How to collect 2 commands into 1 command
FATHI RAMMAH
Postby FATHI RAMMAH » Tue May 04, 2021 6:27 am
hello guys
how can I write a python code to collect 2 existing commands into one command for exp(draft wire and bim slab) or (draft rectangle and arch column), or what is the python loop to check if the first command is finished then run the second command
