I added some custom properties to the objects, but I'm seeing some weird behaviour when reloading the objects from a file:
- One of the properties is of type App::PropertyPrecision that is initialized to receive positive and negative numbers. As soon as the object is created the property works fine, but when the file is reopened, the property will only accept positive numbers.
- The other problem is similar, but in this case the property is of type App::PropertyQuantity , where I'm assigning a custom units of 1/mm. Again in this case, when the object is created the property works fine, but when the file is reopened, the property looses the unit (only the number appears).
I have tested the same code in:
OS: Pop!_OS 21.04 (MATE/mate)
Version: 0.19.
Python version: 3.9.2
Qt version: 5.15.2
OCC version: 7.5.1
Locale: Spanish/Colombia (es_CO)
and in:
OS: Debian GNU/Linux 10 (buster) (X-Cinnamon/cinnamon)
Version: 0.20.25261 (Git)
Build type: Unknown
Hash: 138144d88e0c2310ac710ffcf574c4d2ca66ba6a
Python version: 3.7.3
Qt version: 5.11.3
With the same results.
