Generating Ortographic scetches with Python
Cyberduke
Post by Cyberduke »
HI, I am not new to python, and I have a step file, for which I need to write a python script that will generate the orthographic drawing from it automatically.
I have kinda figured out the very very basics on how to write a python script to control FreeCAD without a GUI. I also know how to see the generated python code in the Console as I do something manually in the FreeCAD gui. But copying that python code to the GUI-less version gives issues(obviously), and I am not sure how to edit it.
For instance, loading a Step file generated the following code, but running it in python gives an error(I obviously need to remove the GUI elements).
If someone can point me in the right direction I would be really happy.
import Part
from FreeCAD import Base
import ImportGui
ImportGui.open(u"/home/bot.step")
App.setActiveDocument("Unnamed")
App.ActiveDocument=App.getDocument("Unnamed")
Gui.ActiveDocument=Gui.getDocument("Unnamed")
Gui.SendMsgToActiveView("ViewFit")
Cyberduke
Re: Generating Ortographic scetches with Python
Post by Cyberduke »
Thank you for the answer, I took some time to work though that example.
Now, I need to get the "TechDraw" workbench going through python. (since that can be used to generate the Ortographic scetch.
I got this sample code, but with the error as shown:
import FreeCAD
import TechDraw
page = FreeCAD.ActiveDocument.addObject('TechDraw::DrawPage', 'Page')
FreeCAD.ActiveDocument.addObject('TechDraw::DrawSVGTemplate', 'Template')
FreeCAD.ActiveDocument.Template.Template = templateFileSpec
FreeCAD.ActiveDocument.Page.Template = FreeCAD.ActiveDocument.Template
page.ViewObject.show()
view = FreeCAD.ActiveDocument.addObject('TechDraw::DrawViewPart', 'View')
rc = page.addView(view)
AttributeError Traceback (most recent call last)
<ipython-input-43-26d9517177e2> in <module>
2 import TechDraw
3
----> 4 page = FreeCAD.ActiveDocument.addObject('TechDraw::DrawPage', 'Page')
5 FreeCAD.ActiveDocument.addObject('TechDraw::DrawSVGTemplate', 'Template')
6 FreeCAD.ActiveDocument.Template.Template = templateFileSpec
AttributeError: 'NoneType' object has no attribute 'addObject'
onekk
Post by onekk »
this will work, but as there is no a templateFileSpec i have commented the line.
import FreeCAD
import TechDraw
from FreeCAD import Rotation, Vector
FreeCAD.newDocument("test")
DOC = FreeCAD.ActiveDocument
page = DOC.addObject('TechDraw::DrawPage', 'Page')
templ = DOC.addObject('TechDraw::DrawSVGTemplate', 'Template')
#templ.Template = templateFileSpec
page.Template = DOC.Template
view = DOC.addObject('TechDraw::DrawViewPart', 'View')
As you could see the best way is to name objects using "variables" it is more simple than mimic the console output.
The code above create two document a "base" document. The lack of this document open will raise the error you reported.
the other document is the TechDraw page, for the rest as I don't know TechDraw, I've simply "translated" your code to show the "basics" of a "decent" Python programming.
Hope it helps
Carlo D.
- Various other stuffs.
Cyberduke
Post by Cyberduke »
Thank you, with the addition of commenting out
#page.ViewObject.show()
, it works. I will have to figure out the TechDraw Workbench in python now:)
I am starting to slowly understand, I modified the code to import the Step file that I have, small question, how can I export a document to for instance PDF or any format so that I can actually "see" what is currently happening and if my import was successful or correct? I anticipate it to be wrong.
import FreeCAD
import TechDraw
import Part
MyShape = Part.read(u"/home/........./bot.step")
MyShape.Volume
MyShape.Area
shapeobj = DOC.addObject("Part::Feature", "MyShape")
shapeobj.Shape = MyShape
DOC.recompute()
DOC.recompute()
onekk
Post by onekk »
You could inspect some methods using a very easy hack:
in the python console:
import Part
print(dir(Part))
same thing for a "generic object":
print(dir(obj_variable))
if there are some docstring or explanation, the same you will see as a popup in the python console, as example:
print(Part.Circle.__doc__)
willl print in the console:
Describes a circle in 3D space
To create a circle there are several ways:
Part.Circle()
    Creates a default circle with center (0,0,0) and radius 1
Part.Circle(Circle)
    Creates a copy of the given circle
Part.Circle(Circle, Distance)
    Creates a circle parallel to given circle at a certain distance
Part.Circle(Center,Normal,Radius)
    Creates a circle defined by center, normal direction and radius
Part.Circle(Point1,Point2,Point3)
    Creates a circle defined by three non-linear points
hope it helps
Regards
Carlo D.
Cyberduke
Post by Cyberduke »
Thank you, That is definitely helpful in one way, but I think you slightly misunderstood what I tried doing.
So in my code I basically tried to open a file named "bot.step" and I want to put it on the page and then print that page to PDF or something such that I can have an output.
onekk
Post by onekk »
Sorry I don't know all the method of all the wb of FreeCAD, something is exposed as Python method and you can direct use the methods to do things.
Some other things are achieved in the GUI using "commands" that are script the are run when you hit a button, or select a menu item.
If a "thing" is not exposed as a Python method, maybe you could not use it in scripting or use it in a "limited way" issuing the command, as in:
Gui.runCommand('Std_Open',0)
But you have to know what command to "issue".
Regards
Carlo D.
