Manipulating InList and OutList
I have two FeaturePython classes: Box and BoxDimensions.
I'd like to make BoxDimensions part of Box's InList. I've search high and low for a method of doing this in the Wiki, API docs, and forums, and have only found ways to read and iterate InList/OutList, but not how to write/insert/append to these lists.
The intuitive way, obj.InList.append(sobj) doesn't work.
Since I'm now delving into application code to try to find an answer, I figured I should ask in here to try and save some time.
Does anyone know what the appropriate API calls to modify InList and OutList are?
Re: Manipulating InList and OutList
I think all the *List properties need to be set "as a whole".
append(), extend(), ... don't work directly :
tmpList = myObj.InList
tmpList.append(item)
myObj.InList = tmpList
They are stored internally as tuples?Chris_G wrote: ↑Thu Mar 11, 2021 8:18 am I think all the *List properties need to be set "as a whole".
append(), extend(), ... don't work directly :Code: Select all
tmpList = myObj.InList tmpList.append(item) myObj.InList = tmpList
Regards
Carlo D.
- Various other stuffs.
I get an error trying to set the list directly:
>>> il = obj.InList
>>> il.append(sobj)
>>> obj.InList = il
AttributeError: Attribute 'InList' of object 'DocumentObject' is read-only
You cannot directly manipulate the InList and OutList of a feature because this is a collection of all link properties used by the features and you can't know which link properties to modify in the end.
The OutList gives you the features a given feature depends on and it must have a link property of a sub-type of PropertyLinkBase. The InList gives you the features that depend on the given feature.
So, you can only indirectly modify the InList/OutList by manipulating the corresponding link properties of the features.
Hello wmayer, Thank you for your prompt reply.
I was also looking at the link properties and wasn't sure what role they played in the dependency graph. I will experiment with these a bit more. Where's the best place to find documentation for them? I find the wiki and forums to be a bit sparse at best, and these seem like core features...
Would you allow a relative newcomer like me to help update the documentation or contribute a mini-tutorial once I've uncovered a solution?
Oops, sorry for the mis-information.
I have never used InList / OutList specifically and thought they were simply behaving like other *List properties.
No problem, it was only curiosity (not the lander on Mars).
Regards
Carlo D.
Regards
Carlo D.
Maybe a real case will be useful.Hermit wrote: ↑Thu Mar 11, 2021 9:14 am Hello wmayer, Thank you for your prompt reply.
Some code with one can work on to test some solutions, in many other "help forums" they ask for a MWE (Minimal Working Example) or to be more precise:
A minimal unworking example and some information about:
1) what you intend to achieve
2) how the actual solution is wrong or subotpimal
3) what you expect the program will do
In this manner and with a MWE someone could test and maybe find a solution
This post is not to criticize, only to help to find a solution.
Regards
Carlo D.
My original post answers these three points.
I have two FeaturePython classes, Box and BoxDimension. I would like BoxDimension's InList to contain a Box object. Similarly, I would like Box's OutList to contain the corresponding BoxDimension object.
Maybe I had the semantics for InList and OutList reversed in my OP, but this entirely describes the conditions that I am trying to achieve.
