It looks like:
https://www.oschina.net/p/vscode-drawio
Is there such workbench can work like this?
Need suggestion. Thanks a lot.
Use "dia" (visio clone). Export to Svg. in FC, Import Svg as geometry. You'll need to fiddle with the text sizes and change lighting to 2 sided.
wandererfan wrote: ↑Tue Jul 28, 2020 1:21 pmUse "dia" (visio clone). Export to Svg. in FC, Import Svg as geometry. You'll need to fiddle with the text sizes and change lighting to 2 sided.
Possibly. Dia has some python scripting support but I haven't tried it.freecadlzh wrote: ↑Wed Jul 29, 2020 3:44 pmIs there any way to integrate it into FC to form a workbench?
Don't assume FreeCAD is only used for a particular usage. Otherwise you are disparaging people that use, say, Draft.
I was thinking the same thing, I am also curious to see what and why he wants because it does, at least at first glance, seem a little strange.
I am also curious to understand what exactly you want and why, what do you want to do this for?
At the same time we should not assume FreeCAD should be suitable for all usages.
