Hello Community
Would need some help again:
I know it`s possible to get object info froma clicked point in the active view, with Pivy obserers for example.
(getObjectInfo())
I`m wondering whether it`s possible to get this also from a given 2D world coordinates point?
E.g. we have point x= 200, y=0. Is there an object on that point.
Or is there a chnace to convert the world coordinates to the pixel coordinates?
So, the opposite of getPoint(pos).
Thanks for help.
Regards
Chris
How to get objectInfo from given world coordinates
Re: How to get objectInfo from given world coordinates
Can't check now, but AFAIR there is a function
getObjectsInfo(x, y)
getObjectInfo(x, y)
coordinates (from placement).
If I wanna use this function I have to convert, but I don`t know whether this is possible somehow.
This isn't exactly same function (notice the 's' at the end of 'objects'). But indeed not very reliable information as I'm with a mobile now and using my memory.
What I found out by myself is, the difference between the both (one with "s" the other without) is just
the number of objects under the cursor.
If using returns only information of 1 object.
returns a list with information of all objects.
Maybe I`m wrong ?
If using
getObjectInfo
getObjectsInfo
Maybe I`m wrong ?
Not sure to understand. Only the viewport is 2D. The scene is 3D everywhere actually. So as well is a Placement. Would you provide a simple example to explain?
I have a solution. With this
I get the cursor position and not the coordinates and I can work with
Thanks for help.
Greetings
Chris
FreeCADGui.activeDocument().activeView().getCursorPos()
getObjectInfo
Thanks for help.
Greetings
Chris
