for i in range(len(obj.Shape.Faces)):
face = "Face%d" % (i+1)
f = obj.Shape.getElement(face)
<class 'Part.OCCError'>: Cannot get sub-shape from empty shape
print (len(obj.Shape.Faces))
print (obj.Shape.Faces)
>>> ### Begin command Std_SendToPythonConsole
>>> obj = App.getDocument("emptyShapeIssue").getObject("cutArray3_cut")
>>> ### End command Std_SendToPythonConsole
20
[<Face object at 000001483D271D20>, <Face object at 000001483D2715A0>, <Face object at 000001483D271BA0>, <Face object at 000001483D271BE0>, <Face object at 000001483D272220>, <Face object at 000001483D2716E0>, <Face object at 000001483D271DA0>, <Face object at 000001483D271720>, <Face object at 000001483D2720E0>, <Face object at 000001483D271C20>, <Face object at 000001483D271960>, <Face object at 000001483D271E20>, <Face object at 000001483D271760>, <Face object at 000001483D271F20>, <Face object at 000001483D2718A0>, <Face object at 000001483D2719E0>, <Face object at 000001483D2713E0>, <Face object at 000001483D271420>, <Face object at 000001483D271A60>, <Face object at 000001483D271AE0>]
But I cannot get past this situation.
Can anyone help nudge me along with some suggestions?
A trimmed down macro to reproduce this is below:
import FreeCAD
from FreeCAD import Base, Rotation, Vector
import Draft
# looking into empty shape issue
def cutArrayFrom(DOC, treeLabel, arrayShape, modelShape = None,
x_inc = 20, y_inc = 10, z_inc = 0,
x_count = 2, y_count = 2, z_count = 1, use_link=True):
drftArray = Draft.make_ortho_array(arrayShape,
Vector(x_inc, 0.0, 0.0),
Vector(0.0, y_inc, 0.0),
Vector(0.0, 0.0, z_inc),
x_count, y_count, z_count, use_link)
drftArray.Fuse = True
# next seem smore use in arch wb etc...
# Draft.autogroup(drftArray)
if modelShape is None:
return drftArray
else:
cut = DOC.addObject('Part::Cut', treeLabel + '_cut')
cut.Base = modelShape
cut.Tool = drftArray
DOC.recompute
return cut
DOC_NAME = "emptyShapeIssue"
DOC = FreeCAD.activeDocument()
if DOC is None:
FreeCAD.newDocument(DOC_NAME)
FreeCAD.setActiveDocument(DOC_NAME)
else:
for obj in DOC.Objects:
DOC.removeObject(obj.Name)
# for draft array
useLink = True
# 0 create a box only --------------------------------------------------
box = DOC.addObject('Part::Box', 'Box')
box.Width = 2*156.5
box.Length = 2*155
box.Height = 19
box.Placement.Base = Vector(-156.5, -155, 0)
print (box)
print (len(box.Shape.Faces))
print (box.Shape.Faces)
# 0 end ----------------------------------------------------------------
# 1 cut cyl array ------------------------------------------------------
cyl = DOC.addObject('Part::Cylinder', 'oneCylinder')
cyl.Radius = 2.5
cyl.Height = 30
cyl.Angle = 360
cyl.Placement.Base = Vector(-25, -15, 0)
cutArray1 = cutArrayFrom(DOC, 'cutArray1', cyl, box, 30.0, 20.0, 0.0, 2, 3, useLink)
DOC.recompute()
print (cutArray1)
print (cutArray1.Shape)
print (len(cutArray1.Shape.Faces))
print (cutArray1.Shape.Faces)
# 1 end ----------------------------------------------------------------
#2 more cyls
cyl2 = DOC.addObject('Part::Cylinder', 'cyl2')
cyl2.Radius = 2.5
cyl2.Height = 30
cyl2.Angle = 360
cyl2.Placement.Base = Vector(-65, -55, 0)
cutArray2 = cutArrayFrom(DOC, 'cutArray2', cyl2, cutArray1, 30.0, 20.0, 0.0, 2, 2, useLink)
DOC.recompute
print (cutArray2)
print (cutArray2.Shape)
print (len(cutArray2.Shape.Faces))
print (cutArray2.Shape.Faces)
# 2 end ----------------------------------------------------------------
# 3 cut cyl array ------------------------------------------------------
some_cyl = DOC.addObject('Part::Cylinder', 'oneCylinder')
some_cyl.Radius = 6
some_cyl.Height = 30
some_cyl.Angle = 360
some_cyl.Placement.Base = Vector(-100, -100, 0)
cutArray3 = cutArrayFrom(DOC, 'cutArray3', some_cyl, cutArray2, 20, 25, 0, 2, 2, useLink)
DOC.recompute
print('printing just created var/props')
print (cutArray3)
print (cutArray3.Shape)
print (len(cutArray3.Shape.Faces))
print (cutArray3.Shape.Faces)
for i in range(22):
f = cutArray3.Shape.getElement(face)
print(f)
# print('printing info from App.getDocument().getObject .. as per send to console')
# sh = App.getDocument(DOC_NAME).getObject("cutArray3_cut")
# print (sh)
# print (len(sh.Shape.Faces))
# print (sh.Shape.Faces)
# f = sh.Shape.getElement('Face1')
# f1 = cutArray3.Shape.getElement('Face1')
# 3 end --------------------------------------------------------------------
# console script to make solid - works in console, fails here
# __s__=Part.Solid(Part.Shell(__s__))
# <class 'Part.OCCError'>: Shape is null
### Begin command Part_MakeSolid
# import Part
# __s__=App.ActiveDocument.cutArray3_cut.Shape.Faces
# __o__=App.ActiveDocument.addObject("Part::Feature","cutArray3_cut_solid")
# __o__.Label="cutArray3_cut (Solid)"
# __o__.Shape=__s__
# del __s__, __o__
# sld = App.getDocument("emptyShapeIssue").getObject("cutArray3_cut_solid")
# print (sld)
# print (len(sld.Shape.Faces))
# print (sld.Shape.Faces)
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
