in which sequence does FreeCAD stores an arc in the Sketcher: anti-clockwise or indifferent or...
Hi community,
I have a question about "in which sequence does FreeCAD stores an arc in the Sketcher: anti-clockwise or indifferent or...".
For mechanical calculations, I export the fundamental sketch geometry to a datafile. This datafile is the import dat file for my mechanical calculation programme.
For this, I select the sketch geometry by mouse. Basic code (using using Gui.Selection) : "sels=FreeCADGui.Selection.getSelectionEx() , selectedEdge=sels[0].SubObjects.copy()" and with "points=selectedEdge.discretize(numberOfPoints)" for getting 3 points to distinguish "line", "circle", "point" and "arc". Also for deriving the essential information such like endpoints, midpoint, radius, length.
According to my observations, the data of an arc is stored anti-clockwise. So, if I select the arc by mouse, the two end points are stored in anti-clockwise direction in my datafile. For my mechanical calculations, outside FreeCAD, this is not very handy, because the joint connection between the "mechanical elements" might get lost in my datafile. I have to sort out my pivot points in the datafile afterwards, or I only should select points in the correct sequence instead of the elementary geometry "lines, arcs".
1. Are my observations correct? Will arcs always generate points in anti-clockwise direction by using Are arcs really stored anti-clockwise, always?
2. Is it possible to let FreeCAD know at what side the arc is selected as possible solution? (Of course I can introduce Points as connection points..)
Hope, that someone knows an answer. Thank you very much.
Best regards,
John.
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Best regards,
John.
Qt version: 5.6.2
Re: in which sequence does FreeCAD stores an arc in the Sketcher: anti-clockwise or indifferent or...
I do not have a definite answer, just some experience and share my memory below, hope somebody can provide you more solid answer.
First, it may depend whether you are talking about 'Edit' mode of the Sketch or not.
I remember all 'arc' in Edit mode are 'interpreted' as anti-clockwise. But the Arc in Wire / Edge 'outside' Edit model may not be.
Seems once dig into a post by @DeepSOIC had discussed something about the topology in OCC (OpenCascade kernel).
I doubt that it is possible to change the "direction" of the arc, as the "internal representation" rely on the "trigonometric convention", so the circle and arcs are calculated anticlockwise, I'm not 100% sure for Sketcher, but the "primitive" is generated by OCCT (modeling engine of FreeCAD).
As you create sketcher geometry, the point are coincident, so if you export 3 point for the arc, you could draw it in whatever way you want in the destination program.
This image show to circle obtained using Part.ArcOfCircle(circle, start_angle, end_angle)
originating circle is the same:
- first circle (unmarked points) was generated using:
to draw the "lower part of circle", you will se the arrow showing the start point and end point of the discretized shape (16 points)
- second circle (with c2 as suffix of proints) was generated using:
And is shown as the upper part of the circle
Note the inversion of the start and ending point and the relative inversion of the coordinates of the start and end point of the discretized curve, respecting the order of the creation
Hope it helps
Carlo D.
h_cir = Part.ArcOfCircle(cir, math.pi , 0)
h_cir2 = Part.ArcOfCircle(cir, 0, math.pi)
Hope it helps
Carlo D.
- Various other stuffs.
Summarized, as far as we have all observed, the arc is created anti-clockwise. Hence, I have to find out another method.Now I'm thinking of "double click" at the "side of the start" while selecting. Of course, I have to solve the "de-selection" in that case. Also tricks like "an extra node" or "users input input("what side") are candidates for solving the inconveniences.
Thank you for your input.
In my view, we may close this submission. Thank very much. John.
Yes, very much! The mechanism is explained in that post. I learned that in most cases (but not always and when not ) the direction is counter clock wise. And probably, the post also described the solution for me.
I''m able to check the direction of the arc. In fact, I already use the direction in my code. I needed the direction for calculated the positioning of the center of the arc. So, if the selected direction is not according to the wanted selection order, I can change the selection direction in my relevant code.
Thank you very much for drawing my attention to that topic.
John.
John.
It depends you have not to calculate the center of the arc, the arc as geometric object has the centre as property it is here as it has the starting and the ending point and also radius.
If not how it could be drawn?
It's a matter of inspect object properties.
Regards
Carlo D.
Regards
Carlo D.
I Hi Carlo. Yes, you'r right. That should be the right way. But I'm not a python engineer. I'm still learning. And this forum and the FreeCAD manual are very important for me. I tried , but it didn't worked out. So, I created my own math to do the work.
speaking of circular arcs in XY plane is not difficult to calculate points, I suppose that if you use sketcher you draw in 2d and in XY.
Now I don't know very well sketcher scripting as I model mostly with Part and some Draft methods, but if you have an edge derived from a circle it's a mere writing exercise.
Plus obviously the start point and endpoint.
With some code it will be more easy .
Regards
Carlo D.
obj = arc.Curve
cent = obj.Center
rad = obj.Radius
Regards
Carlo D.
Hi Carlo. I don't know how to get it when working in the sketcher. I always get non-information. Or "no such attribute".
print("selection", sels[0].SubObjects[0])
Results in:
selection <Edge object at 00000207DBF9CDC0>
Results in:
