Issues with pythonically importing FreeCAD (after conda install)
onekk
Re: Issues with pythonically importing FreeCAD (after conda install)
Postby onekk » Fri Mar 12, 2021 3:16 pm
Suppose you want something added to the PATH, I use this to import the location of a multimodule script in PATH at the beginning of the script, and avoid to import it many time
MODULE_PATH musto contain the PATH you want imported
if not MODULE_PATH in sys.path:
    sys.path.insert(-1,MODULE_PATH)
I suppose that append will work, insert(-1, ....) will insert the thing in the last position of list, different way of specifying things.
Butfrom the little I know about conda, conda is working like a container specifying the module path is working only in the "same environment" on which you install freecad.
Maybe it useful to see:
https://wiki.freecadweb.org/Embedding_FreeCAD/
see the Caveats at the bottom of page
Regards
Carlo D.
Introduzione a FreeCAD in Italiano: https://github.com/onekk/freecad-doc
galou_breizh
Postby galou_breizh » Thu Apr 01, 2021 7:11 am
Why I did to have FreeCAD available in my $PYTHONPATH is
cd $HOME/.local/lib/python3.8/site-packages && for f in /usr/lib/freecad-daily-python3/lib/*.so; do ln -s $f; done
Adapt to your FreeCAD version if you don't use FreeCAD Daily.
I wish that a package manager will put the *.so files in the correct place in the future (but maybe not for the daily version, so that both version can be installed concurrently).
Gaël
OS: Ubuntu 20.04.2 LTS (i3/i3)
Version: 0.19.
Branch: unknown
Hash: e8566f22bbeb0b7204e3c45519d0963e8881100b
Python version: 3.8.5
Qt version: 5.12.8
Coin version: 4.0.0
OCC version: 7.5.1
onekk
Postby onekk » Thu Apr 01, 2021 2:20 pm
The problem with conda, is that from what i remember when I've tried it it's a sort of protected environment, where each "program" use "his own" environment, so when you fire a "conda package" it set "his own" environment I don't know how, but there is some documentation around, this mechanism isolate the "conda package" from the "host OS", so using some thing are doable only in the "conda package" environment.
I have tried to set up a conda environment, but I've gave up because it will download almost an entire OS to use in the "conda package" environment.
It is a sort of container, where only some basic system libraries are used (kernel and glibc and few others I suppose) but all the relevant other libraries are installed as a "per package" needs, to avoid compatibility problems.
the "OS python interpreter" is not aware of the "directory tree" of the "conda package" so it is not included, but chances are that even importing the "conda package" libraries hey are compiled for a different version of python so maybe it is not very "safe" and "error free".
Maybe it is doable to reuse the "conda package" python interpreter to launch a python program not packaged in the "conda package", and this could be the better way to reuse the "freecad conda environment", but this is a problem to be asked maybe to the people that make the "freecad conda package".
Hope it helps
Regards
Carlo D.
looo
Postby looo » Thu Apr 01, 2021 2:31 pm
If you install freecad via conda into a conda environment you should be able to import freecad from python via:
import freecad
This will do the path modification.
But this is only true if you work within the conda-environment (virtual environment). It's not suggested to import from the system python as this will lead to issues because of mixed.dependencies...
gbroques
Postby gbroques » Thu Apr 01, 2021 11:01 pm
I wrote a tiny shell script that can be executed one time, once you have a desired conda environment activated.
It will allow you to import FreeCAD, FreeCADGui, Part, etc. from <my_script.py> when executing:
$ python <my_script.py>
See the following shell script:
https://github.com/gbroques/freecad-to- ... on_path.sh
#!/bin/sh
# Must be executed when a desired conda environment is activated.
# By adding the $CONDA_PREFIX/lib directory to $PYTHONPATH, python is able to find
# FreeCAD, FreeCADGui, and other various FreeCAD-related modules during execution.
cd $CONDA_PREFIX
mkdir -p ./etc/conda/activate.d
mkdir -p ./etc/conda/deactivate.d
touch ./etc/conda/activate.d/env_vars.sh
touch ./etc/conda/deactivate.d/env_vars.sh
echo '#!/bin/sh' >> ./etc/conda/activate.d/env_vars.sh
echo 'export INITIAL_PYTHONPATH=${PYTHONPATH}' >> ./etc/conda/activate.d/env_vars.sh
echo "export PYTHONPATH=$CONDA_PREFIX/lib:\${PYTHONPATH}" >> ./etc/conda/activate.d/env_vars.sh
echo '#!/bin/sh' >> ./etc/conda/deactivate.d/env_vars.sh
echo 'export PYTHONPATH=${INITIAL_PYTHONPATH}' >> ./etc/conda/deactivate.d/env_vars.sh
echo 'unset INITIAL_PYTHONPATH' >> ./etc/conda/deactivate.d/env_vars.sh
Basically, it adds FreeCAD's lib/ directory, with all the .so or .dll files, to PYTHONPATH when you activate your conda environment.
Then it removes FreeCAD's lib/ directory from PYTHONPATH when you deactivate the conda environment.
See the following conda docs for more information:
https://docs.conda.io/projects/conda/en ... -variables
This is equivalent to sys.path.append("path/to/lib") or insert at the top of the script, but way cleaner.
gbroques
Postby gbroques » Thu Apr 01, 2021 11:24 pm
looo wrote: :bell:
Would it be possible to add a post-link.sh to the freecad conda package so the standard FreeCAD is always ready to be imported from a Python script when a conda environment is activated?
See the following post-link.sh:
https://github.com/gbroques/ose-workben ... st-link.sh
#!/bin/sh
# Executed after the package is installed.
# An error is indicated by a nonzero exist and causes installation to fail.
# If there is an error, conda does not write any package metadata.
# See Also:
#   https://docs.conda.io/projects/conda-build/en/latest/resources/link-scripts.html
cd $CONDA_PREFIX
and conda's docs on it:
https://docs.conda.io/projects/conda-bu ... ripts.html
looo
Postby looo » Sat Apr 03, 2021 3:04 pm
gbroques wrote: Thu Apr 01, 2021 11:24 pm
looo wrote: :bell:
#!/bin/sh
# See Also:
cd $CONDA_PREFIX
Thx, good idea. I will try to integrate this in the next days.
