Steel Stair Generator
鋼製階段を作成できます。解凍後マクロ→マクロ→ユーザーマクロの場所を指定して実行してください。
- stairs.zip
- (47.08 KiB) Downloaded 222 times
- ebrahim raeyat
Re: Steel Stair Generator
it is fantastic, can you create it with object to be modified after creation? I mean parametric stair.
Re: スチール階段ジェネレータ
今のところできません。将来修正できればと思っています。
- ebrahim raeyat
Re: スチール階段ジェネレータ
Thanks a lot, I studied you code, it seems it has some not used import modules. and you can use layout for dialog instead of setGeometry for each widget. thanks
@paullee you'll be interested in thispaullee wrote: pinged by pinger macro
Edit: Context:
https://twitter.com/FreeCADNews/status/ ... 2938724353
Thanks @Kunda
@パスカル789 awesome macro indeed
You should be able to add that into existing ArchStairs
https://github.com/FreeCAD/FreeCAD/blob ... hStairs.py
- HakanSeven12
Why there is no screenshot?
- Screenshot_20201202-204002.jpg (300.17 KiB) Viewed 4783 times
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
Will it be added to Arch Stair? Should we also add it to the FreeCAD-addon repo ?
re: Arch stairs
@paullee can you weigh in on this? How would this macro be incorporated in Arch Stairs code in your opinion.
re: FreeCAD-addons
To submit an addon one needs to make a 'Pull Request' to the addons github repository. Though on 2nd thought, maybe this is too redundant?
