Programmatically set backup save options for Std Save
dunaden
Post by dunaden »
I'm setting up a script to auto-generate some files on a Linux server. As part of the process I'm using Std Save to save some FreeCAD files as intermediary build files (from a makefile), code snippet below for reference. This ends up with some backup .FCstd1 files being generated - I would like to avoid this.
I am aware that I can set FreeCAD to not generate these files from the GUI by setting to false this parameter:
"Tools > Edit Parameters -> BaseApp > Preferences > Document > CreateBackupFiles"
What I would like to do is set this parameter programmatically (ideally from the python interface) so that I can avoid the backup files on a headless server (potentially dockerised to be spooled up and destroyed as needed).
Any help, advice or pointing me to where I can find things myself is appreciated!
Trivial code snippet for clarity:
import FreeCAD
doc = FreeCAD.newDocument("someTrash")
doc.saveAs("~/my_file.FCstd")
# This line will create a .FCstd1 file unless the correct parameter is set in FreeCAD
And for completeness sake this is my home setup on which I'm testing things for now (and the version I'm intending to have deployed on the server which will be Ubuntu based).
OS: Linux Mint 19.3
Version: 0.18.4.
Python version: 3.6.8
Qt version: 5.9.5
Locale: English/HongKong (en_HK)
Syres
Re: Programmatically set backup save options for Std Save
Post by Syres »
Something like:
import FreeCAD
noBackupFiles = FreeCAD.ParamGet('User parameter:BaseApp/Preferences/Document')
noBackupFiles.SetBool("CreateBackupFiles", False)
dunaden
Post by dunaden »
Perfect, that's exactly what I needed - thank you so much for the prompt and succinct help!
