QtViewportSize.
QtViewportSize.
I am working on an update to the OpenSCAD workbench Add Element command.
With my updates there are now two Qt TextEdit windows, the first one defined in AddSCADWIdget is the main text entry Window.
I would like to have it so that its size can be larger than currently allowed when the parent Window is enlarged.
It seems to be limited by the maximumViewportSize which if I print it out is 640 x 480.
I have very limited knowledge of Qt and not able to work out how the Viewport works or where its maximum is set.
Anybody able to help?
Update to OpenSCADCommands.py attached
Re: QtViewportSize.
I can't find the relevant code, but when programming with Qt, doing interfaces by hand, i have found that sometimes it is not the field but the layout container.
The field could expand at maximun of the space allowed by the Layout container, if the layout container, is contained (worry for the joke) in another container, two container and some other setting, to define the border are responsible for the max dimension.
Try to see if in this page you could find something useful.
https://doc.qt.io/qt-5/layout.html
se under "Manual Layout" and "Layout Issues", maybe if the "interface" is managed by FreeCAD, maybe reusing some of this spaces (like the space in TreeView), some signal behaviour could be reimplemented.
https://doc.qt.io/qt-5/qgridlayout.html#details
Hope it helps
Regards
Carlo D.
Plus it the widget is inserted in Grid Layout some space are reserved in the grid to make some borders, plus columns could be limited in expansion, as you could fix a ratio, says column 1 has to be 2 times large than column2 and similar things.The widget will get an event of type QEvent::LayoutRequest when the layout needs to be recalculated. Reimplement QWidget::event() to handle QEvent::LayoutRequest events.
Hope it helps
Regards
Carlo D.
- Various other stuffs.
Re: QtViewportSize.
Agree it is probably something down to the layout.onekk wrote: ↑Tue Apr 27, 2021 3:13 pm I can't find the relevant code, but when programming with Qt, doing interfaces by hand, i have found that sometimes it is not the field but the layout container.
Hope it helps
Regards
Carlo D.
The relevant Layout is
layout= QtGui.QVBoxLayout()
layout.addLayout(layouth)
layout.addWidget(self.checkboxmesh)
layout.addWidget(self.textEdit)
layout.addWidget(self.textMsg)
self.setLayout(layout)
currently it can look like i.e. Want the widget with the text cube in it to expand to the maximum.
If I print out Its maximum height I get 16777215
If I print out its maximumViewportSize I get 640,480 hence my original post.
Re: QtViewportSize.
You have to resize the text. try to guess the exact panel dimension and the set explicitly a text height:
Not the proper code, but see at the start when i guess the main FreeCAD window dimension and resize the logbox accordingly.
I have to go now, maybe later, feel free to PM me.
Regards
Carlo D.
class log_box(QtGui.QDialog):
ap_style = "font-size: 14px"
def __init__(self):
super(log_box, self).__init__()
self.initUI()
def initUI(self):
self.result = usr_canc
# create our window
sc_wid = QtGui.QDesktopWidget().screenGeometry().width()
sc_hei = QtGui.QDesktopWidget().screenGeometry().height()
# get dimensions for available space on screen
av_wid = QtGui.QDesktopWidget().availableGeometry().width()
av_hei = QtGui.QDesktopWidget().availableGeometry().height()
w_wid = av_wid * 0.50
w_hei = av_hei * 0.50
x_loc = (sc_wid - w_wid) * 0.5
y_loc = (sc_hei - w_hei) * 0.5
# define window xLoc,yLoc,xDim,yDim
self.setGeometry(x_loc, y_loc, w_wid, w_hei)
self.setWindowTitle("Boxes-FC Log Window")
self.setWindowFlags(QtCore.Qt.WindowStaysOnTopHint)
but_hei = 30
self.txt_win = QtGui.QLabel()
self.txt_win.setWordWrap(True)
self.txt_win.setStyleSheet(self.ap_style)
self.txt_win.setAlignment(QtCore.Qt.AlignTop | QtCore.Qt.AlignLeft)
#print(dir(self.txt_win))
sc_a = QtGui.QScrollArea()
#sc_a.setBackgroundRole(QtGui.QPalette.Dark)
sc_a.setWidgetResizable(True)
sc_a.setWidget(self.txt_win)
btn_cont = QtGui.QFrame()
Btn_can = QtGui.QPushButton('Cancel', self)
Btn_can.clicked.connect(self.onCancel)
Btn_can.setAutoDefault(True)
Btn_can.move(150, w_hei - but_hei * 1.5)
# OK button
Btn_ok = QtGui.QPushButton('OK', self)
Btn_ok.clicked.connect(self.onOk)
Btn_ok.move(260, w_hei - but_hei * 1.5)
# now make the window visible
lay1 = QtGui.QHBoxLayout(self)
lay1.addWidget(Btn_ok)
lay1.addWidget(Btn_can)
btn_cont.setLayout(lay1)
lay = QtGui.QVBoxLayout(self)
lay.addWidget(sc_a)
lay.addWidget(btn_cont)
self.setLayout(lay)
self.show()
def set_text(self, msg):
self.txt_win.setText(msg)
def onCancel(self):
self.close()
def onOk(self):
self.result == userOK
self.close()
Regards
Carlo D.
Re: QtViewportSize.
See if this could be of some help:
https://doc.qt.io/qt-5/qwidget.html#maximumSize-prop
About QSize property
https://doc.qt.io/qt-5/qsizepolicy.html
You have done fo textMsg
What is the widget that need to be resized?
if it is TExtEdit
If not working, try to use the Qgrilayout and set columnspan and rowspan accordingly, i.e
transform like this.
Gridlayout is more customizable, as you could even set the column interspace and many othe things. like minimun column and row height and width.
Hope it helps
Regards
Carlo D.
The widget cannot be resized to a larger size than the maximum widget size.
By default, this property contains a size in which both width and height have values of 16777215.
Note: The definition of the QWIDGETSIZE_MAX macro limits the maximum size of widgets.
self.textMsg.setMaximumHeight(h)
if it is TExtEdit
h = a minimum height dimension, maybe calculated relative from the windows size say 0.5
self.textEdit.setMinimunHeight(h)
self.textEdit.setWidgetResizable(True)
layouth=QtGui.QHBoxLayout()
layouth.addWidget(self.buttonadd)
layouth.addWidget(self.buttonload)
layouth.addWidget(self.buttonsave)
layouth.addWidget(self.buttonrefresh)
layouth.addWidget(self.buttonclear)
layout=QtGui.QGridLayout()
#addWidget(QWidget, int r, int c, int rowspan, int columnspan)
layout.addWidget(self.buttonadd, 0, 0, 1, 1)
layout.addWidget(self.buttonload, 0, 1, 1, 1))
layout.addWidget(self.buttonsave, 0, 2, 1, 1))
layout.addWidget(self.buttonrefresh, 0, 3, 1, 1))
layout.addWidget(self.buttonclear, 0, 4, 1, 1))
layout.addWidget(self.checkboxmesh, 1, 0, 1, 4))
layout.addWidget(self.textEdit, 2, 0, 2, 4) )
layout.addWidget(self.textMsg, 4, 0, 1,41))
Hope it helps
Regards
Carlo D.
Re: QtViewportSize.
Thanks will give it a try.
Re: QtViewportSize.
try first the minimunsize and then resizable = False, it has less impact on the existing code.
see
https://doc.qt.io/qt-5/qwidget.html#setMinimumSize-1
but also:
https://doc.qt.io/qt-5/qsize.html#details
You could use this trick if you are referring to a widget in a complex code.
name the widget:
Suppose that self.mainw is your "main windows" if you want to have the "reference" of the object to manipulate, you have to assign a self.something variabel name, but if you store only the main window you could simply find the objec by name in his childrem with:
The example is done with a grid layout container in which I have to add a widget.
another trick to uniform things is using stylesheets:
suppose that you want to differentiate the label from the text in a bunch of input fields, you coudl set two styles, and then assign them simply with:
Another trick if you use the gridlayout is that you could set the row minimun height, per row, using:
obviously wid is the GridLayout widget and row is the row number 25 is the size in pixel (Qt unit of measure)
Hope it helps
Regards
Carlo D.
see
but also:
name the widget:
label.setObjectName("label1")
wid = self.mainw.findChild(QtCore.QObject, "lable1")
wid.addWidget(self.txt_win, 0, 0)
self.ap_style = "font-size: 14px"
self.tx_style = "font-size: 16px"
wid.setStyleSheet(self.ap_style)
wid.setRowMinimumHeight(row, 25)
wid.setRowStretch(row, 1)
Hope it helps
Regards
Carlo D.
Re: QtViewportSize.
self.textEdit.setWidgetResizable(True) does not work textEdit does not have such a function https://doc.qt.io/qt-5/qtextedit-members.html
Grid layout does not help. the size of textEdit window stays the same.
Don't want to set minimum size its not limited maximum size that is needed.
Re: QtViewportSize.
Try with setSizePolicy
QSizePolicy::Expanding GrowFlag | ShrinkFlag | ExpandFlag The sizeHint() is a sensible size, but the widget can be shrunk and still be useful. The widget can make use of extra space, so it should get as much space as possible (e.g. the horizontal direction of a horizontal slider).
QSizePolicy::Ignored ShrinkFlag | GrowFlag | IgnoreFlag The sizeHint() is ignored. The widget will get as much space as possible.
From this text I suppose that if you could inspect the SizePolicy and maybe change it to Expanding, or Ignored, or try to modify sizeHint() as it seem that the policy is to respect or not respect sizeHint() value.
Sadly I can't experiment, if there is a standalone file to test, maybe I could try for a while and see how it works. It depends also on the platform, on which platform you are testing, I know that Windows and Linux are sligthly different, in some aspects.
But I don't know the translation of Pyside in FreeCAD, fo the proper "names" as the "translation" done in the PySide to PySide2 adaption for compatibility.
Regards
Carlo D.
see https://doc.qt.io/qt-5/qsizepolicy.html#detailsvoid QSizePolicy::setVerticalStretch(int stretchFactor)
Sets the vertical stretch factor of the size policy to the given stretchFactor. stretchFactor must be in the range [0,255].
When two widgets are adjacent to each other in a vertical layout, setting the vertical stretch factor of the widget on the top to 2 and the factor of widget on the bottom to 1 will ensure that the widget on the top will always be twice the size of the one on the bottom.
See also verticalStretch(), setHorizontalStretch(), and setVerticalPolicy().
sizepolicy = QtWidgets.QSizePolicy(
QtWidgets.QSizePolicy.Expanding,
QtWidgets.QSizePolicy.Expanding))
self.textEdit.setSizePolicy(sizepolicy)
Regards
Carlo D.
