File Name in Input Box
gsandy
Post by gsandy »
How can I modify the code below so that the image name (MyImage) is entered by an input box and "imageLocation" would return the same value as it does now?
The object is to be able to enter different image names without going into the code.
imageLocation = "E:/Freecad/Images/MyImage.jpg"
edi
Re: File Name in Input Box
Post by edi »
from PySide import QtGui
MyImage=QtGui.QInputDialog.getText(None,"Input File Name","Please input the file name")[0]
imageLocation = "E:/Freecad/Images/"+MyImage+".jpg"
heda
Post by heda »
https://pyside.github.io/docs/pyside/Py ... ialog.html
fileName, *_ = QtGui.QFileDialog.getOpenFileName(None, "Open Image", "E:/Freecad/Images", "Image Files (*.png *.jpg *.bmp)")
edited code,
was not unpacking correct,
and fileName is imageLocation (i.e. just put imageLocation instead of fileName in the above if I get your question right)
gsandy
Post by gsandy »
Thanks edi your code just how I wanted it to, great.
Thanks heda for the web link. And I would like to pursue your code further. I got it working but I don't know how to get your "fileName" incorporated into my "imageLocation", which is used else where in my code.
