Mesh decimate algorithm
gimba96
Post by gimba96 »
Hi everyone,
I'm not quite sure if this forum is the right place for this question, please forgive me if it is not ;). I have started FreeCAD lately as a preprocessor for some FEM work. I have some STL-files (order 90000 facets) that are too large to comfortably import in the FEM software. Hence I created a simple script:
import Mesh
mesh = Mesh.Mesh('myfile')
mesh.decimate(0.1, 0.5) #tolerance=0.1 and reduction=50%
mesh.write(Filename='myreducedfile', Format='STL')
I was wondering what the mesh.decimate-call actually does. Does it compare facets normals, does it just take any facet and join a number of facets to it?
Hope you can help!
Founder
Re: Mesh decimate algorithm
Post by wmayer »
Here is the paper about the theoretical background:
https://www.ri.cmu.edu/pub_files/pub2/g ... 1997_1.pdf
The reduction is performed by collapsing edges where for each steps two triangles will be eliminated. The algorithm checks beforehand if the operation can be applied (i.e. it must not produce overlapping triangles) and what error it would create.
Depending on the thresholds the algorithm reduces a lot more in rather flat areas and not so much in curved areas.
Here are some links to the actual implementation:
http://voxels.blogspot.de/2014/05/quadr ... ource.html
https://github.com/sp4cerat/Fast-Quadri ... lification
johnwang
Post by johnwang »
wmayer wrote: Wed Apr 28, 2021 8:39 am
Is there algorithm to detect surfaces on a cylinder?
hfc series CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2 and more)
Founder
Post by wmayer »
What exactly do you mean?
gimba96
Post by gimba96 »
wmayer wrote: Wed Apr 28, 2021 8:39 am Here is the paper about the theoretical background:
Alright, thank you! I will look into the paper and actual implementation! This helps a lot
johnwang
Post by johnwang »
wmayer wrote: Wed Apr 28, 2021 10:58 am What exactly do you mean?
Something like rebuilding cylinder surface from quad mesh
Founder
Post by wmayer »
So, if I got you right then you have a mesh that describes a cylinder and you want to get the exact mathematical representation of this cylinder. This process is called reverse engineering and it has nothing to do with mesh decimation.
keithsloan52
Post by keithsloan52 »
So the FreeCAD Mesh code that performs decimation is the same as sp4cerat? i.e 4 x faster than MeshLab?
Founder
Post by wmayer »
FreeCAD uses the modified sp4cerat code: https://github.com/sp4cerat/Fast-Quadri ... Simplify.h
