I did some work on your macro so it now handles objects in nested part containers. I thought it would be really easy - but of course it was more complicated than I anticipated. Placing the text correctly was convoluted...
# -*- coding: utf-8 -*-
from __future__ import unicode_literals
# cette macro trace en rouge (modifiable) le tour du boundingbox avec 6 rectangles
# si "createVol" = 1 il sera cree un volume (rouge) de la dimension du BoundBox
# this macro red trace (editable) around the BoundingBox with 6 rectangles
# if "createVol" = 1 on volume (red) is created
# Macro_BoundingBox_Tracing
#OS: Windows Vista #OS: Windows 8.1 #OS: Windows 10 #OS: Windows 10
#Platform: 32-bit #Word size of OS: 64-bit #Word size of OS: 64-bit #Word size of OS: 64-bit
#Version: 0.14.3389 #Word size of FreeCAD: 64-bit #Word size of FreeCAD: 64-bit #Word size of FreeCAD: 64-bit
#Python version: 2.6.2 #Version: 0.15.4671 (Git) #Version: 0.16.6700 (Git) #Version: 0.17.13528 (Git)
#Qt version: 4.5.2 #Branch: releases/FreeCAD-0-15 #Build type: Release #Build type: Release
#Coin version: 3.1.0 #Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c #Branch: releases/FreeCAD-0-16 #Branch: releases/FreeCAD-0-17
#SoQt version: 1.4.1 #Python version: 2.7.8 #Hash: 7b925d11aa69ac405b423635adb1e2833f18a817 #Hash: 5c3f7bf8ec51e2c7187789f7edba71a7aa82a88b
#OCC version: 6.5.1 #Qt version: 4.8.6 #Python version: 2.7.8 #Python version: 2.7.14
# #Coin version: 4.0.0a #Qt version: 4.8.6 #Qt version: 4.8.7
# #OCC version: 6.8.0.oce-0.17 #Coin version: 4.0.0a #Coin version: 4.0.0a
# #OCC version: 6.8.0.oce-0.17 #OCC version: 7.2.0
#OS: Windows 10 (10.0)
#Version: 0.19.16624 (Git)
#Branch: master
#Hash: 222ae7305fdf1097e4ef3d050f69dff47dbd8786
#Python version: 3.6.8
#Qt version: 5.12.1
#OCC version: 7.3.0
#modified by edwilliams16 to handle objects in nested part containers
__title__ = "BoundingBox_Tracing"
__author__ = "Mario52"
__url__ = "http://www.freecadweb.org/index-fr.html"
__Wiki__ = "https://www.freecadweb.org/wiki/Macro_BoundingBox_Tracing"
__version__ = "0.12"
__date__ = "2021/07/10" # YYYY/MM/DD
import PySide
import FreeCAD, FreeCADGui, Draft, Part
App = FreeCAD
debug = False
if debug:
from sys import path
sys.path.append('/Users/ed/opt/anaconda3/lib/python3.7/site-packages')
import ptvsd
print("Waiting for debugger attach")
# 5678 is the default attach port in the VS Code debug configurations
ptvsd.enable_attach(address=('localhost', 5678), redirect_output=True)
ptvsd.wait_for_attach()
##### Section configuration begin ##################
##### for volume begin ###################
createVol = 1 # give 1 for create Volume # mettre a 1 pour creer un volume
createDimVol = 1 # 1 = create dimension info : 0 = not dimension info
##### for volume end ###################
##### for dimensions info begin ##########
createDim = 1 # 1 = create dimension info : 0 = not create dimension info
if int(FreeCAD.Version()[1]) > 17: # Version de FreeCAD
DisplayModeText = str(u"3D text") # available : u"2D text" or u"3D text"
else:
DisplayModeText = str(u"Screen") # available : u"Screen" or u"World"
JustificationText = str(u"Center") # available : "Center" or "Left" or "Right"
FontSizeText = 3.0 # text info dimension
TextColorText_R = 0.0 # text color info red 1 = 255
TextColorText_G = 0.0 # text color info green 1 = 255
TextColorText_B = 0.0 # text color info blue 1 = 255
arondi = 3 # round the info ex: 3 = 3 decimals
##### for dimensions info end ##########
##### Section configuration end ####################
def adjustedGlobalPlacement(obj, locVector):
'''find global placement to make locVector the local origin with the correct orientation'''
try:
objectPlacement = obj.Shape.Placement
objectGlobalPlacement = obj.getGlobalPlacement()
locPlacement = App.Placement(locVector, App.Rotation(App.Vector(1,0,0),0))
return objectGlobalPlacement.multiply(objectPlacement.inverse()).multiply(locPlacement)
except Exception:
return locPlacement # what should be here?
sel = FreeCADGui.Selection.getSelection()
selEx = FreeCADGui.Selection.getSelectionEx()
objs = [selobj.Object for selobj in selEx]
if len(objs) >= 1:
if hasattr(objs[0], "Shape"):
s = objs[0].Shape
elif hasattr(objs[0], "Mesh"): # upgrade with wmayer thanks #http://forum.freecadweb.org/viewtopic.php?f=13&t=22331
s = objs[0].Mesh
elif hasattr(objs[0], "Points"):
s = objs[0].Points
try:
# LineColor
red = 1.0 # 1 = 255
green = 0.0 #
blue = 0.0 #
# boundBox
boundBox_ = s.BoundBox
boundBoxLX = boundBox_.XLength
boundBoxLY = boundBox_.YLength
boundBoxLZ = boundBox_.ZLength
boundBoxXMin = boundBox_.XMin
boundBoxYMin = boundBox_.YMin
boundBoxZMin = boundBox_.ZMin
boundBoxLocation = App.Vector(boundBox_.XMin,boundBox_.YMin,boundBox_.ZMin)
nameLabel = sel[0].Label
try:
import unicodedata
nameLabel = str(unicodedata.normalize('NFKD', nameLabel).encode('ascii','ignore'))[2:]
except Exception:
None
# if objs[0].getParentGeoFeatureGroup() == None: Need this test somewhere?
App.Console.PrintMessage(str(boundBox_)+"\r\n")
App.Console.PrintMessage("Rectangle : "+str(boundBoxLX)+" x "+str(boundBoxLY)+" x "+str(boundBoxLZ)+"\r\n")
if (createVol == 1) and (boundBoxLX > 0) and (boundBoxLY > 0) and (boundBoxLZ > 0): # Create Volume
BDvol = App.ActiveDocument.addObject("Part::Box",nameLabel + "_BoundBoxVolume")
#BDvol.Label = "BoundBoxVolume"
BDvol.Length.Value = boundBoxLX
BDvol.Width.Value = boundBoxLY
BDvol.Height.Value = boundBoxLZ
BDvol.Placement = adjustedGlobalPlacement(objs[0], boundBoxLocation)
BDPl = BDvol.Placement
oripl_X=BDvol.Placement.Base.x
oripl_Y=BDvol.Placement.Base.y
oripl_Z=BDvol.Placement.Base.z
#if debug: print(f'global {globalObjectPlacement}\n local {localObjectPlacement} BB {BBlocPlacement}')
FreeCADGui.ActiveDocument.getObject(BDvol.Name).LineColor = (red, green, blue)
FreeCADGui.ActiveDocument.getObject(BDvol.Name).PointColor = (red, green, blue)
FreeCADGui.ActiveDocument.getObject(BDvol.Name).ShapeColor = (red, green, blue)
FreeCADGui.ActiveDocument.getObject(BDvol.Name).Transparency = 80
App.Console.PrintMessage(nameLabel + "_BoundBoxVolume : " + str(BDvol.Shape.Volume)+"\r\n")
if createDimVol == 1: # section create dimension info for volume
conteneurVol = []
del conteneurVol[:]
conteneurVol = App.activeDocument().addObject("App::DocumentObjectGroup",nameLabel + "_BoundBoxVolume_Info")
#pl_0C1 = Draft.make_text([str(round(boundBoxLX,arondi))],point=FreeCAD.Vector(oripl_X + (boundBoxLX/2), oripl_Y, oripl_Z))
pl_0C1 = Draft.make_text([str(round(boundBoxLX,arondi))],placement = BDPl.multVec(App.Vector(boundBoxLX/2,0,0)))
pl_0C1.ViewObject.DisplayMode = DisplayModeText
pl_0C1.ViewObject.Justification = JustificationText
pl_0C1.ViewObject.TextColor = (TextColorText_R, TextColorText_G, TextColorText_B)
pl_0C1.ViewObject.FontSize = FontSizeText
pl_0C1.Label = nameLabel + "_Volume_X_" + str(round(boundBoxLX,arondi))
conteneurVol.addObject(pl_0C1)
#pl_0C2 = Draft.make_text([str(round(boundBoxLY,arondi))],point=FreeCAD.Vector(oripl_X, oripl_Y + (boundBoxLY/2), oripl_Z))
pl_0C2 = Draft.make_text([str(round(boundBoxLY,arondi))],placement = BDPl.multVec(App.Vector(0, boundBoxLY/2, 0)))
pl_0C2.ViewObject.DisplayMode = DisplayModeText
pl_0C2.ViewObject.Justification = JustificationText
pl_0C2.ViewObject.TextColor = (TextColorText_R, TextColorText_G, TextColorText_B)
pl_0C2.ViewObject.FontSize = FontSizeText
pl_0C2.Label = nameLabel + "_Volume_Y_" + str(round(boundBoxLY,arondi))
conteneurVol.addObject(pl_0C2)
#pl_0C3 = Draft.make_text([str(round(boundBoxLZ,arondi))],placement=FreeCAD.Vector(oripl_X, oripl_Y, oripl_Z + (boundBoxLZ/2)))
pl_0C3 = Draft.make_text([str(round(boundBoxLZ,arondi))],placement = BDPl.multVec(App.Vector(0, 0, boundBoxLZ/2)))
pl_0C3.ViewObject.DisplayMode = DisplayModeText
pl_0C3.ViewObject.Justification = JustificationText
pl_0C3.ViewObject.TextColor = (TextColorText_R, TextColorText_G, TextColorText_B)
pl_0C3.ViewObject.FontSize = FontSizeText
pl_0C3.Label = nameLabel + "_Volume_Z_" + str(round(boundBoxLZ,arondi))
conteneurVol.addObject(pl_0C3)
# else:
# App.Console.PrintMessage("Not Volume BoundBox possible"+"\r\n")
App.Console.PrintMessage("_____________________"+"\r\n")
conteneurRectangle = []
del conteneurRectangle[:]
conteneurRectangle = App.activeDocument().addObject("App::DocumentObjectGroup",nameLabel + "_BoundBoxRectangle")
if createDim == 1: # conteneur dimension info
conteneurInfo = []
del conteneurInfo[:]
conteneurInfo = App.activeDocument().addObject("App::DocumentObjectGroup",nameLabel + "_BoundBoxRectangle_Info")
try:
if (boundBoxLX and boundBoxLY) > 0.0:
#pl_0 = App.Placement(App.Vector(oripl_X,oripl_Y,oripl_Z), App.Rotation(0.0,0.0,0.0))
pl_0 = adjustedGlobalPlacement(objs[0], boundBoxLocation)
double = Draft.makeRectangle(length=boundBoxLX,height=boundBoxLY,placement=pl_0,face=False,support=None) #OK
double.Label = nameLabel + "_BoundBoxRectangle_Bo"
FreeCADGui.activeDocument().activeObject().LineColor = (red, green, blue)
conteneurRectangle.addObject(double)
# else:
# App.Console.PrintError("not value 0"+"\n")
if createDim == 1: # section create dimension info
#pl_0C1 = Draft.make_text([str(round(boundBoxLX,arondi))],placement=FreeCAD.Vector(pl_0.Base.x + (boundBoxLX/2), pl_0.Base.y, pl_0.Base.z))
# XY -> XY
pl_0C1 = Draft.make_text([str(round(boundBoxLX,arondi))],placement=pl_0.multVec(App.Vector(boundBoxLX/2, 0, 0)))
pl_0C1.Label = nameLabel + "_Rectangle_Bo_0X_" + str(round(boundBoxLX,arondi))
conteneurInfo.addObject(pl_0C1)
#pl_0C2 = Draft.make_text([str(round(boundBoxLY,arondi))],placement=FreeCAD.Vector(pl_0.Base.x, pl_0.Base.y + (boundBoxLY/2), pl_0.Base.z))
pl_0C2 = Draft.make_text([str(round(boundBoxLY,arondi))],placement=pl_0.multVec(App.Vector(0., boundBoxLY/2, 0.)))
pl_0C2.Label = nameLabel + "_Rectangle_Bo_0Y_" + str(round(boundBoxLY,arondi))
conteneurInfo.addObject(pl_0C2)
except:
App.Console.PrintError("not done 0"+"\n")
try:
#pl_1 = App.Placement(App.Vector(oripl_X,oripl_Y,oripl_Z+boundBoxLZ), App.Rotation(0.0,0.0,0.0))
pl_1 =adjustedGlobalPlacement(objs[0], boundBoxLocation + App.Vector(0,0,boundBoxLZ))
double = Draft.makeRectangle(length=boundBoxLX,height=boundBoxLY,placement=pl_1,face=False,support=None) #Ok
double.Label = nameLabel + "_BoundBoxRectangle_To"
# else:
# App.Console.PrintError("not value 1"+"\n")
#pl_0C1 = Draft.make_text([str(round(boundBoxLX,arondi))],placement=FreeCAD.Vector(pl_1.Base.x + (boundBoxLX/2), pl_1.Base.y, pl_1.Base.z))
#XY -> XY
pl_0C1 = Draft.make_text([str(round(boundBoxLX,arondi))],placement=pl_1.multVec(App.Vector(boundBoxLX/2, 0, 0)))
pl_0C1.Label = nameLabel + "_Rectangle_To_1X_" + str(round(boundBoxLX,arondi))
#pl_0C2 = Draft.make_text([str(round(boundBoxLY,arondi))],placement=FreeCAD.Vector(pl_1.Base.x, pl_1.Base.y + (boundBoxLY/2), pl_1.Base.z))
pl_0C2 = Draft.make_text([str(round(boundBoxLY,arondi))],placement=pl_1.multVec(App.Vector(0., boundBoxLY/2, 0)))
pl_0C2.Label = nameLabel + "_Rectangle_To_1Y_" + str(round(boundBoxLY,arondi))
except:
App.Console.PrintError("not done 1"+"\n")
try:
if (boundBoxLX and boundBoxLZ) > 0.0:
#pl_2 = App.Placement(App.Vector(oripl_X,oripl_Y,oripl_Z), App.Rotation(0.0,0.0,90))
pl_2 = pl_0.multiply(App.Placement(App.Vector(0.,0.,0.),App.Rotation(0.0,0.0,90)))
double = Draft.makeRectangle(length=boundBoxLX,height=boundBoxLZ,placement=pl_2,face=False,support=None) #Ok
double.Label = nameLabel + "_BoundBoxRectangle_Fr"
# else:
# App.Console.PrintError("not value 2"+"\n")
#pl_0C1 = Draft.make_text([str(round(boundBoxLX,arondi))],placement=FreeCAD.Vector(pl_2.Base.x + (boundBoxLX/2), pl_2.Base.y, pl_2.Base.z))
#XZ -> XY
pl_0C1 = Draft.make_text([str(round(boundBoxLX,arondi))],placement=pl_2.multVec(App.Vector(boundBoxLX/2, 0, 0)))
pl_0C1.Label = nameLabel + "_Rectangle_Fr_2X_" + str(round(boundBoxLX,arondi))
#pl_0C2 = Draft.make_text([str(round(boundBoxLZ,arondi))],placement=FreeCAD.Vector(pl_2.Base.x, pl_2.Base.y, pl_2.Base.z + (boundBoxLZ/2)))
pl_0C2 = Draft.make_text([str(round(boundBoxLZ,arondi))],placement=pl_2.multVec(App.Vector(0, boundBoxLZ/2, 0)))
pl_0C2.Label = nameLabel + "_Rectangle_Fr_2Z_" + str(round(boundBoxLZ,arondi))
except:
App.Console.PrintError("not done 2"+"\n")
try:
#pl_3 = App.Placement(App.Vector(oripl_X,oripl_Y+boundBoxLY,oripl_Z), App.Rotation(0.0,0.0,90))
pl_3 = adjustedGlobalPlacement(objs[0], boundBoxLocation+App.Vector(0, boundBoxLY, 0)).multiply(App.Placement(App.Vector(0.,0.,0.),App.Rotation(0.0,0.0,90)))
double = Draft.makeRectangle(length=boundBoxLX,height=boundBoxLZ,placement=pl_3,face=False,support=None) #Ok
double.Label = nameLabel + "_BoundBoxRectangle_Re"
# else:
# App.Console.PrintError("not value 3"+"\n")
#XZ -> XY
pl_0C1 = Draft.make_text([str(round(boundBoxLX,arondi))],placement=pl_3.multVec(App.Vector(boundBoxLX/2, 0, 0)))
pl_0C1.Label = nameLabel + "_Rectangle_Re_3X_" + str(round(boundBoxLX,arondi))
pl_0C2 = Draft.make_text([str(round(boundBoxLZ,arondi))],placement=pl_3.multVec(App.Vector(0, boundBoxLZ/2, 0)))
pl_0C2.Label = nameLabel + "_Rectangle_Re_3Z_" + str(round(boundBoxLZ,arondi))
except:
App.Console.PrintError("not done 3"+"\n")
try:
if (boundBoxLY and boundBoxLZ) > 0.0:
#pl_4 = App.Placement(App.Vector(oripl_X,oripl_Y,oripl_Z), App.Rotation(90,0.0,90))
pl_4 = pl_0.multiply(App.Placement(App.Vector(0.,0.,0.),App.Rotation(90,0,90)))
double = Draft.makeRectangle(length=boundBoxLY,height=boundBoxLZ,placement=pl_4,face=False,support=None) #Ok
double.Label = nameLabel + "_BoundBoxRectangle_Le"
# else:
# App.Console.PrintError("not value 4"+"\n")
#pl_0C1 = Draft.make_text([str(round(boundBoxLY,arondi))],placement=FreeCAD.Vector(pl_4.Base.x, pl_4.Base.y + (boundBoxLY/2), pl_4.Base.z))
#YZ ->XY
pl_0C1 = Draft.make_text([str(round(boundBoxLY,arondi))],placement=pl_4.multVec(App.Vector(boundBoxLY/2, 0., 0.)))
pl_0C1.Label = nameLabel + "_Rectangle_Le_4Y_" + str(round(boundBoxLY,arondi))
#pl_0C2 = Draft.make_text([str(round(boundBoxLZ,arondi))],placement=FreeCAD.Vector(pl_4.Base.x, pl_4.Base.y, pl_4.Base.z + (boundBoxLZ/2)))
pl_0C2 = Draft.make_text([str(round(boundBoxLZ,arondi))],placement=pl_4.multVec(App.Vector(0., boundBoxLZ/2, 0)))
pl_0C2.Label = nameLabel + "_Rectangle_Le_4Z_" + str(round(boundBoxLZ,arondi))
except:
App.Console.PrintError("not done 4"+"\n")
try:
#pl_5 = App.Placement(App.Vector(oripl_X+boundBoxLX,oripl_Y,oripl_Z), App.Rotation(90,0.0,90))
pl_5 = adjustedGlobalPlacement(objs[0], boundBoxLocation+App.Vector(boundBoxLX,0,0)).multiply(App.Placement(App.Vector(0.,0.,0.),App.Rotation(90,0.0,90)))
double = Draft.makeRectangle(length=boundBoxLY,height=boundBoxLZ,placement=pl_5,face=False,support=None) #Ok
double.Label = nameLabel + "_BoundBoxRectangle_Ri"
# else:
# App.Console.PrintError("not value 5"+"\n")
#YZ-> XY
pl_0C1 = Draft.make_text([str(round(boundBoxLY,arondi))],placement=pl_5.multVec(App.Vector(boundBoxLY/2, 0, 0)))
pl_0C1.Label = nameLabel + "_Rectangle_Ri_5Y_" + str(round(boundBoxLY,arondi))
pl_0C2 = Draft.make_text([str(round(boundBoxLZ,arondi))],placement=pl_5.multVec(App.Vector(0, boundBoxLZ/2, 0 )))
pl_0C2.Label = nameLabel + "_Rectangle_Ri_5Z_" + str(round(boundBoxLZ,arondi))
except:
App.Console.PrintError("not done 5"+"\n")
except Exception:
App.Console.PrintError("Bad selection"+"\n")
else:
App.Console.PrintMessage("Select an object !"+"\n")
There was one test in your code that didn't end up in my control flow - I wasn't sure what it was for.
My test model was not complicated, so you might want to try it on yours.
It's in a git archive on my computer, I can push it to github if that is more convenient for you.
