rotating Assy 3 model to a desired angle and back to 0deg (solved)
bambuko
Postby bambuko » Fri May 14, 2021 3:32 pm
I have an excellent macro (created by someone else - I am useless :oops: ) to animate Assy 3 model of steam loco.
It happily rotates full 360 deg, making a great animation:
but... animation, whilst nice (and I am sure impressive) doesn't do much for my design process.
I would like to be able to rotate it to a desired angle, do what I need to do at this angle, and re-set back to original.
This macro, kind of allows me to rotate to a specific desired angle (by editing macro values).
It doesn't do very well re-setting back to (what I consider) 0deg (or starting position).
Trouble is that if the rotation is less than 45deg resetting works fine, more than that and if I reset constraint angle to 0deg,
model springs back to the nearest (vertical or horizontal) axis.
This is, of course, no criticism of the current macro - it is really meant to simply animate the model,
whereas I want it to do something different...), hence the question:
Is there a better way of doing what I am trying to do, please?
macro, I am using at the moment:
Re: rotating Assy 3 model to a desired angle and back to 0deg
Postby chrisb » Fri May 14, 2021 5:17 pm
An image of the macro doesn't help as much as the macro itself.
You can create a new macro with lines 19, 20, 22 where you set the desired angle.
bambuko
Postby bambuko » Fri May 14, 2021 6:03 pm
chrisb wrote: Fri May 14, 2021 5:17 pm An image of the macro doesn't help as much as the macro itself...
sorry, having difficulty attaching anything right now, so hopefully this is OK?:
import FreeCAD
import time
angle = 0
for i in range(361):
    FreeCAD.ActiveDocument.getObject("Constraint016").Angle = angle
    Gui.runCommand('asm3CmdQuickSolve',0)
    angle -= 1
    FreeCADGui.updateGui()
    time.sleep(0.001)
# Macro End:  +++++++++++++++++++++++++++++++++++++++++++++++++
chrisb wrote: Fri May 14, 2021 5:17 pmYou can create a new macro with lines 19, 20, 22 where you set the desired angle.
Setting desired angle is the least of my problems ;)
(although not exactly clear how you suggest to do it..)
I do it at the moment using line 18.
Defining what 0deg is and being able to re-set back to it after any change is the main challenge...
edwilliams16
Postby edwilliams16 » Fri May 14, 2021 6:33 pm
FreeCAD.ActiveDocument.getObject("Constraint016").Angle = 0
doesn't reset your model? What does it do?
bambuko
Postby bambuko » Fri May 14, 2021 7:06 pm
edwilliams16 wrote: Fri May 14, 2021 6:33 pm ...doesn't reset your model? What does it do?
No, as I explained in my post, it snaps it to the nearest axis.
So, for example, if I move it to 120deg and want to re-set it to 0deg, it actually ends up at 90deg.
It works fine if the rotation is less than 45deg from 0deg(origin).
mario52
Postby mario52 » Fri May 14, 2021 7:08 pm
hi bambuko
you have time the you have this beautiful macro Macro_Rotate_To_Point
principe : all manually rotation and translation step by step mm by mm degrees by degrees
the macro create one macro with all coordinate Placement and use this macro with different options
Q to Quit
D to Decrease speed
P to Pause/Continue or key RETURN or ESCAPE
S to Step by Step
R to Reverse
M for this message
example
the macro file created and the FCStd file associated Animation Pleuel-Stangen AWB
other example
enjoy with your beautiful tchouff tchouff
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting, Dialog creation. My macros on Gist.github.
bambuko
Postby bambuko » Fri May 14, 2021 7:33 pm
mario52 wrote: Fri May 14, 2021 7:08 pm hi bambuko
:mrgreen:
Thank you mario52
I will explore your macro and if it works with my Assembly 3 model - it is precisely what I need :!:
edwilliams16
Postby edwilliams16 » Fri May 14, 2021 9:25 pm
Without a file to test on, I'm working totally blind, but the following should get past what looks to be a "flipping root" problem, by rotating one degree at a time:
angle = int(FreeCAD.ActiveDocument.getObject("Constraint016").Angle)
while angle != 0:
    angle = angle - sign(angle)
If this works we can likely speed it up by rotating in bigger chunks.
bambuko
Postby bambuko » Sat May 15, 2021 9:45 am
Thank you edwilliams16
edwilliams16 wrote: Fri May 14, 2021 9:25 pm Without a file to test on, I'm working totally blind..
If you are interested and fancy a challenge ;) I would be more than happy to put the file into some dropbox.
Used original macro to rotate things to a certain angle, and then tried your macro to rotate things back to 0deg.
(I have assumed that this was the intention? apologies if I got it wrong :oops: )
I am getting the following error message:
<class 'NameError'>: name 'sign' is not defined
edwilliams16
Postby edwilliams16 » Sat May 15, 2021 1:59 pm
Oops, sign is a numpy function, not bare python
Replace that line of code with
    angle = angle - cmp(angle, 0)
Yes this code is to zero the angle, starting anywhere. We can go the dropbox route if this doesn’t do it.
