Sketch can not be closed correctly
Uriel Rojo Martinez
Postby Uriel Rojo Martinez » Wed Jul 29, 2020 10:40 pm
Hello, everyone I'm working in a macro to generate lattice structures, one of the shapes that I'm working is this one: (Tetra-Chiral)
The macro can adjust the chiral length, radio of circle and weight of shape. I'm in the final steps to get the sketch ready,
but when I'm trying to close it, the sketch turns in wrong shapes, like this:
I can't figure out how to close it and get a correct sketch, I am willing to spend time to learn and I would be glad if someone can point me in the right direction.
Thank you for your time.
import FreeCAD
import Sketcher
import Part
tc_length = 5
tc_width = 1
tc_radius = 1
radius_in = float(tc_radius) - (float(tc_width)/2)
radius_out = float(tc_radius) + (float(tc_width)/2)
ActiveSketch = App.activeDocument().addObject('Sketcher::SketchObject','Sketch')
ActiveSketch = App.ActiveDocument.getObject('Sketch')
ActiveSketch.Placement = App.Placement(App.Vector(0.000000,0.000000,0.000000),App.Rotation(0.000000,0.000000,0.000000,1.000000))
ActiveSketch.MapMode = "Deactivated"
ActiveSketch.addGeometry(Part.Point(App.Vector(23.638113,22.152096,0)))
ActiveSketch.addConstraint(Sketcher.Constraint('DistanceX',-1,1,0,1,23.638113))
ActiveSketch.setDatum(0,App.Units.Quantity(str(float(tc_length))+' mm'))
ActiveSketch.addConstraint(Sketcher.Constraint('DistanceY',-1,1,0,1,22.152096))
ActiveSketch.setDatum(1,App.Units.Quantity(str(float(tc_length))+' mm'))
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(21.940510,7.252213,0),App.Vector(27.177204,6.708781,0)),True)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(21.841702,5.720726,0),App.Vector(26.979591,4.979685,0)),True)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(21.693497,4.386851,0),App.Vector(27.127804,3.448199,0)),True)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(21.644096,2.855366,0),App.Vector(27.078396,1.966115,0)),True)
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',1,5.264816))
ActiveSketch.setDatum(2,App.Units.Quantity(str(float(tc_length))+' mm'))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',2,5.191054))
ActiveSketch.setDatum(3,App.Units.Quantity(str(float(tc_length))+' mm'))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',3,5.514777))
ActiveSketch.setDatum(4,App.Units.Quantity(str(float(tc_length))+' mm'))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',4,5.506576))
ActiveSketch.setDatum(5,App.Units.Quantity(str(float(tc_length))+' mm'))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 0, 1, 4, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Horizontal',4))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 0, 1, 3, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',3,1,4,1,3.073972))
ActiveSketch.setDatum(9,App.Units.Quantity('90.000000 deg'))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 0, 1, 2, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',2,1,3,1,1.226519))
ActiveSketch.setDatum(11,App.Units.Quantity('180.000000 deg'))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 0, 1, 1, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',1,1,4,1,2.453048))
ActiveSketch.setDatum(13,App.Units.Quantity('180.000000 deg'))
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(21.149603,5.411051,0),App.Vector(22.308653,7.066834,0)),True)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(22.573580,5.146125,0),App.Vector(23.765741,6.835024,0)),True)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(23.699509,4.848085,0),App.Vector(25.024137,6.735677,0)),True)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(25.322180,5.113009,0),App.Vector(26.083841,6.536984,0)),True)
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',5,2.021142))
ActiveSketch.setDatum(14,App.Units.Quantity(str(float(tc_radius))+' mm'))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',6,2.067275))
ActiveSketch.setDatum(15,App.Units.Quantity(str(float(tc_radius))+' mm'))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',7,2.306001))
ActiveSketch.setDatum(16,App.Units.Quantity(str(float(tc_radius))+' mm'))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',8,1.614878))
ActiveSketch.setDatum(17,App.Units.Quantity(str(float(tc_radius))+' mm'))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 0, 1, 5, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',1,1,5,1,0.645545))
ActiveSketch.setDatum(19,App.Units.Quantity('45.000000 deg'))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 0, 1, 6, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',5,1,6,1,0.249573))
ActiveSketch.setDatum(21,App.Units.Quantity('90.000000 deg'))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 0, 1, 7, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',5,1,7,1,0.170041))
ActiveSketch.setDatum(23,App.Units.Quantity('180.000000 deg'))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 0, 1, 8, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',8,1,6,1,1.325137))
ActiveSketch.setDatum(25,App.Units.Quantity('180.000000 deg'))
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(12.243484,5.150989,0),App.Vector(14.463294,8.946864,0)),True)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(14.552089,4.618234,0),App.Vector(17.215860,8.702685,0)),True)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(16.683104,4.418450,0),App.Vector(19.058304,7.970148,0)),True)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(18.547745,4.107677,0),App.Vector(21.255917,7.459592,0)),True)
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 6, 2, 9, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 3, 2, 9, 2))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 5, 2, 10, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 1, 2, 10, 2))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 8, 2, 11, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 2, 2, 11, 2))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 7, 2, 12, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 4, 2, 12, 2))
ActiveSketch.delConstraint(19)
ActiveSketch.addGeometry(Part.Circle(App.Vector(12.154692,5.350770,0),App.Vector(0,0,1),1.588368),True)
ActiveSketch.addConstraint(Sketcher.Constraint('Radius',13,1.588368))
ActiveSketch.setDatum(33,App.Units.Quantity(str(float(tc_radius))+' mm'))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 0, 1, 13, 3))
ActiveSketch.addConstraint(Sketcher.Constraint('Tangent',13,9))
ActiveSketch.setVirtualSpace(33, True)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(11.911286,6.644384,0),App.Vector(12.710419,6.622186,0)),False)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(11.911286,6.133828,0),App.Vector(13.087788,6.178224,0)),False)
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 3, 2, 15, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',3,2,15,1,1.520765))
ActiveSketch.setDatum(37,App.Units.Quantity('90.000000 deg'))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 15, 1, 14, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',14,1,15,1,0.004743))
ActiveSketch.setDatum(39,App.Units.Quantity('180.000000 deg'))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',15,2,9,9.275684))
ActiveSketch.setDatum(40,App.Units.Quantity(str(float(tc_width)/2)+' mm'))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',14,2,9,22.301083))
ActiveSketch.setDatum(41,App.Units.Quantity(str(float(tc_width)/2)+' mm'))
ActiveSketch.setVirtualSpace(40, True)
ActiveSketch.setVirtualSpace(41, True)
ActiveSketch.setVirtualSpace(37, True)
ActiveSketch.setVirtualSpace(39, True)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(10.507776,4.076612,0),App.Vector(12.129680,4.270049,0)),False)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(10.998811,3.421897,0),App.Vector(12.218960,3.615336,0)),False)
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 2, 2, 16, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',16,1,2,2,1.118869))
ActiveSketch.setDatum(43,App.Units.Quantity('90.000000 deg'))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 16, 1, 17, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',16,1,17,1,0.386419))
ActiveSketch.setDatum(45,App.Units.Quantity('180.000000 deg'))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',16,2,11,8.355116))
ActiveSketch.setDatum(46,App.Units.Quantity(str(float(tc_width)/2)+' mm'))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',17,2,11,22.685470))
ActiveSketch.setDatum(47,App.Units.Quantity(str(float(tc_width)/2)+' mm'))
ActiveSketch.setVirtualSpace(46, True)
ActiveSketch.setVirtualSpace(47, True)
ActiveSketch.setVirtualSpace(45, True)
ActiveSketch.setVirtualSpace(43, True)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(9.554909,5.873902,0),App.Vector(9.182913,4.623993,0)),False)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(10.894097,5.516786,0),App.Vector(10.075705,4.222237,0)),False)
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 1, 2, 18, 2))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',18,2,1,2,2.420150))
ActiveSketch.setDatum(49,App.Units.Quantity('90.000000 deg'))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 18, 2, 19, 2))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',19,2,18,2,1.094039))
ActiveSketch.setDatum(51,App.Units.Quantity('180.000000 deg'))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',19,1,10,7.001580))
ActiveSketch.setDatum(52,App.Units.Quantity(str(float(tc_width)/2)+' mm'))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',18,1,10,2.620771))
ActiveSketch.setDatum(53,App.Units.Quantity(str(float(tc_width)/2)+' mm'))
ActiveSketch.setVirtualSpace(49, True)
ActiveSketch.setVirtualSpace(51, True)
ActiveSketch.setVirtualSpace(52, True)
ActiveSketch.setVirtualSpace(53, True)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(8.905710,4.455854,0),App.Vector(9.039629,3.176186,0)),False)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(9.709224,4.277296,0),App.Vector(9.634823,3.086906,0)),False)
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 4, 2, 20, 2))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',1,1,20,2,0.125384))
ActiveSketch.setDatum(55,App.Units.Quantity('90.000000 deg'))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 20, 2, 21, 2))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',21,2,20,2,1.473877))
ActiveSketch.setDatum(57,App.Units.Quantity('180.000000 deg'))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',21,1,12,10.619767))
ActiveSketch.setDatum(58,App.Units.Quantity(str(float(tc_width)/2)+' mm'))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',20,1,12,12.541294))
ActiveSketch.setDatum(59,App.Units.Quantity(str(float(tc_width)/2)+' mm'))
ActiveSketch.setVirtualSpace(59, True)
ActiveSketch.setVirtualSpace(58, True)
ActiveSketch.setVirtualSpace(57, True)
ActiveSketch.setVirtualSpace(55, True)
ActiveSketch.addGeometry(Part.Circle(App.Vector(8.452773,5.178742,0),App.Vector(0,0,1),1.443580),True)
ActiveSketch.addConstraint(Sketcher.Constraint('Radius',22,1.443580))
ActiveSketch.setDatum(60,App.Units.Quantity(radius_out))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 0, 1, 22, 3))
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(9.583646,5.297782,0),App.Vector(10.654998,6.696491,0)),True)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(10.312759,4.702586,0),App.Vector(11.503151,6.101296,0)),True)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(10.640118,3.809793,0),App.Vector(12.232265,5.342422,0)),True)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(11.146033,3.422915,0),App.Vector(12.500103,4.464508,0)),True)
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',23,1.761869))
ActiveSketch.setDatum(62,App.Units.Quantity(radius_out))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',24,1.836688))
ActiveSketch.setDatum(63,App.Units.Quantity(radius_out))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',25,2.209951))
ActiveSketch.setDatum(64,App.Units.Quantity(radius_out))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',26,1.708339))
ActiveSketch.setDatum(65,App.Units.Quantity(radius_out))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 0, 1, 26, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',1,1,26,1,0.032547))
ActiveSketch.setDatum(67,App.Units.Quantity('45.000000 deg'))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 0, 1, 25, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',25,1,26,1,0.045054))
ActiveSketch.setDatum(69,App.Units.Quantity('180.000000 deg'))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 0, 1, 23, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',26,1,23,1,0.846113))
ActiveSketch.setDatum(71,App.Units.Quantity('90.000000 deg'))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 0, 1, 24, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Angle',24,1,23,1,1.190530))
ActiveSketch.setDatum(73,App.Units.Quantity('180.000000 deg'))
ActiveSketch.setVirtualSpace(73, True)
ActiveSketch.setVirtualSpace(71, True)
ActiveSketch.setVirtualSpace(69, True)
ActiveSketch.setVirtualSpace(67, True)
ActiveSketch.setVirtualSpace(62, True)
ActiveSketch.setVirtualSpace(63, True)
ActiveSketch.setVirtualSpace(64, True)
ActiveSketch.setVirtualSpace(65, True)
ActiveSketch.setVirtualSpace(60, True)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(8.170523,7.778833,0),App.Vector(9.256756,5.963487,0)),False)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(7.515808,6.886040,0),App.Vector(8.750839,5.174853,0)),False)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(7.054531,6.335484,0),App.Vector(8.527641,4.386219,0)),False)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(6.861092,5.517090,0),App.Vector(8.185404,3.880302,0)),False)
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 23, 2, 30, 2))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 14, 2, 30, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 26, 2, 29, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 18, 1, 29, 2))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 16, 2, 28, 2))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 24, 2, 28, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 25, 2, 27, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 21, 1, 27, 2))
ActiveSketch.setVirtualSpace(67, False)
ActiveSketch.delConstraint(67)
ActiveSketch.addConstraint(Sketcher.Constraint('Tangent',22,30))
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(8.584854,6.521563,0),App.Vector(10.526935,4.797472,0)),False)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(9.813518,7.274614,0),App.Vector(12.449196,5.035278,0)),False)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(11.775414,7.294431,0),App.Vector(13.757128,5.134363,0)),False)
ActiveSketch.addGeometry(Part.LineSegment(App.Vector(13.281515,7.056625,0),App.Vector(14.767800,5.213631,0)),False)
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 15, 2, 31, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 19, 1, 32, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 17, 2, 33, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 20, 1, 34, 1))
ActiveSketch.addConstraint(Sketcher.Constraint('Parallel',30,31))
ActiveSketch.addConstraint(Sketcher.Constraint('Parallel',29,32))
ActiveSketch.addConstraint(Sketcher.Constraint('Parallel',28,33))
ActiveSketch.addConstraint(Sketcher.Constraint('Parallel',34,27))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',31,1.943902))
ActiveSketch.setDatum(90,App.Units.Quantity(str((float(tc_length)/3)*1)+' mm'))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',32,6.048099))
ActiveSketch.setDatum(91,App.Units.Quantity(str((float(tc_length)/3)*1)+' mm'))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',34,15.475498))
ActiveSketch.setDatum(92,App.Units.Quantity(str((float(tc_length)/3)*1)+' mm'))
ActiveSketch.addConstraint(Sketcher.Constraint('Distance',33,5.394029))
ActiveSketch.setDatum(93,App.Units.Quantity(str((float(tc_length)/3)*1)+' mm'))
ActiveSketch.delConstraint(90)
ActiveSketch.delConstraint(91)
ActiveSketch.addConstraint(Sketcher.Constraint('PointOnObject',31,2,22))
ActiveSketch.addConstraint(Sketcher.Constraint('PointOnObject',34,2,22))
ActiveSketch.addConstraint(Sketcher.Constraint('PointOnObject',33,2,22))
ActiveSketch.addConstraint(Sketcher.Constraint('PointOnObject',32,2,22))
ActiveSketch.addGeometry(Part.Circle(App.Vector(9.015268,3.755115,0),App.Vector(0,0,1),0.539429),False)
ActiveSketch.addConstraint(Sketcher.Constraint('Coincident', 0, 1, 35, 3))
ActiveSketch.addConstraint(Sketcher.Constraint('Radius',35,0.539429))
ActiveSketch.setDatum(95,App.Units.Quantity(str(radius_in)+' mm'))
App.ActiveDocument.Sketch.addGeometry(Part.ArcOfCircle(Part.Circle(App.Vector(3.238429,3.572829,0),App.Vector(0,0,1),1.260285),1.141848,1.537306),False)
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Coincident',36,2,31,2))
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Coincident',36,1,29,1))
App.ActiveDocument.Sketch.addGeometry(Part.ArcOfCircle(Part.Circle(App.Vector(2.678770,3.414976,0),App.Vector(0,0,1),0.855130),-3.584613,-2.983830),False)
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Coincident',37,2,34,2))
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Coincident',37,1,30,2))
App.ActiveDocument.Sketch.addGeometry(Part.ArcOfCircle(Part.Circle(App.Vector(3.224078,2.611363,0),App.Vector(0,0,1),0.793802),-1.987235,-1.365322),False)
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Coincident',38,2,33,2))
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Coincident',38,1,27,1))
App.ActiveDocument.Sketch.addGeometry(Part.ArcOfCircle(Part.Circle(App.Vector(3.970290,3.214073,0),App.Vector(0,0,1),0.879101),-0.394713,0.196885),False)
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Coincident',39,2,32,2))
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Coincident',39,1,28,1))
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Radius',36,1.257777))
App.ActiveDocument.Sketch.setDatum(104,App.Units.Quantity(str(radius_out)+' mm'))
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Radius',39,0.879101))
App.ActiveDocument.Sketch.setDatum(105,App.Units.Quantity(str(radius_out)+' mm'))
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Radius',38,0.793802))
App.ActiveDocument.Sketch.setDatum(106,App.Units.Quantity(str(radius_out)+' mm'))
App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('Radius',37,0.855130))
App.ActiveDocument.Sketch.setDatum(107,App.Units.Quantity(str(radius_out)+' mm'))
ActiveSketch.setVirtualSpace(0, True)
ActiveSketch.setVirtualSpace(1, True)
ActiveSketch.setVirtualSpace(2, True)
ActiveSketch.setVirtualSpace(3, True)
ActiveSketch.setVirtualSpace(4, True)
ActiveSketch.setVirtualSpace(5, True)
ActiveSketch.setVirtualSpace(9, True)
ActiveSketch.setVirtualSpace(11, True)
ActiveSketch.setVirtualSpace(13, True)
ActiveSketch.setVirtualSpace(14, True)
ActiveSketch.setVirtualSpace(15, True)
ActiveSketch.setVirtualSpace(16, True)
ActiveSketch.setVirtualSpace(17, True)
ActiveSketch.setVirtualSpace(20, True)
ActiveSketch.setVirtualSpace(22, True)
ActiveSketch.setVirtualSpace(24, True)
ActiveSketch.setVirtualSpace(95, True)
Re: Sketch can not be closed correctly
Postby chrisb » Thu Jul 30, 2020 6:45 am
How about
- placing the center of the arcs in the center of the coordinate system
- make the ends of the arc coincident with the ends of the adjacent straight lines?
This consumes 6 DOF while adding such an arc adds only 5. Thus your Sketch would be overconstrained. You have to remove - or better not generate it - the point-on-object constraint.
If you still get the arc the wrong way round, you can try to switch the sequence of attachments, i.e. swap the ends.
Uriel Rojo Martinez
Postby Uriel Rojo Martinez » Thu Jul 30, 2020 5:31 pm
How about
Very helpful, thanks!
ulrich1a
Postby ulrich1a » Thu Jul 30, 2020 8:27 pm
I would not try to generate a sketch in a makro, but generate the profile directly with Part lines and arcs and make a Part wire from it. As you can calculate all vertexes in the macro, you do not need the sketcher solver at all.
Ulrich
