[Help] Areas Between Two Polyline
HakanSeven12
Postby HakanSeven12 » Tue Nov 24, 2020 5:38 pm
I have two 2D point list that represent polylines that showed in pic and I want to calculate areas between this polylines like showed in picture(Sum orange areas and sum green areas). İn orange areas blue line over red line and in green areas red line over blue line. I have lots of this type polylines. So I want to automate this process. Is there any idea how can I do that?
johnwang
Re: [Help] Areas Between Two Polyline
Postby johnwang » Tue Nov 24, 2020 8:13 pm
1 Make a list of intersection points
2 calculate between each pair of intersection points for both polylines
3 Sblue-Sred
4 Sum up (+ and -)
hfc series CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2 and more)
HakanSeven12
Postby HakanSeven12 » Tue Nov 24, 2020 8:24 pm
How can I get the intersection points? How can I project start-end points to other line?
Roy_043
Postby Roy_043 » Wed Nov 25, 2020 8:05 am
The Draft module has a findIntersection function.
heda
Postby heda » Thu Nov 26, 2020 10:42 pm
If using findIntersection in DraftGeomUtils, it works with edges, so you will have to use those to get the intersections.
Just create a new vertical line at the ends and use the findIntersection on the vertical lines
I'm guessing it will be more code than one first expects to make it work on different cases.
btw - let us know if you managed to get it done.
HakanSeven12
Postby HakanSeven12 » Fri Nov 27, 2020 12:13 am
The problem is I just have two polyline x,y coordinates only. I draw this just show what I want. So I can't use draft functions. If I find a way I will inform you :)
But your idea is good. I don't think it that way.
Edit: I found this intersection algorithm on internet.
def line_intersection(line1, line2):
    xdiff = (line1[0][0] - line1[1][0], line2[0][0] - line2[1][0])
    ydiff = (line1[0][1] - line1[1][1], line2[0][1] - line2[1][1])
    def det(a, b):
        return a[0] * b[1] - a[1] * b[0]
    div = det(xdiff, ydiff)
    if div == 0:
       return None
    d = (det(*line1), det(*line2))
    x = det(d, xdiff) / div
    y = det(d, ydiff) / div
    return x, y
def poly_intersection(poly1, poly2):
    for i, p1_first_point in enumerate(poly1[:-1]):
        p1_second_point = poly1[i + 1]
        for j, p2_first_point in enumerate(poly2[:-1]):
            p2_second_point = poly2[j + 1]
            if line_intersection((p1_first_point, p1_second_point), (p2_first_point, p2_second_point)):
                return True
    return False
PL1 = ((-1, -1), (1, -1), (1, 2))
PL2 = ((0, 1), (2, 1))
print poly_intersection(PL1, PL2)
heda
Postby heda » Fri Nov 27, 2020 12:46 am
Well, so you just have the coords, like text?
If so, not entirely clear in your question - and was going to say why do that in freecad?
Sounds like fairly easy geometry to be done in python directly (or any other language, or spreadsheet application for that matter).
Seems like you have come to that conclusion of your own.
Now, even if you just have points you could do that in fc, but I would use numpy for that (and matplotlib to verify results)....
HakanSeven12
Postby HakanSeven12 » Fri Nov 27, 2020 1:02 am
Its about my workflow. Me and a friend creating a new workbench and I need to calculate volume between two surface by draw it's cross sections and calculate those areas and create volume tables and process goes like this. I can't use standard FreeCAD functions and objects because my coordinates are double values. So I'm using specific node in coin 3d. So I need to write nearly everything from zero.
Roy_043
Postby Roy_043 » Fri Nov 27, 2020 8:42 am
The findIntersection also accepts 4 vertices:
You can also feed 4 points instead of `edge1` and `edge2`.
HakanSeven12
Postby HakanSeven12 » Fri Nov 27, 2020 9:26 am
I will take a look. Thanks
