[FIXED] Ticket #6407 - python API access to 2d fillet OCC functionality
Re: Ticket #6407 - python API access to 2d fillet OCC functionality
Updated thread title with issue #6407 and renamed thread for better comprehension
git commit b07be87677
Example:
Example:
from FreeCAD import Base
# Defining the points
p1 = Base.Vector(0, 0, 0)
p2 = Base.Vector(5, 5, 0)
p3 = Base.Vector(-5, 5, 0)
ed1 = Part.makeLine(p3, p2)
ed2 = Part.makeLine(p2, p1)
pln = Part.Plane()
api = Part.ChFi2d.FilletAPI()
api.init(ed1, ed2, pln)
radius = 1
api.perform(radius)
fillet2d, ed1, ed2 = api.result(p2)
wire = Part.Wire([ed1, fillet2d, ed2])
Part.show(wire)
Would it be better to use pln = Part.Plane(p1, p2, p3) instead for a more general solution where all points are not already on the xy plane or does it not matter?wmayer wrote: ↑Sat May 28, 2022 9:22 am git commit b07be87677
Example:Code: Select all
from FreeCAD import Base # Defining the points p1 = Base.Vector(0, 0, 0) p2 = Base.Vector(5, 5, 0) p3 = Base.Vector(-5, 5, 0) ed1 = Part.makeLine(p3, p2) ed2 = Part.makeLine(p2, p1) pln = Part.Plane() api = Part.ChFi2d.FilletAPI() api.init(ed1, ed2, pln) radius = 1 api.perform(radius) fillet2d, ed1, ed2 = api.result(p2) wire = Part.Wire([ed1, fillet2d, ed2]) Part.show(wire)
Re: [FIXED] Ticket #6407 - python API access to 2d fillet OCC functionality
It doesn't matter in this case. A plane where p1,p2,p3 lie on that all have z=0 is the xy plane and that's created with Part.Plane(). But for the general case you are right.TheMarkster wrote: ↑Mon May 30, 2022 4:12 pm Would it be better to use pln = Part.Plane(p1, p2, p3) instead for a more general solution where all points are not already on the xy plane or does it not matter?
