Hi everyone,
Today I finished my Honeycomb Solid Macro and I want to publish it into the default Macros repository, but according to the best practice, I'm sharing it here to be tested and reviewed by you.
Please test it, and let me know if work fine for you. The code is versioned in my GitHub repository https://github.com/christiangda/FreeCAD ... ycombSolid
[Macro] New Honeycomb Solid Macro (to be tested)
Re: [Macro] New Honeycomb Solid Macro (to be tested)
Hello and welcome to the forum.
I dont know how is this supposed to work but when the file with a honeycomb is saved and then loaded it still has all the properties but can not be modified - some errors are shown. I tried then creating a second honeycomb. While the file is not closed it is properly edited. But the first honeycomb still does not change - no errors thou.
hi
good macro thanks work very well
but the icon is not saved in file (as in my macro example !!)
(similar macro Macro_FCHoneycombMaker)
mario
mario
Hi @kisolre, you are right, I'm working on it, I'm not sure why it happens, I'm reading about the error I have.kisolre wrote: ↑Sat Jan 16, 2021 8:12 pm Hello and welcome to the forum.
11:02:42 <string>(1)<class 'AttributeError'>: Module __main__ has no class HoneycombSolid
11:02:43 <string>(1)<class 'AttributeError'>: Module __main__ has no class ViewProviderHoneycombSolid
https://wiki.freecadweb.org/Scripted_objects
https://github.com/FreeCAD/FreeCAD/blob ... ePython.py
I'm I don`t know why when you reopen the Freecad file, even if the macro is installed these errors appear
mario52 wrote: ↑Sat Jan 16, 2021 8:57 pm hi
mario
Hi Mario, thanks!
Let me tell you that your macro was my inspiration, and I only am trying to use different honeycombs solids in the same documents, that the reason why I have created this.
My project using the firs version of my macro is: https://github.com/christiangda/3d-prin ... case.FCStd if you want to check it.
I'm just a Hobbyist of 3d printing trying to used FreeCAD as my favourite tool for 3d designs
I'll implement the new version of my macro as soon I fixed the problem of the icon and the problem of properties when the file is reopened.
I'm reading how to create a Custom Icon and how to save it to be persistent, thank you again for your comment.
As soon as I fixed these problems I'll comment here.
hi
mario
the Macro_FCHoneycombMaker is at TheMarkster (not mario52)
thanks
mario
the page https://wiki.freecadweb.org/Scripted_ob ... attributes explains more about how to save attributes. I think that one of the things then need to be respected is that the class must be importable, i.e. a *.py file, not a *.FCMacro file. I don't have the time to double-check that but this would mean that the macro needs to be split into a FCMacro and a py file containing the needed classes. The GeodesicDome macro from the official repository is a working example of parametric object that works after FreeCAD restart.
Gaël
Gaël
Hi Gaëlgalou_breizh wrote: ↑Wed Jan 20, 2021 7:30 pm Hello,
Gaël
Thank you very much for your comment, this help me to solve the problem
When you create a ParametricObject it is necessary to create a folder with the content of your code as ".py" and the ".FCMacro" needs to have python "import <your class into your .py file>"
Now it is working fine when you save and reload your files.
I'm creating the pull request to distribute my macro! https://github.com/FreeCAD/FreeCAD-macros/pull/89
Christian
