[Bug] even if the Group property is set readonly, dragging is allowed
flachyjoe
Post by flachyjoe »
Context:
class StaticGroup:
    def __init__(self, obj, children):
        obj.Proxy = self
        self.Type = "MyObject"
        self.children = children
        obj.Group = children
        obj.setPropertyStatus('Group', 'ReadOnly')
obj = App.ActiveDocument.addObject('App::DocumentObjectGroupPython', 'MyStaticGroup')
StaticGroup(obj, children)
Expected result:
Dragging an object in the StaticGroup shouldn't change the Group property and fail
Observed result:
Dragging change the Group property, an object can be add or a child can be removed.
Workaround:
class StaticGroup:
        obj.Proxy = self
    def onChanged(self, fp, prop):
        if str(prop) == 'Group':
            fp.Group = self.children
OS: Ubuntu 21.04 (XFCE/xubuntu)
Version: 0.20.25207 (Git)
Build type: Unknown
Hash: e73ddda1b704fb602e1528efbf860862f51b9a3b
Python version: 3.9.5
Qt version: 5.15.2
OCC version: 7.5.2
Locale: French/France (fr_FR)
- Flachy Joe -
ickby
Re: [Bug] even if the Group property is set readonly, dragging is allowed
Post by ickby »
Read-only for a property does only apply for the property editor. It does not prevent any programmatic change of the property, neither by python, c++ or even other UI elements like Dialogs etc.
Drag and drop as a UI feature is controlled by the viewprovider. There you can define if drag and drop is supported, and what to do on a drop. For this override the filling functions:
canDragObjects() --> return true/false for enable/disable
canDragObject(obj) --> same for individual objects
dragObject(obj) --> when object is draged by the user
As a side note: if you want to make a property really unchangeable, you need to set it to immutable (possible since 0.19). If I remember this works by using
setPropertyStatus
. the method has good documentation on how-to do it.
But I would expect strange behaviour in the sense, that the UI feedback would show the user to allow drag and drop, but nothing would be changed and only an error printed.
flachyjoe
Post by flachyjoe »
Thank you ickby for the clarification.
UI reacts anyway on read-only properties with removing of spin buttons and other three-dots ones and blocks text editing so it's disappointing to allow drag and drop.
- Flachy Joe -
ickby
Post by ickby »
Drag and drop is a universal implementarion, detailed by the document objects. It has no idea, what a group property is, or how it influences drag and drop. So it is understandable that it cannot react on the read only status.
