Property pane looses display behavior after error or message dialog
openBrain
Re: Property pane looses display behavior after error or message dialog
Post by openBrain »
chrisb wrote: Sat May 01, 2021 10:41 pm Concerning the topic: the problem doesn't occur here on MacOS.
Did you try with Property view floating or docked? I guess it only appears in floating mode (if I understand correctly the OP).
I tried it with floating. When I switch to another application, the properties tab falls even behind the FreeCAD window. As soon as I bring FreeCAD to front, the property tab seems to get an event and comes to front above the FreeCAD window.
