Releasing "Vision_5" toolbar
The macro is here:
https://github.com/Freedman-CB1/Macro-Vision
For some Youtube views, watch these in 1080p:
https://www.youtube.com/channel/UCcnFnZ ... VEHjhkzHkw
For some .mp4 videos:
https://github.com/Freedman-CB1/Vision_5_Videos
Directions for use:
https://github.com/Freedman-CB1/Macro-Vision/wiki
Updated macro on github, Sept. 18 2020
All feedback is welcome, especially if you can find code problems, I'm new to python.
Directions for use:
- Vision_5_toolbar_image.PNG (7.87 KiB) Viewed 2529 times
- bavariaSHAPE
Re: Releasing "Vision_5" toolbar
When I start Vision 5, I get the following error:
Any idea?
OS: Windows 7 SP 1 (6.1) (Without internet connection)
Version: 0.19.22284 (Git)
Hash: bf1e8e48389f5e9e25bd77b67fe98da4213e797c
Python version: 3.6.8
Qt version: 5.12.1
20:19:24 C:\…\FreeCAD_0.19_x64_LP_12.1.2_PY3QT5-WinVS2015\Mod\Show\SceneDetails\Workbench.py(43)<class 'SyntaxError'>: ('invalid syntax', ('C:/…/AppData/Roaming/FreeCAD/Macro/Vision5_V55.FCMacro', 6, 1, '<!DOCTYPE html>\n'))
Any idea?
Qt version: 5.12.1
… for a happy FreeCAD-World … JM2C …
I should have said: do a new macro create and copy the macro code into it.
The reason I wanted to do github was to track changes.
I will post the macro code here until I make a change on github and then I will remove it here permanent. This will make it easier for now.
And I have no idea about that error.
Thanks
Thanks
- bavariaSHAPE
Done, thanks.freedman wrote: ↑Sat Aug 29, 2020 7:36 pm I should have said: do a new macro create and copy the macro code into it.
Thanks
My procedure:
So I have the original files in a ZIP file, is also better for archiving.
There is no point in importing every class from QtGui and QtCore, if you are already using the prefixed classes.
Not needed.
This is enough.
Using the str() function is pointless because TypeId is already a string.
This is enough.
Please don't use semi-colons, it's bad Python style.
Better.
This could actually be handled with a loop.
Also, I don't recommend using big try-except blocks.
This is a way to quickly avoid errors in your code, however it's not the best solution.
You should trap specific errors, not just trap all errors to quickly avoid problems.
Not needed.
from PySide.QtCore import *
from PySide.QtGui import *
from PySide import QtCore
from PySide import QtGui
QtGui.QWidget()
QtGui.QVBoxLayout()
if str(obj.TypeId) != "Part::Helix":
if obj.TypeId != "Part::Helix":
self.editor_list[0][0].setEnabled(True) ; self.editor_list[1][0].setEnabled(True) ; self.editor_list[2][0].setEnabled(True) ; self.editor_list[3][0].setEnabled(True) ; self.global_list[3][0].setEnabled(True)
for i in range(4):
self.editor_list[i][0].setEnabled(True)
try:
# 50 lines
except:
pass
try:
self.pad2 = self.pad.getParentGeoFeatureGroup()
except:
self.pad2 = None
if not self.pad2:
return
# 50 lines
Thanks vocx, I will get those changes incorporated.
Would you mind making a screencast demoing the usage of the macro ?
Thanks!
Is there a file size limit to a video, like mp3, does the 1 meg limit still apply?
Thanks
Thanks
Yes, attachment limits apply across the board. You can always upload to imagur or even your github repo
Videos.....
Video1: Using Global and Single selections and see what they do to the model. A Global selection affects the entire model and single selections are mouse select only. You will need to exit Single selection mode to edit model lines and edges. There are many combinations to choose from. https://github.com/Freedman-CB1/Vision_ ... Video1.mp4
Video2: Using Page edit mode on page #1, using suppress vs wireframe, selecting all objects in a Part container vs single object and enter/exit Page edit. https://github.com/Freedman-CB1/Vision_ ... Video2.mp4
Video3: Using Page edit mode on page #1 we set the Part edit and go about clicking on objects. In about 5 click almost the entire model is set for hidden and we hide it. Then we go about randomly selecting parts for unhiding. Then we see how object edit can give us easy access to looking inside a model. We can select between Part and Object selection at any time.
At the end we see how wire framed objects can be shown in the model. https://github.com/Freedman-CB1/Vision_ ... Video3.mp4
Video4: Using page edit we use multiple pages as we work our way down thru layers to see inside. Objects selected on the current page are hidden in the next page (increasing page number). This allows us to keep some object always hidden as we work. The page numbers can be changed in edit or view mode but the control points are only visible in edit mode. The model will be stored as you see it so when you open the file the macro can used to edit. https://github.com/Freedman-CB1/Vision_ ... Video4.mp4
Video5: Shows the Edit-Sketcher-Display-Preferences that I use, you might want it a little different but I recommend these settings. Notice I turn off "Restore cameras position" so when we use "3D view sketch" button the view won't get changed after an edit. The video shows "3D view sketch" enabled so as sketches are opened the view stays as is. Selecting "Inventor" allows us to rotate the view while a sketch is opened. You will need to switch back from Inventor to restore the mouse to normal operation in Gesture mode. The video continues on to show how Page Edit can be used to hide objects and open sketches to edit and rotate the view while in Sketcher. https://github.com/Freedman-CB1/Vision_ ... Video5.mp4
Video6: Selecting "Color all" to change to color of all objects. This will override all color so watch out if you preset colors. We also see how "Focus tree" will keep the tree in view after a sketch edit. Notice how we open multiple sketches without a view change because we have "3D view sketch" enabled. https://github.com/Freedman-CB1/Vision_ ... Video6.mp4
Video7: Shows page mode and how we navigate back and forth using the page editor.https://github.com/Freedman-CB1/Vision_ ... Video7.mp4
