[Features Requests] Sketcher Radius/Diameter presentation
- Shalmeneser
In Sketcher, Radius/Diameter dimensions are written horizontally.
Would it be possible to write them (slightly) sloped (at creation) to discriminate them from horizontal dimensions ?
Re: [Features Requests] Sketcher Radius/Diameter presentation
+1Shalmeneser wrote: ↑Tue Jul 20, 2021 10:33 am In Sketcher, Radius/Diameter dimensions are written horizontally.
I am not sure if the first request was for the text or the lines of the dimension, but
I would certainly vote for ensuring the initial dimension line to be at a slight
angle. I am often having to move it see horizontal lines (geometry/axis/construction)
hidden when it is inserted.
Regards
Regards
It's both. I understand the feature request doing automatically what I usually do manually: rotate the dimension at least a little bit off horizontal. How about 10°?
- Shalmeneser
The text is always parallel to the line.
Exactly.
but what about adding R or ø prefix if it's possible?
Thank you for the clarication.
1) Agreed 10-15degrees sounds good
2) Ideally allow the option to have dia/rad dims shown
horizontally as well as in line.
3) Support ø/R
Best Wishes
3) Support ø/R
Best Wishes
- Shalmeneser
At left : today !
At right : tomorrow ? (without the blue arc, just for your information)
- Snip macro screenshot-593d7f.png (33.66 KiB) Viewed 2485 times
I think 10 degree might not be enough for my taste. I like what Shalmesener did.
Regards / Viele Grüße
Max
Max
