Some time ago, i have seen a page that describes the python use of automatic dimensioning with update on recompute.
Sorry, i have forgotten the page.
Can anybody help?
Kind regards,
Jack - not really
Auto dim in 3D and Viewer
Re: Auto dim in 3D and Viewer
Are you meaning a Draft wb dimension in linked mode? E.g click Draft Dimension icon, press and hold the Alt key, then select an edge. Draft dimension will appear and be linked to that edge and auto update if the edge is changed.
You can use Draft Dimension from a script or the GUI.
this is a link to the page on the wiki
http://www.freecadweb.org/wiki/index.ph ... _Dimension
Jim
Jim
sorry, I didn't mean that.
It was an example where dimension was created in 3D and auto updated in all 2D projection in the svg view.
In the Python window you can get mouse tips from the pop-up help
for example the code below makes a dimension on a default Part Box I had in my model
when you type the dot after Draft on the second line, the function browser will pop up, hold the mouse above the item you want and a mouse tip will pop up.
If you put one of these dimensions in a Drawing in Drawing workbench or from Draft WB, you get a dimension in your Drawing that will auto update along with the dimension in your model which in its self will auto up date when the relevant Part Box parameter is changed.
The Python code to put an item in the Drawing is explained in the wiki just search "Drawing" and look at the Drawing module page. I this is the URL to the wiki page.
http://www.freecadweb.org/wiki/index.ph ... ing_Module
I don't know what version of FreeCAD you are working with , but there has been quite a few updates in these areas you are talking about since 0.13 and the Drawing module is currently being actively developed. So expect changes and complications etc.
Jim
import Draft
>>> Draft.makeDimension(FreeCAD.ActiveDocument.Box,2,0,FreeCAD.Vector(-2.32557463646,5.0,0.0))
Jim
