Part API Euler Spirals?
HakanSeven12
Post by HakanSeven12 »
Is the part API support euler spirals? If not, can someone add it?
Re: Part API Euler Spirals?
Have a look at what the Python console shows on creation of a spiral.
HakanSeven12
Euler spiral not same thing with this one. It start from infinite radius and goes to a spesific radius like this:
https://images.app.goo.gl/awrp9aRBe8pAWKb89
or this:
https://images.app.goo.gl/UZ5g3QuDju8uvqaB8
I see, sorry for the noise. Asking for the API means that OCC supports it?
HakanSeven12
Like we can create lines circles or arcs by using api and it return a shape and we can use that shape. I want something similar for spiral
I understand what you want, but the API (=Application Programming Interface) is only an interface to some OCC functions. AFAIK these functions are not implemented natively in FreeCAD.
Chris_G
Post by Chris_G »
And a quick search didn't return any result in the OpenCascade API either ...
Chris_G: thanks for confirming.
HakanSevven12: You may have a look at the addon macro 3D_Parametric_Curve.
HakanSeven12
wmayer wrote:
What are you thinking about that?
Founder
Post by wmayer »
HakanSeven12 wrote: Sat Jun 05, 2021 6:37 am
wmayer wrote: Wed May 12, 2021 2:15 pm
While lines, circles or arcs are directly supported by OCCT this is not the case for Euler spirals. So, the only feasible way is to have a function that creates (an approximated) B-Spline curve from an Euler spiral. This function can be part of FreeCAD or a Python add-on. Are there any formulas to do the calculation?
