[solved] Wiki dialog example broken?
jdm
Post by jdm »
I'm beginning with scripting, but the example at https://wiki.freecadweb.org/Dialog_creation which I have copied below does not open any window or produce any visible effect. Note, script indentation is missing in this post but correct on my computer.
Can anyone tell if there is some issue with the example above? Or link another basic input form dialog example known to be working. Thanks.
OS: Fedora 34 (Workstation Edition) (GNOME/gnome)
Version: 0.19.Unknown
Build type: Unknown
Python version: 3.9.4
Qt version: 5.15.2
OCC version: 7.5.0
from PySide import QtCore, QtGui
import FreeCAD, Part
class Ui_Dialog(object):
def setupUi(self, Dialog):
Dialog.setObjectName("Dialog")
Dialog.resize(187, 178)
self.title = QtGui.QLabel(Dialog)
self.title.setGeometry(QtCore.QRect(10, 10, 271, 16))
self.title.setObjectName("title")
self.label_width = QtGui.QLabel(Dialog)
self.label_width.setGeometry(QtCore.QRect(10, 50, 57, 16))
self.label_width.setObjectName("label_width")
self.label_height = QtGui.QLabel(Dialog)
self.label_height.setGeometry(QtCore.QRect(10, 90, 57, 16))
self.label_height.setObjectName("label_height")
self.width = QtGui.QLineEdit(Dialog)
self.width.setGeometry(QtCore.QRect(60, 40, 111, 26))
self.width.setObjectName("width")
self.height = QtGui.QLineEdit(Dialog)
self.height.setGeometry(QtCore.QRect(60, 80, 111, 26))
self.height.setObjectName("height")
self.create = QtGui.QPushButton(Dialog)
self.create.setGeometry(QtCore.QRect(50, 140, 83, 26))
self.create.setObjectName("create")
self.retranslateUi(Dialog)
QtCore.QObject.connect(self.create,QtCore.SIGNAL("pressed()"),self.createPlane)
QtCore.QMetaObject.connectSlotsByName(Dialog)
def retranslateUi(self, Dialog):
Dialog.setWindowTitle("Dialog")
self.title.setText("Plane-O-Matic")
self.label_width.setText("Width")
self.label_height.setText("Height")
self.create.setText("Create!")
print("tyty")
def createPlane(self):
try:
# first we check if valid numbers have been entered
w = float(self.width.text())
h = float(self.height.text())
except ValueError:
print("Error! Width and Height values must be valid numbers!")
else:
# create a face from 4 points
p1 = FreeCAD.Vector(0,0,0)
p2 = FreeCAD.Vector(w,0,0)
p3 = FreeCAD.Vector(w,h,0)
p4 = FreeCAD.Vector(0,h,0)
pointslist = [p1,p2,p3,p4,p1]
mywire = Part.makePolygon(pointslist)
myface = Part.Face(mywire)
Part.show(myface)
class plane():
def __init__(self):
self.d = QtGui.QWidget()
self.ui = Ui_Dialog()
self.ui.setupUi(self.d)
self.d.show()
Chris_G
Re: Wiki dialog example broken?
Post by Chris_G »
For code indentation, you can use the Code </> tag in your message.
The code you show defines 2 objects (Ui_Dialog and plane) but doesn't use it.
If you save your code into a file mywidget.py
Then you can use it with :
import mywidget
myDialog = mywidget.plane()
Or, directly at the end of your code, you can create a plane object instance with :
myDialog = plane()
onekk
Post by onekk »
Here your code modified according to the last proposal of Chris_G
fdialog.py
(2.37 KiB) Downloaded 21 times
It works at least on 0.20 weekly build tested with a Linux AppImage.
use the </> code tag
Regards
Carlo D.
- Various other stuffs.
jdm
Post by jdm »
That worked of course, merci bien, grazie.
To be honest I'm supposedly able to program but have been too lazy too think before asking :oops:
onekk
Post by onekk »
No problem, according you will learn how to post code properly :D.
Feel free to ask, the forum will help you, if you ask politely and you are willing to learn, better ask here than loose your time in watching youtube videos, some lines of code are more "concise" than an hour of video seeing the mouse pointer dance on the screen and trying to read the menu or to catch what is selected and what version of FreeCAD is used.
Regards
Carlo D.
