How to get Face Name or Face ID in Box Part?
freecadlzh
Post by freecadlzh »
In part workbench, I created a box Part, Now in python script I try follow code,but can not get the face name:
>>> gg = FreeCAD.ActiveDocument.getObject ("Box")
>>> g=gg.Shape.Faces
>>> g
[<Face object at 000000002762D410>, <Face object at 000000002762D910>, <Face object at 000000002762DD90>, <Face object at 000000002762D350>, <Face object at 00000000205CF5A0>, <Face object at 00000000205CE920>]
>>> g0 = g[0]
>>> g0.Name
AttributeError: 'Part.Face' object has no attribute 'Name'
How to get the face name? Thanks a lot.
freecadlzh
Re: How to get Face Name or Face ID in Box Part?
Is there any way to deal that?
Waiting for help, Thanks a lot.
Post by Kunda1 »
Please always post you About info when asking for assistance
freecadlzh
Kunda1 wrote: Fri Oct 16, 2020 1:29 am Please always post you About info when asking for assistance
OS: Windows 7 SP 1 (6.1)
Word size of EME_Simulator_: 64-bit
Version: 0.19.22665 (Git)
Hash: b0d7850406e046f3b7a8cd5da261e7d54df6bd99
Python version: 3.6.8
Qt version: 5.12.1
Locale: Chinese/China (zh_CN)
mario52
Post by mario52 »
hi
with getSelectionEx() and SubElementNames[0 to xxx]
try:
    SubElement = FreeCADGui.Selection.getSelectionEx()                    # sub element name with getSelectionEx()
    element_ = SubElement[0].SubElementNames[0]                           # name of 1 element selected
    App.Console.PrintMessage("elementSelec   : "+str(element_)+"\n\n")
except:
    App.Console.PrintMessage("Oups"+"\n\n")
Code_snippets
mario
freecadlzh
mario52 wrote: Fri Oct 16, 2020 1:10 pm hi
try:
except:
Code_snippets
mario
Thanks for your help, but this code can not deal my problem:
Follow your code, when program runs just when user clicked on the model (such as a cube model named Box) ,and pressed the CTRL key with the left mouse clicked on one Face (such as a face of Box named Face2 be clicked) the method "getSelectionEx" will worked, and can return the object (Face2 object), and the "SubElementNames" can contain the name "Face2" that the name of clicked face of the Cube model.
So which subobject can be returned , just depends on the user's mouse click.
But now my needed is : Give a part object, without user's mouse click, by python script list or print all the part object subobject name.
For example: give a Cube object, It consists of 6 faces, named Face1,Face2,Face3....Face6, by "FreeCAD.ActiveDocument.getObject("Box").Shape.Faces" can got the 6 Face object of the Box, But I did not kown the way to get the 6 Face object name, so I can not print the names of the 6 faces. Need the code to got all of the 6 faces name. Thanks a lot.
gg=FreeCAD.ActiveDocument.getObject("Box")
gg.Shape.Faces
[<Face object at 00000000271F2E30>, <Face object at 00000000271F2EB0>, <Face object at 00000000271F2F30>, <Face object at 00000000271F2FB0>, <Face object at 00000000271F3030>, <Face object at 00000000271F30B0>]
mario52
Post by mario52 »
hi
>>> g0 = g[0]
g[0] = Face1
g[3] = Face4
for g0.display the Name i do not know
mario
freecadlzh
mario52 wrote: Sat Oct 17, 2020 10:02 am hi
>>> g0 = g[0]
g[0] = Face1
g[3] = Face4
mario
Thanks for your help, I got a picture below:
In the picture, I know the face object name is "Face1" , But in freecad did not provide a method to get the Face object(named "g0") name , so the code "g0.Name" runs errors. I need a way to get the Face object name( not by selection).
Need help , Thanks a lot.
Chris_G
Post by Chris_G »
A shape has no "Name" property.
Instead, every shape has only a convenient shortcut to access its own subshapes.
Take a box object. It is a solid.
It has 8 vertexes.
You can access them in two ways :
v = box.Vertexes[2]
or :
v = box.Vertex3
It is the same.
The second version is just slightly more convenient because it is a property, not an item of a list.
Now let's consider the second face of the box.
It has 4 vertexes.
You can access them with :
v = box.Face2.VertexN # for N in [1...4]
But if you access these same vertexes from the box solid directly, you'll see that they are :
v = box.VertexN # for N in [5...8]
So, a subshape cannot have a single name, because it depends on the parent shape it is accessed from.
derMart
Post by derMart »
I do have the exact same problem as @freecadlzh. I am using the link branch by @realthunder.
I want to add a specific face to the selection. Found out this can be done via
FreeCADGui.Selection.addSelection(applicationName,objectName,faceName)
so for example:
FreeCADGui.Selection.addSelection('myapplication','Pad','Face2')
Getting the objectName is no problem via
App.ActiveDocument.getObject('Pad').Name
but I am also stuck at the subname / face name. Now inferring from comment above, can I be sure that all faces inside an object are named 'Face1', 'Face2', ... or may those names be different than this convention? Especially, when working in the link branch which does some things to prevent naming changes if things are edited around?
