Creating an Image Plane in Python Script
phixxx5
Post by phixxx5 »
I'm new to FreeCAD and I'm working on a custom workbench. At the moment I am trying to create an Image Plane in my Python script similarly to the Image Plane I can create in the GUI in the Image workbench. I have tried the following:
import FreeCAD, FreeCADGui
import Image, ImageGui
import Part, PartGui
class PlaceImage:
    def Activated(self):
        """ This code gets executed when the corresponding button is pressed."""
        doc = FreeCAD.activeDocument()
        img_plane = doc.addObject("Image::ImagePlane', 'ImagePlane")
However I see the error:
No document object found of type 'Image::ImagePlane', 'ImagePlane'
What am I doing wrong? Do I have to implement my own ImagePlane Class in Python?
onekk
Re: Creating an Image Plane in Python Script
Post by onekk »
Something wrong you wrote:
instead of :
img_plane = doc.addObject("Image::ImagePlane", "ImagePlane")
or:
img_plane = doc.addObject('Image::ImagePlane', 'ImagePlane')
the error code:
is showing that FreeCAD is searching for the whole string shown that is obviously "strange", as there is the name of the object in it instead of:
'Image::ImagePlane'
That would be more correct for a "object type".
Hope it helps
Regards
Carlo D.
- Various other stuffs.
phixxx5
Post by phixxx5 »
Thank you! What a stupid mistake :oops:
onekk
Post by onekk »
It happens, more frequently than you could immagine.
Regards
Carlo D.
