Sorry if I am posting this message in the wrong place. I confess I felt confused when I was choosing the topic.
My installation:
OS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Branch: unknown
Hash: 9e3b630bbfb6807e93eeffb655e6c20f218644fc
Python version: 3.8.5
Qt version: 5.12.8
OCC version: 7.5.1
The problem:
I use A2plus a lot to make my assemblies, even often having to start the work from scratch always I need to modify the geometry of a base part within the assembly. Complaints apart, right now I am facing a new problem regarding missing parts in imported a2plus subassemblies. Take a look at the pictures below.
The first picture is an a2plus assembly that I am trying to import in the final assembly of the second picture. Notice there are some parts missing.
When I try to update the assembly I am getting the error messages below. Please, help me to understand what is happening.
Thank you in advance.
22:13:47 PropertyPythonObject::toString(): failed for <class 'PEMInserts.FSPcbStandOffObject'>
22:13:47 Traceback (most recent call last):
File "/usr/lib/python3.8/json/__init__.py", line 231, in dumps
return _default_encoder.encode(obj)
File "/usr/lib/python3.8/json/encoder.py", line 199, in encode
chunks = self.iterencode(o, _one_shot=True)
File "/usr/lib/python3.8/json/encoder.py", line 257, in iterencode
return _iterencode(o, 0)
File "/usr/lib/python3.8/json/encoder.py", line 179, in default
raise TypeError(f'Object of type {o.__class__.__name__} '
<class 'TypeError'>: Object of type Quantity is not JSON serializable
22:13:47
===== Start Solving System ======
22:13:47 TARGET POS-ACCURACY :1e-05
22:13:47 REACHED POS-ACCURACY :6.41261195323249e-08
22:13:47 TARGET SPIN-ACCURACY :1e-05
22:13:47 REACHED SPIN-ACCURACY :0.0
22:13:47 SA SPIN-ACCURACY :0.0
22:13:47 ===== System solved using partial + recursive unfixing =====
22:25:13 PropertyPythonObject::toString(): failed for <class 'PEMInserts.FSPcbStandOffObject'>
22:25:13 Traceback (most recent call last):
