With Linux AppImage (0.19.2), freecadcmd doesn't execute a script anymore
qlerebours
Postby qlerebours » Thu May 06, 2021 4:05 am
Hello there,
I'm new to this community, so first, I'd like to say thank you to everyone for the job you did with freecad :)
I would need help with something, but I don't want to report it as an issue since I'm not sure that it's actually an issue. I checked and didn't find a topic or issue about this.
I downloaded the v0.19.2 AppImage from Github. Opening and editing using Freecad GUI works perfectly, however I'm interested in scripting.
On the previous version (0.18.x that I installed using the PPA with apt), I was able to run
freecadcmd myscript.py
and it was working fine.
Now, when I do
freeCad.AppImage freecadcmd myscript.py
the start message shows (the one with the ASCII text) but nothing more happens. I also tried to unpack the AppImage and use the freecadcmd file in the bin directory and it's exactly the same.
However, I can run
which opens the Python console and play my script line by line, which works well.
FreeCAD Version obtained from FreeCAD.Version():
['0', '19', '24291 (Git)', '/home/conda/feedstock_root/build_artifacts/git_cache/github.com/FreeCAD/FreeCAD', '2021/04/15 09:17:08', '(HEAD detached at 0.19.2)', '7b5e18a0759de778b74d3a5c17eba9cb815035ac']
And from the GUI:
OS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.24291 (Git) AppImage
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: French/France (fr_FR)
Do you know if it's a bug or if I do something wrong?
Thank you for you help :)
Re: With Linux AppImage (0.19.2), freecadcmd doesn't execute a script anymore
Postby chrisb » Thu May 06, 2021 5:25 am
Hi and welcome to the forum!
Please attach your full FreeCAD info as described in the forum rules.
qlerebours
Postby qlerebours » Thu May 06, 2021 5:35 am
chrisb wrote: Thu May 06, 2021 5:25 am Hi and welcome to the forum!
I edited the post, thanks
Postby chrisb » Thu May 06, 2021 6:11 am
qlerebours wrote: Thu May 06, 2021 5:35 am I edited the post, thanks
Can you access the GUI too? The FreeCAD infos in their well known form as described in the post linked above have two advantages: They include information about the libraries, and they are presented in a well known form which makes it easy for the power helpers to recognize relevant information a glance.
I may add that I am not able to help with this myself, so my remarks are to be seen as preparation for a real helper.
qlerebours
Postby qlerebours » Thu May 06, 2021 6:25 am
chrisb wrote: Thu May 06, 2021 6:11 am
I re-edited with the GUI version
