Mod folder VS pivy module!
abghrnjd
Post by abghrnjd »
I'm writing a macro in VScode as an external editor. I use a .env file to introduce modules to VScode:
FREECAD_LIB=C:\Program Files\FreeCAD 0.19\bin
FREECAD_LIB_two=C:\Program Files\FreeCAD 0.19\lib
FREECAD_LIB_three=C:\Program Files\FreeCAD 0.19\Ext
FREECAD_LIB_four=C:\Program Files\FreeCAD 0.19\bin\Lib
FREECAD_MOD=C:\Program Files\FreeCAD 0.19\Mod
FREECAD_MOD_two=C:\Users\Abbas\AppData\Roaming\FreeCAD\Mod\A2plus
FREECAD_STUBS=C:\Program Files\FreeCAD 0.19\freecad-stubs-master\out
PYTHONPATH=${FREECAD_LIB};${FREECAD_LIB_two};${FREECAD_LIB_three};${FREECAD_LIB_four};${FREECAD_MOD};${FREECAD_MOD_two};${FREECAD_STUBS};${PYTHONPATH}
I also need to import pivy into my code some where:
from pivy import coin
this means I have to add this line to .env file!
C:\Program Files\FreeCAD 0.19\bin\Lib\site-packages
as FREECAD_LIB_five
BUT when I add this line, FreeCAD Gui doesn't show up, Nothing happens! my whole code doesn't run any more!
How can I solve this paradox?
abghrnjd
Re: Mod folder VS pivy module!
Post by abghrnjd »
I copied the whole pivy folder into mod folder. it Solved the problem. VS code finds it there!
edwilliams16
Post by edwilliams16 »
What does the .env file do for you? Does it get completion working? I've not managed that. Where else do those environment variables you define appear?
I imagine soft-linking into your Mod directory would also work and be tidier.
abghrnjd
Post by abghrnjd »
edwilliams16 wrote: Mon Jul 19, 2021 8:52 pm What does the .env file do for you? Does it get completion working? I've not managed that. Where else do those environment variables you define appear?
I'd never heard of soft/hard linking! looks like a great idea. :idea:
How is it possible on Freecad installed in windows?
edwilliams16
Symlinks how been in Unix since Day 1 - and since under the hood OSX is Unix, it's there on Macs. I'm not very familiar with Windows, but a quick google gave https://www.maketecheasier.com/create-s ... windows10/
HakanSeven12
Post by HakanSeven12 »
Maybe you can create a tutorial about VScode-FreeCAD.
abghrnjd
Post by abghrnjd »
HakanSeven12 wrote: Tue Jul 20, 2021 5:50 am Maybe you can create a tutorial about VScode-FreeCAD.
It's a good challenge, very tempting to learn, but a real pain in the neck to implement... countless, complicated errors rise up when you start. you must have a good knowledge in programming to be comfortable with this approach. I know very little.
