Please review FCVerticalText Macro
WRM65
Postby WRM65 » Thu Jul 23, 2020 10:06 pm
FreeCAD Community,
Prior to submitting the new macro Vertical Text for inclusion to the central repository, please review the macro scripts (see attached zip file).
Here is a description of the macro.
Description
Typically, when a text is presented "vertically", the text is rotated 90 degrees resulting in each character in the text positioned horizontally, which can also make it difficult to read the text. In some cases, it may be preferable to position each character in a vertical (upright) position which make the text easier to read. However, it can be quite laborious, positioning and aligning each character in the text to get the final "vertical" layout. This macro provides an easy and intuitive way to create a "vertical" layout of a given text string. The image below illustrates the vertical layout of a text in both the "typical" and "upright" layout.
The creation of this macro was inspired by the Macro to Create Circular Text and as such, the layout of the user interface (UI) is very similar.
Screenshot - VerticalText - 00.png (31.76 KiB) Viewed 924 times
Scripts
The macro files:
There are four (4) supporting Python files which must be installed in the subfolder ./verticaltext
1. Constants.py
2. Utilities.py
3. FormEntrySettings.py
4. FormPreview.py
All comments / advice welcomed.
Thanks.
Happy FreeCAD'in
FCVerticalText.zip
(17.59 KiB) Downloaded 56 times
vocx
Re: Please review FCVerticalText Macro
Postby vocx » Thu Jul 23, 2020 10:09 pm
It's much easier to review if you keep the code in a Git repository, like GitHub or Gitlab.
Also, it's best if you follow Pythonic guidelines, and name the files in lowercase, and follow the general directions of PEP8 (Python style guidelines).
WRM65
Postby WRM65 » Fri Jul 24, 2020 12:20 am
I will rewrite as advised.
Much appreciated.
mario52
Postby mario52 » Fri Jul 24, 2020 9:50 am
hi
thanks for appreciate and use my macro
i discover little error in the test 0.18 : "__title__" must be uppercase "__Title__" (i correct it later in my macro (only this macro use the uppercase))
"This version " + __title__ + " rmu work with the FreeCAD 0.18 or higher.
the installation is not easy and not FreeCAD rule:
Installation error: missing file - C:/Users/userName/AppData/Roaming/FreeCADverticaltext/VerticalText.py
instead
C:/Users/userName/AppData/Roaming/FreeCAD/Macro/.......
many macro is not installable with AddonManager (you have 4 macros and different directory)
thanks for adding the link to the original macro idea
i have years late for my new modification and i use the path on wire (direction) for position the text
example :
thanks
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting, Dialog creation. My macros on Gist.github.
Postby Kunda1 » Fri Jul 24, 2020 1:05 pm
hi
@mario52 couple of observations:
  • Size character should be Character size
  • Begin angle should be Starting angle
  • End angle should be Ending angle
  • Would it be possible to add the ° (degree character) in the textboxes of the appropriate spinners?
mario52
Postby mario52 » Fri Jul 24, 2020 8:12 pm
hi
[*]Size character should be Character size
[*]Begin angle should be Starting angle
[*]End angle should be Ending angle
done thanks
[*]Would it be possible to add the ° (degree character) in the textboxes of the appropriate spinners?[/list]
no many errors with utfblabla (ça m'a dégoûté) stay..."deg"
mario
WRM65
Postby WRM65 » Sun Jul 26, 2020 3:41 am
Hi Mario,
As I am new to FreeCAD please explain your comment
"the installation is not easy and not FreeCAD rule:"
The installation error prints the parameter settings retrieved from your FreeCAD installation.
See the code starting at line number 279 - 305
  __param = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Macro")
  __path  = __param.GetString("MacroPath","")
  __path  = __path.replace("\\","/") # convert the "\" to "/"
  __path += "verticaltext/" #add macro subdirectory
It seems that a "forward slash" need to be added when formulating the macro subdirectory (line 284)
__path += "/verticaltext/" #add macro subdirectory
From the README.md, it suggest multiple files are supported during the installation process using the __Files__ metadata property.
https://github.com/FreeCAD/FreeCAD-macros#readme
However, if your comment "many macro is not installable with AddonManager (you have 4 macros and different directory)", then my macro will not work.
Also if your enhancement to your FCCircularText macro will provide the exact functionality I have developed, then my macro will be unnecessary.
Thanks for your response.
Regards,
WRM.
mario52
Postby mario52 » Sun Jul 26, 2020 12:53 pm
hi WRM65
no problem with your macro and if the functionality is duplicate everyone is free and your macro is a good macro thanks for sharing
yes
QFontDialog.getFont
does not give the Fonts directory in Windows 10
for this i have used Matplotlib font
you must see with galou and Kunda1 for the installation with AddonManager
mario
Postby Kunda1 » Sun Jul 26, 2020 1:04 pm
It would be ideal if macros weren't duplicated for the simple reason to keep the macro ecosystem as uncluttered as possible.
Is there a way functionality can get combined?
BTW, to submit macros, check out:
https://github.com/FreeCAD/FreeCAD-addons
WRM65
Postby WRM65 » Mon Aug 17, 2020 2:23 am
Hello Mario,
I would like to use your circular text macro to create a circular text on a flat object as shown in your example (included below).
Could you please assist and provide the configuration settings to provide both text layouts.
Thanks.
Kind regards,
WRM.
