie': '16780', 'mdhill': '14574', 'A_3': '7639', 'otoien': '16164', 'fcaponi78': '1007', 's-light': '5425', 'jcc242': '1017', 'Fantaspic': '11388', 'Routerworks': '19363', 'cadgiru': '10838', 'josheeg': '2362', 'magwas': '615', 'Thoma': '13437', 'IanP': '7957', 'Matael': '7975', 'serrepattes': '15169', 'BassMati': '21785', 'Cobraschock': '25890', 'helo10': '917', 'miniellipse': '19613', 'tomkcook': '9516', 'Bayesian': '26807', 'PunyTune': '23110', 'wafi': '10594', 'tilas': '717', 'ldboehm': '20298', 'carlod': '684', 'mfasano': '19405', 'dbecad': '19043', 'salatwork': '1044', 'hinckel': '4480', 'mrdic': '14954', 'mdinger': '2928', 'Magnum56': '19253', 'JOE_FU': '23194', 'micksulley': '19859', 'M3RS2': '20695', 'seppelw': '18203', 'mk2': '4637', 'nic': '24865', 'JLB85FR': '7593', 'dchigrin': '397', 'flowwie': '23494', 'jmwright': '3465', 'Rei': '8970', 'jacknotreally': '181', 'lambda': '13391', 'Piero69': '26052', 'David_D': '20509', 'DAP': '9480', 'gpmari1': '11120', 'doubters': '8165', 'Gustav180': '6328', 'hrhassan': '31926', 'sweepy': '13775', 'DaveGlx': '4332', 'maker': '19242', 'sodelo': '12583', 'kishore': '9122', 'roegel': '3782', 'angow': '779', 'hamish': '4408', '_taras_': '6417', 'IMback!': '26160', 'shinwu': '3908', 'froussel': '15460', 'fmluizao': '28364', 'Pascal': '13929', 'pPodest': '23873', 'tonyaimer': '27612', 'Ukacor': '24411', 'TT-RS': '4271', 'FATH': '15765', 'obijuan': '3679', 'lutz_dd': '3703', 'geolux': '25205', 'EdgarRobles': '6517', 'Tomas': '7799', 'archang': '3878', 'Boneshaker': '7905', 'hatari': '9540', 'rus': '13334', 'Chri1': '21908', 'Aleks': '30029', 'disenator': '4213', 'prandall': '13151', 'PAT64': '8949', 'AdamTimm': '7607', 'demackison': '4500', 'fester2251': '780', 'KgoaOT': '9484', 'cahlfors': '856', 'serviteur': '4419', 'kemeniru': '439', 'Ca': '4520', 'fmd14': '6662', 'darrenmsmith': '25371', 'whirlybomber': '2011', 'Moebius': '7796', 'jbet': '1126', 'ShurikMur': '6707', 'Johnquicker': '21100', 'SvenGoord': '23886', 'mmiscool': '11849', 'maggus': '2743', 'DeeJayOne': '27274', 'sandman': '2966', 'mindflow': '22351', 'ggcode': '15955', 'Badapower': '8291', 'amka': '6715', 'hokieengr': '12126', 'grandcross': '6949', 'freecadlzh': '30003', 'Sawfish': '3853', 'fjullien': '18209', 'twohot': '529', 'gbroques': '29296', 'retnev': '17745', 'shivaksingh': '14160', 'adamLange': '6083', 'liutas4x4': '9464', 'midgetfc': '87', 'tobaggo17': '5238', 'SupDoc': '27958', 'icare': '7109', 'silopolis': '10730', 'CkwA': '3982', 'Berci': '7836', 'Blumfeld': '17520', 'Henri33': '17862', 'momentumv5': '742', 'Tato3d': '24848', 'poserge': '5777', 'ryback08': '832', 'Danilo0702': '23597', 'Berser': '20335', 'Eagle': '6597', 'czinehuba': '21877', 'Eneen': '6581', 'manday': '561', 'Tripplex': '20600', 'jbi': '8611', 'Poppa': '19578', 'JulianTodd': '21998', 'ubit': '4910', 'Dex': '16697', 'wieszak17': '2621', 'Halfa': '7541', 'mafer78': '6854', 'eexpss': '12046', 'sket': '3276', 'tommeyers': '19016', 'flim': '19800', 'cline': '187', 'danreb': '19019', 'dammerel': '3759', 'Geraldhemel2': '3998', 'alberich': '16220', 'mad_max': '20513', 'diep': '2502', 'LotusChang': '3873', 'zacl': '26705', 'jumbo125': '27897', 'duk': '6049', 'vu2011': '701', 'ole84': '322', 'misterkeeks': '1352', 'lalberts': '7771', 'Rod': '7918', 'cad-gast2': '8704', 'fjaffre': '26169', 'Christoph': '9381', 'luuv': '2084', 'Gregor': '30570', 'felixlee868': '26041', 'DomiChi': '2975', 'the_document': '18028', 'bypbop': '7808', 'albertof': '235', 'jcf': '11165', 'kryptokommunist': '30335', 'robinh': '3209', 'JAndersM': '7413', 'brusk': '5465', 'Condor-2-4-2': '16547', 'xeres': '20521', 'h.tsubota': '8207', 'Lotharyx': '7906', 'dekoning': '4462', 'cflin': '15048', 'lelectronlibre': '28031', 'mpetrasinovic': '29784', 'tryer': '6702', 'Georg99': '4382', 'peepsalot': '735', 'Celica_Supra': '22176', 'laurent_parti': '2861', 'psi13art': '344', 'business_kid': '15574', 'Sanguinario_Joe': '2564', 'federico.carminati': '15114', '71GA': '14043', 'JeffWitz': '5714', 'yves78': '4521', 'Robavh': '3838', 'djreichel': '908', 'joancabeza': '19271', 'roo': '16003', 'gflorent': '21049', '18turbo': '6731', 'mpyusko': '516', 'antoniovazquezblanco': '3050', 'geobruce': '19970', 'überfuzz': '7792', 'elsordo': '7721', 'tantle1961': '12016', 'ian9toes': '20230', 'soaring': '12129', 'julianfoad': '5989', 'topcyde': '2880', 'flopsy': '7942', 'claus1982': '2971', 'JiriVALASEK': '24857', 'Chaospilot': '22486', 'FreeRadical': '4396', 'raback': '31306', 'terok': '17808', 'lota': '17987', 'toralf': '25178', 'marktaff': '4033', 'c-m-burns2': '1405', 'TedM': '30824', 'benjaminwharton': '24013', 'simsiem': '7742', 'ifohancroft': '25644', 'lesept': '19326', 'volodia': '19505', 'RickDeckard': '18194', 'electronlibre': '778', 'edi': '29214', 'Dekonstruierer': '15592', 'Mika38': '13015', 'nvivier': '172', 'mangtronix': '3132', 'SBW': '4651', 'Doug': '13425', 'marmni': '2444', 'JoshuaCall': '28753', 'dpettegrew': '23764', 'anatolli': '19728', 'ceving': '16604', 'hooshsim': '22205', 'josegegas': '13017', 'shIxx': '19183', 'Alex68': '9367', 'Yinameah': '5412', 'splineman': '283', 'andrigtmiller': '7704', 'jidoeuf': '5539', 'l-m88': '207', 'otto9F9otto': '19334', 'kryscosne': '7982', 'tööö': '25907', 'ljb': '21357', 'q_9': '27607', 'tcs_ulrich': '16343', 'linuxer': '4258', 'gege81100': '28175', 'idfx': '7868', 'berka': '6645', 'Mod77': '30880', 'fiffo': '16957', 'AvgJoe': '4099', 'leeon': '24252', 'pi': '24093', 'engdham': '20709', 'sjb': '14640', 'Olav': '11423', 'rikblok': '13456', 'Cyber3DK': '13569', 'iari': '2396', 'Laurent239': '6845', 'myier': '320', 'wieszak': '1108', 'wearyhacker': '19962', 'Schlaui': '22624', 'vmzsoft': '15878', 'Worufu': '7577', 'zorglub44': '17977', 'JV_3D': '11943', 'DevJohan': '3589', 'netnico': '5713', 'svbol': '28639', 'Frankq_it': '7497', 'AwesomeCronk': '21651', 'cristian.a73': '20755', 'JCR84J': '19013', 'mancunia89': '4177', 'FBXL5': '26761', 'flamel': '15506', 'hobbyman': '23689', 'Manachero': '27347', 'bstanard': '5302', 'aj5robinson': '1029', 'nokian': '10134', 'Escain': '6950', 'rmu': '16039', 'blindmessenger': '22607', 'CarModeller': '23596', 'wbeppler': '19087', 'Manja': '19264', 'Mik': '7951', 'cedric': '9141', 'ewok2': '24009', 'julieng': '22492', 'Stou': '23002', 'PedjaS': '29229', 'bob.': '17666', 'tryomph': '5321', 'ABeton': '27254', 'Lohengrin': '8153', 'Anam': '13884', 'grandson12': '5499', 'clel': '9142', 'M-Rick': '3854', 'CoderMusashi': '22406', 'kuroshivo': '5073', 'revolt_randy': '6242', 'cadcam': '30470', 'ElMastro': '25581', 'surfin_eddie': '1388', 'clarkitect': '6806', 'balrobs': '30989', 'AIMEDSOLUTIONS': '21324', 'Geoplace': '24051', 'Chrisso': '27676', 'REl': '29797', 'misterwazlib': '17591', 'F_Rosa': '7885', '9alfred99': '11400', 'Wompoo2': '3370', 'Bil': '4005', 'rassi149': '6982', 'sp9rqa': '18116', 'TLS': '5842', 'jhasler': '4511', 'HurdyGuigui': '2721', 'Peter_D': '31742', 'FCuser2019': '27385', 'MrMaker': '6612', 'Darktrax': '4225', 'robertmain': '28086', 'Lookid': '21476', 'jeanlouisquero': '10061', 'beamer146': '2419', 'mrtaotao789': '16463', 'griffmic88': '18885', 'MMSN': '3368', 'freecad-heini': '1124', 'Grey': '11456', 'bfeist': '11872', 'Gandouz': '31400', 'Funag': '16978', 'Tandy': '21754', 'SIG': '4003', 'chrisw': '5635', 'giostark': '21901', 'inform': '2404', 'kenrinc': '3828', 'tukan': '24004', 'ollydbg': '8395', 'schloeri': '8554', 'Dempsy': '13065', 'Matthias70': '16411', 'iwbnwif': '13354', 'l3VGV': '27774', 'burtbick': '9203', 'lawrencek': '26180', 'pat_oneil': '6241', 'Sidemountyucatan': '24853', 'polemidis': '12978', 'emills': '826', 'vinbai': '15157', 'ASenger': '11460', 'mendy': '19994', 'EinmalAnwender': '21182', 'anwend-gast2': '685', 'ubiquity': '17193', 'Uerdingen2263': '18688', 'iyd2019': '27812', 'mumme': '6279', 'woodbuddha': '2589', 'paddle': '29478', 'E': '2688', 'shaynox': '9724', 'csanyi_pal': '655', 'ov10fac': '28495', 'billfromnet': '19863', 'dlhenke': '13971', 'ooveif9': '19112', 'satheesh': '8793', 'jl-mando': '17478', 'naeco': '9849', 'tsadowski': '5270', 'masterkorp.alfredo': '5144', 'toolman': '3347', '2cv001': '28971', 'hughthecat': '932', 'marcxs': '1047', 'Rol38': '23846', 'Tilarta': '26829', 'WayofWood': '22497', 'geant': '5739', 'Harry_D': '6365', 'vectronic': '18665', 'freecading': '6143', 'axk': '2685', 'M': '27826', 'Epy': '2317', 'Shack': '15578', 'slc55': '1564', 'XXX': '8236', 'Looktree': '4594', 'JellyPalm': '30355', 'trezvy': '5294', 'bodisey': '7345', 'Motte': '13792', 'zoidberg': '2395', 'craigjl62': '1555', 'Geeks': '3677', 'MarkkuTM': '17957', 'montagdude': '23163', 'FreeMake': '24397', 'phil16': '7945', 'jairds': '1679', 'Stonefire': '23710', 'gneiss': '24154', 'jrdrukin': '22468', 'romartin': '4342', 'gunther_alfred': '5307', 'randy19962': '7092', 'jahwobble': '27491', 'Pierpaolo': '8329', 'danidr': '9914', 'GLEN': '11522', 'miguel': '3062', 'jmr': '18534', 'multitrain': '32274', 'vectro': '15654', 'neo2001': '27922', 'TonyR': '19452', 'MikeDewitt': '30962', 'martin51': '31201', 'yellowhat': '5046', 'Budd': '27204', 'loz': '2498', 'Jaso': '8763', 'Walgri': '6003', 'Ghostonback': '28265', 'umardastgir': '24954', 'h.dale': '3818', 'ConneR': '21669', 'Runk': '23025', 'eggy': '6510', 'tak': '25149', 'baltic': '27365', 'practical': '27850', 'akredd': '2954', 'a179308': '21742', 'ajawamnet': '26658', 'leong': '8440', 'highfellow': '9633', 'BlaiseDarveaux': '19812', 'tynlizzard': '8034', 'cemoi': '8256', 'samiam1000': '16816', 'glockpod': '15233', 'alafr': '29231', 'aster94': '27953', 'Dominique': '33626', 'rider_mortagnais': '4161', 'jonnor': '5506', 'malinand': '111', 'blubee': '15523', 'franck76': '8330', 'GrantRobertson': '19977', 'andykirby2': '2295', 'however': '3045', 'CADennis': '14444', 'kc79': '7204', 'SpaceCAD': '7603', 'xav83': '775', 'PiotrG': '28458', 'squaretoround': '4345', 'Tandini': '9393', 'denisnooby': '27685', 'ivanzero': '859', 'Markqz2': '2710', 'amarao': '21670', 'Diegis': '6136', 'unfa': '6226', 'samurai76': '7816', 'prius06': '21207', 'frankleng': '6193', 'dmun': '15457', 'ShapeShifter': '3539', 'H': '30887', 'normads': '1441', 'dam5h': '1574', 'Scalpel78': '3769', 'fafc': '6452', 'fly71': '9234', 'sdaau_ml': '22661', 'lorenz': '8146', 'Henning': '15111', 'alonso_jamm': '28210', 'streken': '941', 'W_klus': '31096', 'FreeCAD97990': '15673', 'FreeCAD91': '12009', 'emptyspace': '12153', 'zach': '24667', 'Leviathan': '17114', '__Vinz__': '9923', 'bhs67': '5322', 'jpmartin': '5070', 'thuswm': '1065', 'ppd': '24042', 'luispa': '3687', 'hlg': '26149', 'thebeav': '6650', 'Opaxtl': '15694', 'ariel-co': '559', 'augur': '32643', 'franzengel': '1085', 'massimo67': '11390', 'benoitlst': '23313', 'naxq0': '19621', 'mitu7362': '28713', 'dre99gsx': '2149', 'YeeP': '17024', 'ronindev': '4542', 'markk': '9723', 'thoraxe': '33572', 'robotMarvin': '12912', 'Petert': '7290', 'RobertPHeller': '32230', 'hholgi': '21563', 'bitminer': '18680', 'oly': '13252', 'francis75': '4048', 'josemaria': '19466', 'mark1791': '20956', 'pilou8830': '26176', 'leonpiper69': '1974', 'Ricky1966': '21280', 'dingolino': '29604', 'shiftee': '15770', 'AMax': '16794', 'fusan': '11482', 'aleph0': '7716', 'DanaK': '22525', 'Yes_Papa': '5308', 'AshAsh': '22705', 'vrytar': '1404', 'boelle': '16412', 'Sinclair': '8345', 'asdaf': '21972', 's7726': '2727', 'TomF': '18947', 'eslavko': '1736', 'vesema3': '25105', 'Will2': '8666', 'Wilson': '20694', 'eudoxos': '9504', 'lah': '11153', 'routalot': '21610', 'Califax': '28293', 't86951': '3335', 'Baritone': '9604', 'pauluzs': '24071', 'RogerK': '21760', 'yohplala': '71', 'basmati': '28028', 'Realperso': '20623', 'rweilert': '30723', 'tobycz': '9571', 'Gar': '6116', 'derei': '7384', 'Antonius': '25123', 'tpavlicek': '18065', 'mrrclb48z': '18498', 'tiger': '18674', 'grooveman': '26066', 'chenkianwee': '284', 'liongate': '2394', 'Stéphan': '18468', 'kevinz': '27862', 'nicokid': '7078', 'Blue_Ice': '2527', 'marcus': '2553', 'kefir': '3655', 'Thierry': '3392', 'akeyokey': '13186', 'patn': '21594', 'hdbondt': '15747', 'tino': '24498', 'Abraham': '7781', 'pgood': '11190', 'Stefan_L_01': '7769', 'vcfbauplusfe': '22573', 'bvx': '29049', 'common': '29361', 'MIngB': '12681', 'fredko': '4645', 'tombrown19': '551', 'SIXe': '24351', 'bobfredo': '22134', '7ofNine': '9948', 'Лапчатый': '23256', 'Kjetil': '26702', 'SchmilBlick': '5183', 'sanderboer': '27188', 'rophys': '750', 'brucehvn': '21059', 'soloquintett': '26099', 'boreilly': '19410', 'blazini36': '19522', 'hdt551': '28372', 'NCCALCADA': '24847', 'Johanneshov': '3238', 'weasel_face': '9722', 'ezroller': '10479', 'fdomateu': '19942', 'Nathanael': '2659', 'p3d': '2948', 'jgriessen': '240', 'bricechart': '3391', 'EnigmaVoidX': '30414', 'holzjunkie': '16803', 'earthcare': '9004', 'awkonradi': '18422', 'stemby': '486', 'apalazzi': '781', 'Peter': '4425', 'YCStone_': '8754', 'felix': '2307', 'calculon': '17190', 'sol1d': '17238', 'marcorhino': '1422', 'derek-v-s': '25255', 'Rudl': '17287', 'Reynard1066': '31335', 'quirxi': '2032', 'davitof': '3996', 'jrporter': '4168', 'bleber': '9324', 'mll123': '1335', 'michav': '27325', 'Cywil': '5838', 'Lou_Papet': '3764', 'davdue': '5311', 'douardda': '2801', 'lbowers': '25704', 'Grawp': '18853', 'jhademenos': '19174', 'wconly': '25654', 'Andrea3': '17169', 'BackEMF': '3206', 'bigwebs': '3581', 'drayko': '1106', 'rhombus': '27481', 'AndarionCG': '2788', 'mkey': '21002', 'tday': '3411', 'Rene': '5595', 'donjan': '15557', 'fedelop': '9562', 'gooogor': '1212', 'free4one': '7251', 'PMac': '16406', 'dculp001': '7926', 'SilasHoff': '25974', 'carlos420': '1028', 'jjsca': '940', 'steeveosteen': '1446', 'nzurbrugg': '2536', 'Arnold': '17368', 'lidiriel': '28821', 'wangyh9098': '3758', 'DjangoFreeCAD': '23013', 'tempr': '3164', 'Vert-Ex': '28984', 'graymalk': '3464', 'walpa': '11067', '-=SpV=-': '24141', 'emoreira': '23909', 'Juyam': '3907', 'usertogo': '22915', 'derep': '32777', 'justacec': '15887', 'franck67': '16384', 'shootquinn': '2711', 'purehunter': '25547', 'CuriosityMan': '22780', 'eds': '13281', 'emmdelage': '536', 'G-VAR': '12050', 'mnc5': '17252', 'lblabr': '17157', 'sjam986': '31387', 'lucrol': '18938', 'sawozny': '6692', 'M_W': '25363', 'Hedaa': '25958', 'kir': '5382', 'CPE': '10993', 'KlausMerkert': '13922', 'MarmotCAD': '7880', 'doctek1': '5207', 'Ramses': '21675', 'crownfield': '21707', 'babyrisa': '5741', 'rainharvester': '22357', 'howetuft': '27349', 'yagoyago': '1135', 'maito78': '7947', 'Lazlow': '30054', 'asker': '21390', '111': '26074', 'jg847': '18298', 'Genues': '28998', 'maebaq': '29431', 'tk5ep': '16584', 'MarvinK': '4287', 'Bibi': '4363', 'davec49': '694', 'kazan417': '20036', 'StarBootics': '27600', 'tux': '6261', 'mtsinc': '19605', 'MarcX': '17505', 'Mx74': '17633', 'jp2112': '6084', 'miscjunk': '3934', 'openfablab': '10949', 'SparkyCola': '15318', 'Santamaria_13': '13478', 'thebighaggis': '30743', 'Di': '26787', 'Fdancad': '10426', 'DavidGoodenough': '4576', 'trevelyon': '22931', 'Be': '18929', 'Darcad': '18977', 'sps': '16381', 'jio80': '21348', 'ThierryM': '2875', 'solosails': '18673', 'jerrill': '1173', 'Cpl_Detritus': '25085', 'DrMorgenes': '3984', 'Galane': '5664', 'bgma1961': '19252', 'putzwasser': '33149', 'didencool': '1249', 'mdjurfeldt': '15407', 'iarza': '21046', 'cattin6': '28251', 'remizik': '23702', 'Ben2003': '21641', 'qurn': '21833', 'ericg': '3599', 'abielecki': '19257', 'elucches': '1255', 'Hans_K': '16036', 'MSchet1978': '29878', 'stephan_g60': '13283', 'racemaniac': '28498', 'nquantum': '20955', 'danilius': '3412', 'Vido': '17493', 'marcuswolschon': '2117', 'Jolito': '34893', 'shahram10715': '24894', 'vikas12': '300', 'fcaponi': '5642', 'BobSharp': '7199', 'greyltc': '7583', 'marcvs': '2815', 'flokart': '8418', 'HarleyHarry64': '17003', 'greg_b': '10379', 'DeltaFoxtrot': '12379', 'Robocut': '3516', 'fritz1': '9949', 'logiclinux': '199', 'friv': '23205', 'rradler': '23650', 'leonjobs': '2461', 'Marcel-B': '4285', 'Dacord': '4381', 'janeks': '5132', 'iKWI': '19187', 'Redtag': '28217', 'Stubbs': '8852', 'Karlo': '3947', 'ruchg': '10942', 'FreeCAD-L': '30391', 'nezam': '4919', 'pekkio': '15489', 'einherier': '23896', 'gAdlike': '17153', 'Accessdenied': '29317', 'maxlem': '26468', 'ClaudeG': '19752', 'chri': '13588', 'telson': '5282', 'domad': '33963', 'ramFCnet': '5976', 'Taylor': '28671', 'tfcb123': '8453', 'Shlomo': '18876', 'jureko': '28027', 'dvdtgravwe11': '2120', 'Uwe': '7805', 'Rolfi': '11756', 'beamer145': '2095', 'deavik': '2654', 'TimWescott': '5109', 'patrick_83': '27909', 'Dreamim': '15660', 'yclee126': '15868', 'Win': '17436', 'flolli': '77', 'rjburner': '5627', 'fracinq': '32125', 'InTheDark': '7934', 'hajduk': '13021', 'parade': '27512', 'brucethepirate': '5820', 'jsoo1': '23587', 'jamesl73': '1892', 'R23D': '29332', 'bieber': '26083', 'Gra': '22173', 'Jochen': '6119', '3': '11343', 'DavidNicholls': '2840', 'dccharacter': '7124', 'joaopcrodrigues': '21720', 'anna': '18019', 'andré': '5593', 'venche': '17747', 'craig9': '19113', 'wil': '23520', 'rosparovac': '19561', 'ttype': '1832', 'Artem_Zh': '16804', 'bricofab': '14212', 'hautamecki': '1006', 'mdelore': '4009', 'RobertHK': '2700', 'BrianEV': '12486', 'nmt': '13254', 'Michu': '10439', 'turri': '494', 'Chairy': '2939', 'revolver1941': '3900', 'magnet': '9361', 'scopaev': '580', 'charles1954': '27821', 'mario.silva.costa': '14969', 'jake77': '23323', 'Sami91': '24539', 'haonk': '25697', 'ercmrj': '4592', 'Grue': '10714', 'jtidwell': '29257', 'GeoffG': '23051', 'Misterlion': '5764', 'rasomei': '5946', 'akotowski': '29383', 'villager': '16476', 'AhmedER': '13868', 'Shinich': '18400', 'dh9ts': '22578', 'pperrin': '12412', 'remcat': '25137', 'Thearod': '15438', 'giorgoss': '2413', 'axkibe': '29261', 'tekuehne': '27124', 'cwstirk': '2464', 'garthhh': '309', 'harlekin': '6027', 'TimOdell': '6355', 'Bojan_Bekic': '23686', 'Embed': '6410', 'ChrisWesley': '17393', 'Dav83': '27829', 'free-swallow': '29299', 'rbsalyer': '16594', 'penneng': '27567', 'alexis': '15410', 'wima': '29112', 'cappu': '21194', 'teus': '26692', 'alarke': '5488', 'White_Fox': '19192', 'swat_01': '6584', 'Pettter': '24467', 'engraver': '3334', 'frankbuss': '25515', 'Gurbhe': '21659', 'erlin': '9295', 'st_phan': '31506', 'David.Boettcher': '5955', 'cl781121': '1051', 'Murmele': '13716', '_cyclops_': '9709', 'studioa': '85', 'pingplong': '7055', 'gauna': '7314', 'bernard_01': '24484', 'harsh': '12564', 'Laurent31': '20923', 'mr_cg': '13013', 'rmavrichev': '28544', 'imarin': '15856', 'harpo_bzh': '2420', 'JGS': '29281', 'DarkPhoinix': '25160', 'Raptor4': '4383', 'spontarelliam': '27141', 'Taufeeq2': '19222', 'terrymorgan': '2422', 'mrcshh': '5078', 'franck606': '18372', 'vdbehr': '1943', 'moggie': '7444', 'edward_silicon': '3061', 'S-Y.Chen': '27160', 'kb1gtt': '6808', 'javeh': '2805', 'evgeny_magata': '3895', 'JurgenG': '5578', 'jr22': '573', 'Mishich': '23402', 'DomCa': '28111', 'claus007': '2469', 'invent': '20505', 'Naifu': '25623', 'elsacramento': '5616', 'Alexand': '24115', 'getSurreal': '2901', 'pat': '16549', 'Packmers': '20939', 'j2l': '30955', 'lena22': '27348', 'laurentparti': '1791', 'Zhukovgreen': '11733', 'ricorico94': '21277', 'JacktheRipper': '25812', 'AnTeBiOs': '5337', 'merlin63': '23183', 'ouinouin': '7059', 'DingBEN': '24297', 'aga': '15976', 'gspeed': '16680', 'MatCAD': '3230', 'pouic13190': '4240', 'gdurrens': '31994', 'HardRock': '18990', 'orxshi': '28789', 'fillet': '7770', 'prshah': '8066', 'Lorenz': '8213', 'Thomn78': '8534', 'pinniped': '1096', 'Generator': '6997', 'm0s1n': '3285', 'ppvernhout': '5087', 'Gwen': '18430', 'Fra88': '18944', 'Das_Sams': '23839', 'exmerci': '28896', 'diepchess': '2144', 'steve49suzuki': '2852', 'Mhoame': '17115', 'sergiobini': '17435', 'bhorton111': '831', 'PommesCreek': '28501', 'kaktus018': '19901', 'wisenwild': '2000', 'behn66': '11927', 'Chowderhead': '8840', 'niconol': '21408', 'PepperSoris': '17705', 'saeppi': '18075', 'Macer1902': '31320', 'csm': '28604', 'tyszja': '24739', 'dnyberg': '3265', 'Troymx576': '31131', 'ignacio': '8081', 'prusa3di3': '9712', 'viralata': '5372', 'Raph82': '5404', 'markolinux': '27538', 'Sag': '3773', 'marzof': '14552', 'jouke': '14914', 'ehb': '6048', 'threedbb': '1156', 'jesito': '6487', 'ghislainvdwalle': '7903', 'tv05': '30150', 'iszczygiel': '22334', 'hjh': '23024', 'sirpete83': '15349', 'Matti03': '30734', 'bestfit': '21836', 'Georges': '5671', 'karpeski': '5756', 'swosho': '660', 'pa4tim': '3120', 'Renaud330': '16806', 'Soralius': '3880', 'epileftric': '17847', 'nemetken': '2089', 'gauthneo': '17929', 'davidinsc': '1607', 'BigLebowski': '25041', 'daboga': '30309', 'MrDark82': '3919', 'JoeB': '17449', 'sandy': '5181', 'alovicious72': '27369', 'robin.jonsson.4276': '27854', 'CMT': '23461', 'Chiefy': '2635', 'noobdude': '20703', 'AndrewCSP': '25663', 'Michel59263': '26263', 'silent_missile': '26679', 'renne': '27438', 'ManB': '10506', 'nigec': '6204', 'Le_Loup': '19344', 'rd35520': '8680', 'Bjoern-S': '17724', 'stadtbahnzug': '10010', 'rainbowhope': '28573', 'Tom1': '15995', 'Syranolic': '9515', 'siggio': '9926', 'daddyzaur': '32618', 'juless': '24991', 'torrincore': '20677', 'urg': '8036', 'kohnagha': '22898', 'maegras': '386', 'butchwax': '861', 'rowan.bradley': '20038', 'carlod3': '2372', 'robster': '8307', 'matthewutter': '6028', 'Smoshie': '2590', 'kabu': '9664', 'gcbsourceforge': '1105', 'whitakerp': '1252', 'andykirby': '1989', 'silas': '20184', 'RoCNC': '29927', 'PeterSprQ': '13330', 'tremblou': '340', 'dmisvik': '424', 'philburgt': '6672', 'juanvanyo': '11666', 'SandUhrGucker': '8772', 'tippex62': '5081', 'maxi.mep': '33729', 'petefromtn': '1855', 'GigiG': '2808', 'rayhall': '13236', 'larsen': '5707', 'ypsilon': '18907', 'CyberGolem': '20027', 'goingalong': '2631', 'DaQue': '3660', 'kenr': '4411', 'SebLiss': '5830', 'razor49': '3192', 'cyberlacs': '20989', 'yodi': '8509', 'Schorsch': '25877', 'emagdalena': '667', 'nop123': '1427', 'Trenien': '11481', 'Rathan': '6760', 'Jenjack': '35256', 'CraigCu': '7538', 'abrosimov-a-a': '25779', 'Patola': '9674', 'zappl': '726', 'chrisond': '23559', 'maxagaz': '19694', 'sangrampp': '2065', 'Francesco': '17786', 'theoryshaw': '3381', 'tcurdt': '30259', 'NT4Boy': '3977', 'timthelion': '5165', 'schmusebaerchen': '555', 'Jo': '19617', 'nhg100': '2567', 'CADBird': '12155', 'binoyte': '25278', 'elocevets': '1144', 'Ave-5D': '19586', 'Giovann': '26928', 'velociraptux': '12690', 'm3atwad': '9254', 'DoubleHP': '13570', 'Damnax': '9782', 'HumbleBeauty': '27195', 'din743': '1284', 'pro2311': '20201', 'Edgecutter': '9890', 'bocheverovsky': '9961', 'tarek': '18647', 'wamba860_8': '27730', 'Ed': '23456', 'doug1272': '1675', 'Orngrimm': '6929', 'HiFiJ': '24206', 'Fanta': '2510', 'peresthayal': '25002', 'glabifrons': '21035', 'luvres': '8671', 'MacDony': '9029', 'banankerdi': '5888', 'daaan': '27867', 'iccha': '1515', 'OliWee': '15606', 'steve.white': '3245', 'gobban': '25655', 'yeKcim': '4269', 'stanislau': '4366', 'cbk': '19303', 'Laurent14': '23552', 'Tinkefu': '23590', 'ycstoyou': '1829', 'o0l10': '2049', 'Jim54': '2644', 'Dr_Froggy_rD': '7727', 'Feuermurmel': '23794', 'rachdatu': '15571', 'hanslammerts': '6730', 'the_m3rovingian': '24747', 'Isabel': '20454', 'tml': '7780', 'csmith': '3451', 'Botoni': '8565', 'amarilisppt': '24713', 'mowijo': '7591', 'johanh': '30775', 'bennn': '9525', 'easyw': '1559', 'Paolob74': '2972', 'ripacheco': '7863', 'Lumaja': '4314', 'joelholdsworth': '576', 'nonlimited': '767', 'engral': '1605', 'tueftlerwork': '2062', 'mariusz.dec': '7491', 'KW91': '16968', 'Ja': '17032', 'shermelin': '30257', 'medju': '4446', 'barbacane': '22083', 'EldeTabernas': '22199', 'peterkegels': '5021', 'storerkeeper': '14920', 'Jacko': '27979', 'langstracht': '26822', 'mcemp': '27544', 'rubylion': '27578', 'mihe': '18898', 'sergeysn': '5895', 'MooCow1988': '6062', 'bronson': '6665', 'alexustinov': '7018', 'SamMallinson': '2366', 'sclaes': '7700', 'matthyuz': '16557', 'Dorantor': '21108', 'Seri': '3706', 'nazal': '8905', 'Low': '17983', 'messor': '22826', 'nicotuf': '103', 'FreeCadUser': '5896', 'jrtonkin': '3108', 'Moonchilde': '3289', 'wynn': '13597', 'benc': '31580', 'Seonaxus': '5430', 'chrisb123': '259', 'dmaz85': '6390', 'Meru': '21254', 'Renegade78': '30581', 'VonKrolok': '9636', 'MostlyHarmless': '18001', 'hening': '16240', 'Nico': '2913', 'Kd0afk': '4101', 'arauchfuss': '800', 'mdecarolis': '24583', 'catcher': '16929', 'flyfish': '25582', 'himbeerhacks': '22513', 'FreeCADNeuling': '5416', 'twinchip': '23398', 'nilsholga': '33134', 'SemrE': '19655', 'Johnathon': '7079', 'callisto': '20071', 'JackB': '20519', 'Sirios.77': '3431', 'santacruz': '13617', 'wpattison19': '5399', 'realwheel': '5667', 'theunnamed': '6157', 'Fredo': '16099', 'mjrich79': '12066', 'Rihab': '29284', 'gozlikehell': '29355', 'efferre': '20552', 'Dan-K': '21386', 'Witu': '31106', 'robcad': '18582', 'Tooniis': '18646', 'jukkaaho': '185', 'erikevenson': '934', 'Bourgeois62': '6282', 'Lars': '19768', 'KOLANICH': '7666', 'MOS88': '3433', 'grijo': '26106', 'spilz': '9442', 'tomerp': '18006', 'dyleks': '18583', 'expart': '425', 'buick455': '1658', 'joergfreecad': '24387', 'Elko': '17612', 'johan': '11467', 'lemoineo': '22999', 'WalkingShadow': '5678', 'hsnam': '28232', 'bxabi': '7259', 'totyped': '29260', 'shredator': '7811', 'indrek84': '21124', 'Steveco': '21284', 'Blunt0': '25768', 'oldstairdog': '4098', 'berti': '9224', 'hreintke': '27597', 'Amadeus': '10797', 'maidenone': '1084', 'SimonH_freeCAD': '28408', 'gillesfouca': '1525', 'yhw-miracle': '29021', 'neuhaus': '29037', 'Grumot': '2894', 'audispkt': '3183', 'madeskjet': '4032', 'alan2': '13542', 'jeneilaszlo04': '19916', 'DaveGray65': '15863', 'icero': '2139', 'Rammsteiner24': '24381', 'Newbie_German': '12150', 'Lynn': '2792', 'mickele': '9032', 'joea': '30993', 'FelixCA': '22235', 'andrew.j.smart1988': '16425', 'bountyCAD': '21344', 'micCAD': '25945', 'luemmel76': '9364', 'ffvpor': '10072', 'dima8101': '14777', 'hemuman': '465', 'TomV': '11256', 'Weeve': '6514', 'sunggus': '20527', 'nikhouse': '13946', 'old-flyer': '23032', 'beaker42': '814', 'Ditschelping': '18497', 'daur': '20851', 'Kailee71': '30077', 'gbgb': '3612', 'ascaron': '25651', 'to-the-nth': '4117', 'Theo': '27157', 'nurmili': '22967', 'rahmanshaber': '27634', 'joerg0606': '11438', 'koin3D': '34543', 'mzagozdzon': '18712', 'padawan': '33116', 'Narcissus': '20842', 'ducapaso': '8164', 'eduhono': '16949', 'Lehmeier': '8654', 'bliepp': '21660', 'anishkgt': '33030', 'rammstan': '23610', 'PaulWray': '20043', 'fyve': '2666', 'JayKay': '7534', 'mrwusel': '16502', 'callmesteve': '8007', 'diiity': '9340', 'PlaneAnimal': '22097', 'MARCO_GIACOMINI': '22449', 'homulus': '10261', 'blackdrum': '3029', 'Bernard': '13614', 'virgodave': '6840', 'Samuele': '6900', 'AllVisuals4U': '15903', 'jacquesclouseau': '9395', 'SBlade': '31153', 'mviljamaa_': '2334', 'psolyca': '12207', 'eegrek39': '22124', 'insomniux': '26743', 'BJF': '6448', 'uuykay': '19894', 'Glurth': '21113', 'neophyte1': '30338', 'VanderBuggy': '26035', 'pgnd': '28307', 'echo': '6749', 'Vagulus': '35139', 'Radi38': '29129', 'torvictech': '29480', 'ionos': '10375', 'mune72': '786', 'mths.': '15288', 'masazz': '1291', 'bobhund': '24118', 'n1k0l4': '7928', 'giuseppe': '30189', 'nicolas_buonomo': '30205', 'Steban': '21311', 'jenjaaaaa': '26127', 'djwho': '440', 'Demokrit': '23375', 'szekelyisz': '945', 'tux-lab': '971', 'BrianC': '6239', 'dinodelfavero': '1729', 'Robb': '6974', 'DanielS': '20576', 'DareDevil73': '16507', 'ReggaeRoy': '8215', 'davidwowa': '17083', 'fredericleuba': '30176', 'nil.parent': '26805', 'bottlenecks': '5624', 'Ade': '27700', 'sayluv': '2070', 'pabloskimg': '7697', 'Destroy': '12651', 'sam57': '8361', 'NerdWorld': '3627', 'neodelphi': '17292', 'Kabo': '17532', 'sicivic89': '839', 'astirfreak': '32913', 'Talika': '20226', 'spacether': '2548', 'comeinandburn': '12220', 'OldGuyInTheClub': '8254', 'jalapeno': '3575', 'philem': '8969', 'putz182': '26199', 'marcalpv': '4782', 'Msegade': '11229', 'bangar': '1664', 'sicofante': '1757', 'moonman91': '2009', 'Alex_2643': '2604', 'fehrenbach': '4229', 'rnwest': '21893', 'GrannySShifting': '31151', 'Sven178': '9814', 'axos88': '27704', 'dongdongqing': '6005', 'microartisan': '19123', 'stonecookie': '28460', 'djalfe': '7225', 'Decimal458': '24745', 'max6919': '25786', 'orc101': '9459', 'jthibaut': '31888', 'sterna': '5949', 'Eri': '19300', 'carmojos': '1590', 'willa8004': '2178', 'piter42': '29387', 'Mark_OS': '16976', 'JamesMarine': '25511', 'Francois': '25653', 'plopiche': '13199', 'lfvrchris': '22123', 'waynegramlich': '14624', 'beluga': '5612', 'semmy': '6465', 'TRS-80': '28883', 'SebastianM': '16369', 'Hale': '20630', 'goffi': '5398', 'Manue': '18886', 'myth': '5952', 'atalanttore': '347', 'mischael': '11352', 'crilex': '15513', 'CarloGreen': '19934', 'Joan': '7236', 'Zig_mint': '23186', 'Celtix': '7013', 'scons': '2671', 'dliess': '20879', 'outchips': '21281', 'DREKE': '26112', 'rudi48': '14154', 'eddriesen': '26965', 'Esprit': '14218', 'jswild': '13703', 'mmarre': '4239', 'Chris128': '10022', 'Nilix5': '10038', 'zumer': '10297', 'aueb': '27255', 'Tomete': '18702', 'ricardortizcoronado': '20111', 'nikjen2': '2704', 'randy.heydon': '2813', 'Mikeo': '5301', 'Utopietester': '14661', 'phidelf973': '5723', 'kridhond': '10932', 'mwilding': '19354', 'WhiteShadow': '28381', 'grautvornix': '15541', 'R-INYURU': '20234', 'annoyed': '16325', 'oldsphere': '7711', 'fab': '14310', 'markus23': '31875', 'dgvirtual': '27501', 'WhiteHole': '19067', 'seb_kuzminsky': '891', 'ImpressMeZosk': '6304', 'mikkamakka': '23762', 'michmerr': '16214', 'Oliver': '7671', 'dsaiko': '12438', 'roberto52': '16583', 'MnCAD': '8026', 'rothloup': '3881', 'Bassta': '30716', 'Cambriabill': '14647', 'bhm': '6933', 'JoeBuster': '7177', 'Badger': '2359', 'ehrichweiss': '7693', 'NeilBaker': '25419', 'mac_the_bike': '26010', 'ranska_': '30628', 'toron': '27906', 'calisto2018': '19134', 'El_Capitan': '19150', 'Lyndo': '19710', 'papypavi': '11624', 'ToniGil': '28673', 'pmonro': '6971', 'SK_K': '2494', 'random': '2869', 'cingolo': '12408', 'drallod': '12568', 'kiki': '3284', 'Vailala': '9996', 'mickael-17000': '18544', 'dlewczuk': '27373', 'Wolli': '19250', 'mprowe.freecad': '15469', 'Ra': '11516', 'hertfordkc': '2326', 'plaes': '7363', 'janc.linders': '35345', 'xobes': '7481', 'sdavies': '2818', 'JPT': '3167', '1rob1': '30211', 'buhtz': '17438', 'toughkrua': '18289', 'lartisan': '15630', 'Lotus123': '28694', 'HB9FIH': '20068', 'BigMan200': '22347', 'mkj2000': '22529', 'kshots': '5364', 'karolf': '444', 'miro': '18948', 'saul': '5858', 'GregD': '15391', 'artem655000': '28393', 'luvCAD': '28680', 'vnks': '1869', 'bolle732': '1941', 'Commo': '2482', 'AR15DCM': '2572', 'noraef': '7463', 'michaeljoya': '29297', 'Brane212': '8349', 'JavierBrana': '21399', 'Brucesc2': '8875', 'olof': '3926', 'gurjo': '10751', 'Steve': '19045', 'jwolter0': '1103', 'peteg1455': '2048', 'Roo2': '7348', 'unelsson': '25937', 'sanzo': '4043', 'rpardeza': '30601', 'Aina': '4215', 'JensElmo': '18628', 'paragon': '27548', 'Hector.': '6066', 'skal': '28146', 'abevan': '1154', 'vad': '22674', 'dnwalker': '23244', 'mesutbarut': '19223', 'jozamm': '2660', 'csteifel': '20471', 'Japren': '8224', 'Mel3': '25604', 'rentemplan': '30199', 'jotter': '13377', 'JoKo': '29963', 'b0f00nmanjaro': '3562', 'Anton': '9398', 'flyasky': '9506', '243750496': '12006', 'RasmusB': '2491', 'AndreaG': '2772', 'kab': '5442', 'ddlm': '170', 'michelw': '23029', 'Rana': '27627', 'eyome': '32323', 'sb56637': '14872', 'Decibel': '10983', 'la_mecanique': '15704', 'zviz': '3494', 'rstech': '8963', 'candyb': '17785', 'claypipe': '2443', 'below32': '7390', 'toolmaker': '8142', 'surferdudemi': '17028', 'XQAcDozu': '8526', 'Spedex': '30201', 'jabberwocky': '9707', 'treslah': '10131', 'yan_circus': '5369', 'hxmuller': '10899', 'Vitaliq': '19209', 'Ton': '28326', 'Nuno': '11939', 'Steffen-1978': '16517', 'FlyingaHull': '12708', 'Laurie44': '21340', 'armata165': '30587', 'bullhayward': '31158', 'Mu77': '18200', 'xalba': '10468', 'Philip': '15109', 'eodguy': '33705', 'witek12': '11268', 'nikospap': '1463', 'pomonabill221': '2041', 'agu': '2501', 'graycad': '24955', 'Stess': '16606', 'Yann': '25262', 'fabien5': '16910', 'SteveT': '3837', 'Paininstructor': '18273', 'BenW': '10093', 'Jeanmimi0168': '14334', 'andes135': '14398', 'fentabi': '14414', 'AnotherBigAl': '18545', 'IlProfCocco': '32026', 'hans-nl': '1691', 'falrus': '2439', 'FoxBob79': '16207', 'L': '2800', 'ChrispHL': '12686', 'NoTrees': '17023', 'ChrisC': '3801', 'Zbigu': '26065', 'marvellouschandan': '22122', 'romainbonjour': '31414', 'changedsoul': '5804', 'Hymer': '26893', 'blasVuwi': '27371', 'cds4byu': '18751', 'diljot6791': '554', 'faraday': '11883', 'Materiatura': '35098', 'mechg': '2518', 'theniceguy': '7401', 'matteo1783': '8052', 'mathia': '16844', 'VVilhelnn': '12955', 'robofly': '9456', 'JonathanBelnoue': '18239', 'boorgatspook': '303', 'macuso': '994', 'Shikamon': '6205', 'alexu': '28440', 'axre0433': '1587', 'NewbieFreeCADer': '15613', 'ton': '7626', 'FrankKollu': '16765', 'flexbex': '20866', 'kianwee': '3252', 'Oleg_Mo': '8380', 'karzi': '22153', 'LESCAR': '6043', 'matelot': '19267',
#add new users and userids here
#some examples:
#'Enyalios': '13094',
#'agima2': '12024'
def getClipText():
clip = QtGui.QClipboard()
return clip.text(QtGui.QClipboard.Clipboard)
def setClipText(txt):
clip.setText(txt)
#werner's code to get about info
class AboutInfo(QtCore.QObject):
def eventFilter(self, obj, ev):
if obj.metaObject().className() == "Gui::Dialog::AboutDialog":
if ev.type() == ev.ChildPolished:
# print(obj.metaObject().className())
mo = obj.metaObject()
index = mo.indexOfMethod("on_copyButton_clicked()")
if index > 0:
mo.invokeMethod(obj, "on_copyButton_clicked")
QtGui.QApplication.instance().postEvent(obj, QtGui.QCloseEvent())
return False
def getAboutInfo():
ai=AboutInfo()
QtGui.QApplication.instance().installEventFilter(ai)
Gui.runCommand("Std_About")
QtGui.QApplication.instance().removeEventFilter(ai)
return getClipText()
about = getAboutInfo()
setClipText(about)
Msg("\npinger macro -- "+str(len(dict1.keys()))+" users in database. Edit source code to add more.\n")
items = []
for k in dict1.keys():
#Msg(str(k))
items.append(k)
pass
items = ["select user to ping","copy FreeCAD about info"] + sorted(items[:limitToTopNUsers], key=str.casefold)
username,ok = QtGui.QInputDialog.getItem(QtGui.QMainWindow(),"Select user", """Select user:\n\n\
WARNING: (Will replace current clipboard contents.)\n\n\
Tip: Begin typing the name in the combo box.\n""",
items,0,editable=True)
if ok and username != items[0] and username != items[1]:
ping = "[quote="+username+" user_id="+dict1[username]+"]\npinged by pinger macro\n[/quote]"
setClipText(ping)
FreeCAD.Console.PrintMessage("Success!\n\nNow copied to clipboard: \n\n"+ping)
elif ok and username == items[1]:
setClipText(about)
FreeCAD.Console.PrintMessage("Success!\n\nFreeCAD About info copied to clipboard:\n\n"+about)
else:
Msg("\npinger macro: User canceled\n")
