Created NEW Macro : AeroFoil
melwynfranciscarlo
Postby melwynfranciscarlo » Mon Mar 01, 2021 3:05 pm
I just created my very first FreeCAD Macro, titled AeroFoil.
A similarly existing macro is the Airfoil Import & Scale, which is very old, I reckon; also, it's limited in its functionality.
I simply added a whole lot more features to make the airfoil creation more fun, flexible, and do-it-all.
Macro AeroFoil Wiki Page
Description : AeroFoil creates airfoil curves and faces using pre-defined models, algebraic functions, and DAT or CSV Files.
So, what do you think? Is it worth tying the knot with FreeCAD?
8-) MFC Boy: the one and only! 8-)
Syres
Re: Created NEW Macro : AeroFoil
Postby Syres » Mon Mar 01, 2021 5:16 pm
melwynfranciscarlo wrote: Mon Mar 01, 2021 3:05 pm So, what do you think?
You can't assume every FreeCAD user has their macros in the default location, some of us have a proper data structure with macros, templates, GCode, FEM/CFD etc so I changed line 186 on my copy from :
MD_ = App.getUserMacroDir() + "AeroFoil_UI_Files/AeroFoil_"
to:
MD_ = FreeCAD.getUserMacroDir(True) + "/AeroFoil_UI_Files/AeroFoil_"
The difference on my Windows box is from:
17:12:46 C:\Users\JPS\AppData\Roaming\FreeCAD\Macro/AeroFoil_UI_Files/AeroFoil_
to:
17:12:46 E:/Data/FreeCAD/Macro/AeroFoil_UI_Files/AeroFoil_
I've not tested on Linux yet but will do later and report back.
OS: Windows 7 SP 1 (6.1)
Version: 0.19.24267 (Git)
Hash: b2ca86d8d72b636011a73394bf9bcdedb3b109b7
Python version: 3.6.8
Qt version: 5.12.1
melwynfranciscarlo
Postby melwynfranciscarlo » Mon Mar 01, 2021 5:28 pm
Syres wrote: Mon Mar 01, 2021 5:16 pm You can't assume every FreeCAD user has their macros in the default location, some of us have a proper data structure with macros, templates, GCode, FEM/CFD etc so I changed line 186 on my copy from :
Okay, thank you, Syres! I've noted that down.
After I receive all inputs, I'll make the changes in one-go.
melwynfranciscarlo
Postby melwynfranciscarlo » Thu Mar 04, 2021 1:50 pm
Syres wrote: Mon Mar 01, 2021 5:16 pm You can't assume every . . .
I added your correction to my copy as well, and seeing that no other issues have turned up, I have submitted a PR.
Zolko
Postby Zolko » Fri Mar 05, 2021 11:41 am
melwynfranciscarlo wrote: Mon Mar 01, 2021 3:05 pm I just created my very first FreeCAD Macro, titled AeroFoil.
Hello, nice effort, but there are some issues:
1) why do I have to tell where the lines start and where they end ? Is line #1 (as per a text editor) the first line, or is the first line the #0 as per python ? The built-in airfoil dat importer can figure this out alone. You could, for example, skip all lines beginning with # as comments, and read each line until an empty line is encountered)
2) I can't enter a chord larger than 10mm
3) the following data produces wrong results:
# Airfoil   Z- 33   10.90%   alpha0= -3.04   Cm0= -.0653
  1.00000   .00000
   .99686   .00030
   .98747   .00123
   .97199   .00290
   .95069   .00542
   .92394   .00887
   .89223   .01329
   .85611   .01862
   .81618   .02478
   .77307   .03161
   .72739   .03889
   .67977   .04637
   .63078   .05380
   .58100   .06092
   .53096   .06746
   .48116   .07318
   .43208   .07785
   .38409   .08125
   .33758   .08331
   .29293   .08394
   .25049   .08310
   .21058   .08078
   .17350   .07702
   .13951   .07189
   .10884   .06551
   .08172   .05801
   .05830   .04958
   .03873   .04042
   .02309   .03080
   .01145   .02101
   .00381   .01147
   .00026   .00275
   .00000  -.00032
   .00018  -.00209
   .00069  -.00363
   .00165  -.00503
   .00308  -.00640
   .00803  -.00968
   .02048  -.01464
   .03807  -.01889
   .06059  -.02231
   .08789  -.02484
   .11973  -.02646
   .15585  -.02719
   .19592  -.02708
   .23956  -.02621
   .28633  -.02467
   .33574  -.02252
   .38732  -.01987
   .44052  -.01690
   .49473  -.01376
   .54930  -.01060
   .60357  -.00753
   .65687  -.00467
   .70854  -.00212
   .75790   .00003
   .80430   .00170
   .84711   .00286
   .88570   .00347
   .91951   .00355
   .94801   .00316
   .97073   .00234
   .98712   .00123
   .99682   .00032
  1.00000   .00000
4) I use the Curves WB to re-sample my points when mixing different airfoils, it would be good to include those tools
5) sometimes I need upper and lower surfaces of airfoils (for wire-cutting for example), it would be good to have the option to automatically add the (0,0) point and split the upper and lower surfaces into 2 separate curves (combining this with the re-sampling of the points)
6) the UI seems to grab the mouse, is it really necessary ?
melwynfranciscarlo
Postby melwynfranciscarlo » Fri Mar 05, 2021 12:59 pm
Zolko wrote: Fri Mar 05, 2021 11:41 am ...
Hello Zolko, thank you very much for your reply.
1. You don't necessarily have to input the line numbers. Leaving it at its default value at 0 (as there is no line number 0) should automatically figure it out. The 'add line numbers' feature is simply for those who want it; you don't have to use it.
2. Airfoils greater than 10mm are possible on my computer. I've set a minimum limit of 1mm, not a maximum. I've just tested your airfoil for a chord length of 10 yards, that is, 9144mm, and it worked. Could you share a screenshot if it shows any errors?
3. I see the wrong results, and I'm on it! I'll notify you when I figure it out.
4. Could you be specify the tools used? And by resampling, do you mean equidistant resampling of points on a curve?
5. Oh yes, like the split curve. I could work on that, sure.
6. Grab the mouse? I'm confused. The mouse cursor does not change other than the default and the text cursor modes.
melwynfranciscarlo
Postby melwynfranciscarlo » Fri Mar 05, 2021 2:40 pm
Zolko wrote: Fri Mar 05, 2021 11:41 am 2) I can't enter a chord larger than 10mm
Oh yes, it seems that I may have strangely (unintentionally, I think) set the maximum value of the Spin Box to 99.99. So the maximum of the input in the UI file was set to less than 100.
I've corrected it to 1000.
Is that okay? I mean, beyond that, you could simply switch to cm, m, etc.
Zolko
Postby Zolko » Fri Mar 05, 2021 2:42 pm
melwynfranciscarlo wrote: Fri Mar 05, 2021 2:40 pm I've corrected it to 1000.
that's 1m. Why not 100000 (100m) ? That would leave room for some extravangza
melwynfranciscarlo
Postby melwynfranciscarlo » Fri Mar 05, 2021 4:41 pm
Zolko wrote: Fri Mar 05, 2021 2:42 pm
Haha, okay, I'll do that then.
Phew, Problem No. 3 has finally been solved. The issue was with the .xxx and -.xxx style of DAT points. The code was used to just 0.xxx and -0.xxx. Changed that now.
melwynfranciscarlo
Postby melwynfranciscarlo » Tue Mar 09, 2021 5:51 pm
Zolko wrote: Fri Mar 05, 2021 11:41 am 5) sometimes I need upper and lower surfaces of airfoils (for wire-cutting for example), it would be good to have the option to automatically add the (0,0) point and split the upper and lower surfaces into 2 separate curves (combining this with the re-sampling of the points)
The Split feature has been added to the Macro. It has also been tested against your airfoil, and it works!
