Looping through children of parent compound object
ChrisFC
Post by ChrisFC »
Hi all,
I have a series of parts, most of which are compound objects. I would like to loop through each of these parent objects, and for each parent, loop through each child part within the parent compound object, and extract the vertexes. The reason I want to do this is because I need to append a 'nan' to a list of the x,y,z coords of these points, between each child object. This is because if I do not do this, and go to plot the points, you would get lines joining up different children objects that aren't always spatially connected.
Here is my code so far:
sel = FreeCADGui.Selection.getSelection()
for o in sel:
  print('Checking o:')
  print(o)
  comp = o.Shape
  print(comp)
  print(comp.Vertexes)
  print(comp.Faces)
  print(comp.Solids)
Looping over the different parent objects is easy, and if for example I do o.Shape I get ALL of the vertexes of that entire compound object in a list. This isn't what I want; I need to loop over each child object within the compound to get their specific vertexes. comp.Solids and comp.Faces in the above code return empty lists for me :/ Any ideas?
Cheers,
Chris
onekk
Re: Looping through children of parent compound object
Post by onekk »
From the Python console introspection, explicited with the print statement.
maybe:
>>> print(Part.Compound.childShapes.__doc__)
Return a list of sub-shapes that are direct children of this shape.
childShapes([cumOri=True, cumLoc=True]) -> list
 * If cumOri is true, the function composes all
   sub-shapes with the orientation of this shape.
 * If cumLoc is true, the function multiplies all
   sub-shapes by the location of this shape, i.e. it applies to
   each sub-shape the transformation that is associated with this shape.
But the concept of subshapes and children may be not the required.
Hope it helps
Carlo D.
- Various other stuffs.
edwilliams16
Post by edwilliams16 »
If you have solids nested in compounds, how about
sel = Gui.Selection.getSelectionEx()[0]
vlist=[sol.Vertexes for sol in sel.Object.Shape.Solids]
giving a list of vertex lists for the contained solids.
