Looking for signals for New Document and Properties Changed
freedman
Post by freedman »
If you have a second, I searched a bunch and can't the references.
Usage: I'm running a macro and a user can change documents, I need the signal that tells me the document has changed.
Usage: I'm running a macro and a user changes Properties, I need a signal for that, I think it signals on any change of the Properties.
Here is the one for changing Workbenches if you want to trade. :)
        mw=Gui.getMainWindow()
        mw.workbenchActivated.connect(self.wbChange)
Thanks
ickby
Re: Looking for signals for New Document and Properties Changed
Post by ickby »
Dir that you need document observers. I the GUI doc observer I think I think it is this one for document change: https://github.com/FreeCAD/FreeCAD/blob ... on.h#L109
Property change is excepted by app document observers .
The way you showed in the example code is how Qt signals work. With that method you only connect to things that are provided by Qt, and hence can find in their documentation. To my knowledge freecad does not provide any custom signals.
openBrain
Post by openBrain »
ickby wrote: Fri Jun 11, 2021 11:31 am Dir that you need document observers. I the GUI doc observer I think I think it is this one for document change: https://github.com/FreeCAD/FreeCAD/blob ... on.h#L109
For sake of precision, list of slots available for a DocumentObserver added in FreeCAD namespace is here :
https://github.com/FreeCAD/FreeCAD/blob ... h#L55-L113
And for DocumentObserver added in FreeCADGui namespace:
https://github.com/FreeCAD/FreeCAD/blob ... .h#L53-L74
freedman
Post by freedman »
I need to stop doing searches and start looking more at the source code. It makes since these would be found as header files in App and GUI.
Thank you.
