Here's the function (also attached as file for easier viewing):
def biasFeatures(feature, bias): #Uses edge comparisons to bias a passed face object
This function is responsible for biasing (expanding or shrinking) a given object by a given amount. It does this by comparing edge distances and making
the distances either larger or smaller through a series of comparisons.
Inputs: the feature (face) being biased and the value to bias by. A negative bias value enlarges an object and a positive bias shrinks the object
Returns: a new face object that has been biased
print("Bias begin") #For Debugging
print("bias = %f" % bias) #For debugging
The below section gathers boundary conditions needed to correctly bias the objects. The points from the bounds variable are used to keep
an object from being biased off of the given substrate (if applicable) and the loop finds the outside edge points of the feature
bounds = get_2D_outer_bounds() #Grabs the outermost bounds of the device
xLow = bounds[0][0]; xHigh = bounds[2][0]; yLow = bounds[0][1]; yHigh = bounds[2][1] #Used later to not bias objects off the substrate
Z = feature.Vertexes[0].Point[2] #Gets the height value for the new face
lowX = 0; highX = 0; lowY = 0; highY = 0 #Used to find the boundaries of the feature being biased
for points in feature.Vertexes: #Runs through every vertex and grabs the boundary points
point = points.Point
if point[0] < lowX:
lowX = point[0]
if point[0] > highX:
highX = point[0]
if point[1] < lowY:
lowY = point[1]
if point[1] > highY:
highY = point[1]
xVals = []; yVals = [] #Used to keep track of the new vertex points
#print(len(feature.Edges)) #For debugging
The below section is divided into two categories: simple rectangular objects with 4 edges, and more complex objects with an even number of edges.
The biasing works by taking an edge and checking it's distance to an edge on the opposite side of the object (by checking vector direction of the edges).
It then shifts the edge by the biasing amount and checks to see if it shifted in the right direction. If not then it'll take the values being shifted the
other direction. For more complex objects the edge being compared to will always be an outside edge since an inside edge might actually need to be shifted
towards another inside edge for the object to get larger. The new vertices are recorded onto 2 arrays, 1 for the x values and 1 for the y values. These
are updated independently since right now all biases are done on axis (all inputs expected to exist on axis). So, one edge will move only in the x direction
and will create updated x values for the vertices and then the next edge will move in the y direction and create updated y values for the vertices.
edge1 is always the edge that will undergo the bias and edge2 is always the edge that it is being compared to.
**Will have to be updated for any objects with an odd number of edges (including "circular" objects). Will have to be updated for off-axis objects.
if len(feature.Edges) == 4: #If rectangular with only 4 edges
#print("TRUE") #For debugging
for edge1 in feature.Edges: #Runs through every edge of the passed feature
edge1First = edge1.firstVertex().Point; edge1Last = edge1.lastVertex().Point #Gets the two vertices of the edge
if (edge1First[0] == edge1Last[0] == lowX == xLow) or (edge1First[0] == edge1Last[0] == highX == xHigh): #If the edges are at the boundary of the device
xVals.append(edge1First[0]) #Don't add any bias since edge at boundary of device
xVals.append(edge1Last[0]) #Don't add any bias since edge at boundary of device
if len(yVals) == 0: #If no y values have been updated then add a value (used to balance vertices)
yVals.append(0) #5 vertices required to close an object, this gives the fifth vertex
continue #Continue to next edge
if (edge1First[1] == edge1Last[1] == lowY == yLow) or (edge1First[1] == edge1Last[1] == highY == yHigh):#If the edges are at the boundary of the device
yVals.append(edge1First[1]) #Don't add any bias since edge at boundary of device
yVals.append(edge1Last[1]) #Don't add any bias since edge at boundary of device
if len(xVals) == 0: #If no x values have been updated then add a value (used to balance vertices)
xVals.append(0) #5 vertices required to close an object, this gives the fifth vertex
#print(edge1.firstVertex().Point[0], edge1.lastVertex().Point[0]) #For debugging
edge1Dir = np.array(edge1.tangentAt(edge1.FirstParameter)) #Finds the vector direction of the edge and converts to a numpy array
for edge2 in feature.Edges: #Runs through all the edges of the feature to find a comparison edge
edge2Dir = np.array(edge2.tangentAt(edge2.FirstParameter)) #Finds the direction of the second edge
#Below line takes the dot product of the two edge directions. If they are exactly opposite directions then the angle will be 180 degrees
if math.degrees(math.acos(np.dot(edge1Dir, edge2Dir) / (np.linalg.norm(edge1Dir)* np.linalg.norm(edge2Dir)))) == 180:
#Part.show(edge1) #For debugging
#Part.show(edge2) #For debugging
#print(edge1Dir) #For debugging
#print(edge2Dir) #For debugging
origDist = edge1.distToShape(edge2)[0]#np.linalg.norm(edge1-edge2) #Finds the original distance between the two FreeCAD edges
tempPts = [FreeCAD.Vector(edge1First[0]+bias, edge1First[1], Z), \
FreeCAD.Vector(edge1Last[0]+bias,edge1Last[1], Z)] #This is used to create a new set of vertices with a bias
newEdge = Part.makePolygon(tempPts) #Creates a new FreeCAD edge that can be used for comparison
#Part.show(newEdge) #For debugging
newDist = newEdge.distToShape(edge2)[0]#np.linalg.norm(newEdge-edge2) #Finds the distance between the new and old FreeCAD edges
If the passed bias is negative then an expansion occurs, so the difference between the new and old edges should be positive
(shown as "-bias") and the reverse for a reduction in object size. If the expansion in the x direction is incorret then
an attempted expnasion in the y direction occurs.
if (newDist-origDist) == -bias: #If the difference between the edges distances is equal to the bias value
#This is right way to move edge
xVals.append(edge1First[0]+bias) #Create first new x vertex with the bias added
xVals.append(edge1Last[0]+bias) #Create second new x vertex with the bias added
if len(yVals) == 0:
elif (newDist-origDist) == bias:
#Reverse the bias value
xVals.append(edge1First[0]-bias) #Create first new x vertex with the bias subtracted
xVals.append(edge1Last[0]-bias) #Create second new x vertex with the bias subtracted
if len(yVals) == 0:
else:
#Add bias to the y values
tempPts = [FreeCAD.Vector(edge1First[0], edge1First[1]+bias, Z), \
FreeCAD.Vector(edge1Last[0],edge1Last[1]+bias, Z)]
yVals.append(edge1First[1]+bias)
yVals.append(edge1Last[1]+bias)
if len(xVals) == 0:
yVals.append(edge1First[1]-bias)
yVals.append(edge1Last[1]-bias)
if len(xVals) == 0:
break
else: #Object has an even number of edges greater than 4 edges
#internalEdgeNum = 0 #Not currently in use - was going to be used for edge direction counts
Much of the following section follows the same process as above. The only difference is that there is a check to see if the edge that is being
biased is an inside or outside edge. If it is an outside edge then the same process as above happens, and if it is an inside edge then
there is an additional check to verify that the edge it is being compared to is an outside edge. This verifies the correct movement direction
of the edge (in accordance with the bias) and accounts for the fact that an enlargment will require inside edges to be closer versus farther
apart.
See above for inline comments describing each process.
if len(yVals) == 0:
continue
if len(xVals) == 0:
continue
edge1Dir = np.array(edge1.tangentAt(edge1.FirstParameter))#edge1.tangentAt(edge1.FirstParameter)
edge2Dir = np.array(edge2.tangentAt(edge2.FirstParameter))#edge2.tangentAt(edge2.FirstParameter)
if (math.degrees(math.acos(np.dot(edge1Dir, edge2Dir) / (np.linalg.norm(edge1Dir)* np.linalg.norm(edge2Dir)))) == 180):
edge2First = edge2.firstVertex().Point; edge2Last = edge2.lastVertex().Point
if (edge1First[0] == lowX or edge1First[0] == highX \
or edge1First[1] == lowY or edge1First[1] == highY) \
and (edge1Last[0] == lowX or edge1Last[0] == highX \
or edge1Last[1] == lowY or edge1Last[1] == highY): #If the edge is an outside edge
print("Edge on outside")
#Part.show(edge1)
#Part.show(edge2)
#print(edge1Dir)
#print(edge2Dir)
FreeCAD.Vector(edge1Last[0]+bias, edge1Last[1], Z)]
#Part.show(newEdge)
#print(newDist, origDist) #For debugging
#print("Bias added to X values with a newDist of %f and origDist of %f" % (newDist, origDist)) #For debugging
#this is right way to move edge
if len(yVals) == 0:
#print("Bias substracted from X values with a newDist of %f and origDist of %f" % (newDist, origDist))
#reverse the bias value
if len(yVals) == 0:
else:
#add bias to the y values
#Part.show(newEdge)
#print("Bias added to Y values with a newDist of %f and origDist of %f" % (newDist, origDist)) #For debugging
if len(xVals) == 0:
#print("Bias subtracted from Y values with a newDist of %f and origDist of %f" % (newDist, origDist)) #For debugging
if len(xVals) == 0:
break
elif ((edge2First[0] == edge2Last[0] == lowX) or (edge2First[0] == edge2Last[0] == highX) \
or (edge2First[1] == edge2Last[1] == lowY) or (edge2First[1] == edge2Last[1] == highY)): #This must be an inside edge (not at boundary values)
print("Inside edge found")
#Part.show(edge1)
#Part.show(edge2)
#print(edge1Dir)
#print(edge2Dir)
#Part.show(newEdge)
if len(yVals) == 0:
#print("Bias substracted from X values with a newDist of %f and origDist of %f" % (newDist, origDist)) #For debugging
if len(yVals) == 0:
else:
#Part.show(newEdge)
if len(xVals) == 0:
if len(xVals) == 0:
break
if xVals[0] == 0: #Corrects the 5th vertex so that the shape is properly closed
xVals[0] = xVals[-1]
yVals.append(yVals[0])
elif yVals[0] == 0: #Corrects the 5th vertex so that the shape is properly closed
yVals[0] = yVals[-1]
xVals.append(xVals[0])
#print(len(xVals),len(yVals)) #For debugging
#print(xVals)
#print(yVals)
finalVerts = [] #New array to hold a tuple of the final vertices
for idx in range(0,len(xVals)): #The length of xVals and yVals are equal, this loop runs through them to create new vertices
if idx == 0: #If this is the first vertex, find the highest value from the ends of the arrays
#Solve for first and last vertex
if abs(xVals[0]) > abs(xVals[-1]): #Determines the x value for the first vertex
xFin = xVals[0]
else:
xFin = xVals[-1]
if abs(yVals[0]) > abs(yVals[-1]): #Determines the y value for the first vertex
yFin = yVals[0]
else:
yFin = yVals[-1]
finalVerts.append((xFin,yFin,Z))
elif idx == len(xVals)-1: #Sets the last vertex equal to the first vertex so the object is closed
#set equal to first point
finalVerts.append(finalVerts[0])
else:
finalVerts.append((xVals[idx],yVals[idx],Z))
#print(len(finalVerts))
#print(finalVerts) #For debugging
pts=[]
for i in range(0,len(finalVerts)): #Used to create an array of the "Vector points" required in FreeCAD
pts.append(FreeCAD.Vector(finalVerts[i][0],finalVerts[i][1],finalVerts[i][2])) #FreeCAD.Vector(x,y,z)
#print(pts)
wire=Part.makePolygon(pts) #Connects all points given above, makes a wire polygon (just a connected line)
#Part.show(wire)
face=Part.Face(wire) #Creates a face from the wire above
print("Bias end")
return face #Returns the new face that has been biased
There are a few function calls that return specific values; these functions can be found in this GitHub Repository.
OS: Windows 10 (10.0)
Version: 0.19.22960 (Git)
Hash: c5a4b01d2e4218bcc0eb6650337650a6c65ef0e4
Python version: 3.8.6
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
