MoveToOrigin macro
edwilliams16
MoveToOrigin macro
Post by edwilliams16 »
From https://forum.freecadweb.org/viewtopic. ... 30#p510397
On importing stl, step and other files, objects are sometimes inconveniently located far from the origin. This Macro allow you designate a point in the object and change the object's placement so that it is translated to the origin.
Current options, selecting, then running the macro:
One Vertex - moved to origin
A line - mid-point moved to origin
A face - CG moved to origin
A circle or circular arc - center moved to origin
(double clicking) A shape (solid, shell, compound, compsolid) - CG moved to origin
Please test in your workflow and I will attempt to debug if necessary and/or add a desirable feature. In the final version I'll put debug=False
I assume if this works and is found of interest, I should follow instructions in https://wiki.freecadweb.org/Macro_documentation
If anyone knows how to make the final line
base.move(-shift)
undoable, it would be a good addition.
EDIT. Undo implemented
__Title__    = "MoveToOrigin"
__Author__   = "edwilliams16"
__Version__  = "00.01"
__Date__     = "2021.6.15"
debug = True
'''Usage:
This macro will adjust the placement of a shape to place a selected feature at the origin.
One vertex:  - to origin
One line segment - midpoint to origin
One circle - center to origin
One arc of circle - center to origin
One face - CG of face to origin
Three vertices - center of circle through vertices to origin
Shape - CG of shape to origin
If the shape is a BaseFeature inside a body, the base feature's placement in the body is adjusted.
def circumcenter(A, B, C):
    '''Return the circumcenter of three 3D vertices'''
    a2 = (B - C).Length**2
    b2 = (C - A).Length**2
    c2 = (A - B).Length**2
    if a2 * b2 * c2 == 0.0:
        print('Three vertices must be distinct')
        return
    alpha = a2 * (b2 + c2 - a2)
    beta = b2 * (c2 + a2 - b2)
    gamma = c2 * (a2 + b2 - c2)
    return (alpha*A + beta * B + gamma * C)/(alpha + beta + gamma)
def centerofmass(subshapes):
    mass =0.0
    moment = App.Vector(0, 0, 0)
    for sh in subshapes:
        mass += sh.Volume
        moment += sh.Volume * sh.CenterOfMass
    return moment/mass
selt = Gui.Selection.getSelectionEx()
if len(selt) != 1:
    print('Select one vertex, edge or object\nor three vertices for center of circle')
    shift = App.Vector(0, 0, 0)  # bail and do nothing
else:
    sel = selt[0]
    if sel.HasSubObjects:
        vv = sel.SubObjects
        if len(vv) ==3 and vv[0].ShapeType == 'Vertex' and   vv[1].ShapeType == 'Vertex' and vv[2].ShapeType == 'Vertex':
            shift = circumcenter(vv[0].Point, vv[1].Point, vv[2].Point)
            if debug: print('Three Vertices')
        elif len(vv) == 1:
            selected = sel.SubObjects[0]
            if selected.ShapeType == 'Vertex':
                shift = selected.Point
                if debug: print('One vertex')
            elif selected.ShapeType == 'Edge':
                if selected.Curve.TypeId == 'Part::GeomCircle':    #circles and arcs
                     shift = selected.Curve.Center
                     if debug: print('One arc')
                elif selected.Curve.TypeId == 'Part::GeomLine':
                    shift = (selected.valueAt(selected.FirstParameter) + selected.valueAt(selected.LastParameter))/2 # mid-point
                    if debug: print('One line')
                else:
                    print(f'edge is {selected.Curve.TypeId} not handled')
            elif selected.ShapeType == 'Face':
                shift = selected.CenterOfMass #center of face
                if debug: print('One face')
            else:
                print(f'ShapeType {selected.ShapeType} not handled')
        else:
            print('Wrong number of Selections')
    else:
        if debug: print(f'ObjectName is {sel.ObjectName}')
        #if sel.ObjectName[0:11] == 'BaseFeature':
        if hasattr(sel.Object, 'Shape'):
            if debug: print('One solid')
            shape = sel.Object.Shape
            if shape.ShapeType == 'Solid' or shape.ShapeType == 'Shell':
                shift = shape.CenterOfMass
            elif shape.ShapeType == 'Compound' or shape.ShapeType == 'CompSolid':
                shift = centerofmass(shape.SubShapes)
            #more cases?
            else:
                print(f'Object ShapeType {sel.Object.Shape.ShapeType} not handled')
        else:
            print(f'{sel.ObjectName} is not a shape')
print(f'Shift = {shift}')
base = App.ActiveDocument.getObject(sel.ObjectName).Placement
App.ActiveDocument.openTransaction('Undo Move to Origin')
base.move(-shift)
App.ActiveDocument.commitTransaction()
Last edited by edwilliams16 on Wed Jun 16, 2021 10:44 pm, edited 2 times in total.
duckmug
Re: MoveToOrigin macro
Post by duckmug »
Hi, I attempted to test a previous version earlier and it didn't seem to actually move the line, it was rather moving the camera, if that makes sense.
I had selected the line inside sketch edit mode and ran the macro.
Maybe I am doing something wrong?
I've tried now to run your version from above and got this error:
  File "<input>", line 52
    print(f'Shift = {shift} to Undo')
SyntaxError: invalid syntax
I use the latest version of Freecad from the official freecad linux repos.
edwilliams16
It's not intended to work on sketches either in or out of edit mode. It is intended for 3D objects in 3D view. Are you somehow using an old version of FreeCAD - I can only understand the syntax error if you are using python2 not python3?
What does
import sys
sys.version
in the Python console report?
BTW, it moves the object, not the camera.
duckmug
Post by duckmug »
edwilliams16 wrote: Wed Jun 16, 2021 4:36 am It's not intended to work on sketches either in or out of edit mode. It is intended for 3D objects in 3D view. Are you somehow using an old version of FreeCAD - I can only understand the syntax error if you are using python2 not python3?
What does
import sys
sys.version
'3.8.5 (default, May 27 2021, 13:30:53) \n[GCC 9.3.0]'
edwilliams16
I suspect you may be pasting into the Python console, not running it as a macro. If so, put a blank line before the complaining print statement. The REPL doesn’t handle continuations the same as in a file.
duckmug
Post by duckmug »
Ah, I was doing that yes, never had this issue before, will keep it in mind from now and on.
Really useful by the way, I was doing this before:
obj = FreeCADGui.Selection.getSelection()[0]
shp = obj.Shape
center = shp.BoundBox.Center
m = FreeCAD.Matrix()
m.move(center * -1)
movedShape = shp.transformGeometry(m)
new_obj = App.ActiveDocument.addObject('Part::Feature', obj.Name)
new_obj.Shape = movedShape
openBrain
Post by openBrain »
edwilliams16 wrote: Wed Jun 16, 2021 2:44 am If anyone knows how to make the final line
base.move(-shift)
App.ActiveDocument.openTransaction('DESCRIPTION')
# undoable code
edwilliams16
openBrain wrote: Wed Jun 16, 2021 5:51 am App.ActiveDocument.openTransaction('Undo MoveToOrigin')
base.move(-shift)
[/code]
Hard to believe it is so simple! One minor nit. It works fine, but the tree is left with the object with a recompute check mark. It would be tidier to be rid of this, but I have not succeeded.
drmacro
Post by drmacro »
edwilliams16 wrote:
Where are you keeping the latest version?
edwilliams16
drmacro wrote: Sat Jun 19, 2021 3:17 pm
Until I get a wiki page written the OP https://forum.freecadweb.org/viewtopic. ... 50#p510458 is the latest.
It's getting untidy because there are still two threads going...
