Creating XPM icons for toolbar is no longer available?
Evgeniy
Post by Evgeniy »
I make example based on this wiki page https://wiki.freecadweb.org/Module_Creation
I tried to create an icon from XMP by different ways, but nothing works, but the workbench icon is displayed normally.
Log results when icon is loading to toolbar:
Cannot find icon:
/* XPM */
static const char * ViewProviderBox_xpm[] = {
"16 16 6 1",
Although wiki example tell's that is possible... May be something broken in the source code?
import FreeCAD, FreeCADGui
IconGlobal = """
      /* XPM */
      "16 16 6 1",
      "    c None",
      ".   c #141010",
      "+   c #615BD2",
      "@   c #C39D55",
      "#   c #000000",
      "$   c #57C355",
class MyTool:
	"""Explanation of the command."""
	def __init__(self):
		"""Initialize variables for the command that must exist at all times."""
		pass
	def GetResources(self):
		return {"MenuText": "My Command",
			"Accel": "Ctrl+M",
			"ToolTip": "ToolTip command",
			"Pixmap"  : IconGlobal}
	def Activated(self):
		# do something here...
		print("Activated")
	def IsActive(self):
		if FreeCAD.ActiveDocument == None:
			return False
		else:
			return True
# The commands must be "registered" with a unique name by calling its class.
FreeCADGui.addCommand('My_Command1', MyTool())
FreeCADGui.addCommand('My_Command2', MyTool())
FreeCADGui.addCommand('My_Command3', MyTool())
class MyWorkbench ( Workbench ):
	"My workbench object"
	Icon = IconGlobal
	MenuText = "My Workbench"
	ToolTip = "This is workbench"
	def GetClassName(self):
		return "Gui::PythonWorkbench"
	def Initialize(self):
		self.appendToolbar("My Tools", ["My_Command1","My_Command2","My_Command3"])
		self.appendMenu("My Tools", ["My_Command1","My_Command2","My_Command3"])
		Log ("Loading MyModule... done\n")
		# do something here if needed...
		Msg ("MyWorkbench.Activated()\n")
	def Deactivated(self):
		Msg ("MyWorkbench.Deactivated()\n")
FreeCADGui.addWorkbench(MyWorkbench)
mario52
Re: Creating XPM icons for toolbar is no longer available?
Post by mario52 »
Hi
here other example Custom_icon_in_tree_view but the icon is not permanent after Save/Open the file
mario
Evgeniy
Post by Evgeniy »
mario52 wrote: Sat Jul 31, 2021 10:28 am here other example Custom_icon_in_tree_view but the icon is not permanent after Save/Open the file
Hi
Thanks for link. But it tells about how to add XPM icon to ViewProvider but i tell about how add XPM icon to ToolBar via Command.
In ViewProvider all works fine... but not in toolbar.
I'm look the forum, and find very old post (2014 year) from jmwright Trouble With XPM and SVG Icons With a Command. He was talking about the same problem as me. But yorik says:
yorik wrote: Fri Nov 14, 2014 12:28 pm We don't use that mechanism anymore, and I wonder if it was not disabled at some point.
This is very strange. Apparently, one of the developers accidentally or for some purpose broke this mechanism. But at the same time, this mechanism works successfully in the ViewProvider and as a Workbench icon. Perhaps it has something to do with the scaling of toolbar icons...
But the wiki page https://wiki.freecadweb.org/Module_Creation continues to show disinformation for users since 2014...
mario52
Post by mario52 »
hi
sorry maybe see one little workBench addon for study
similar problem Work Feature workbench with parametric objects
(i make this little ToolBar (not workBench) with icon in macro, maybe ... )
mario
Evgeniy
Post by Evgeniy »
Intresting example. I look code it real use load XPM from string...
I try launch it in FreeCAD 0.20 under Linux. Only the color of the toolbar changes, but not the icons.
In the subject of the example, users write that in one version of FreeCAD the icons are visible and in the other version they are no longer there.
This means that this method is not reliable for use yet...
I don't understand how it works yet, maybe it's pure Qt.
Is possible to use this mechanism to load SVG from python code?
openBrain
Post by openBrain »
Evgeniy wrote: Sat Jul 31, 2021 11:44 am But the wiki page https://wiki.freecadweb.org/Module_Creation continues to show disinformation for users since 2014...
Yep, probably everybody did same as you since there : comment rather than changing the content...
onekk
Post by onekk »
At the top of the page:
There is a "deprecation warning" that says that this page has to be deleted after the relevant (and I suppose working) informations are moved to:
https://wiki.freecadweb.org/Workbench_creation
I doubt that is since 2014 that the information are outdated, maybe after the passage to PySide2 something is chanced or maybe you have to install some libraries to read some image formats (maybe this is something OS related).
As this page:
https://doc.qt.io/qt-5/qpixmap.html
XPM format is supported by QT5, that is used by PySide2.
Hope it helps.
Regards
Carlo D.
- Various other stuffs.
mario52
Post by mario52 »
Evgeniy wrote: Sat Jul 31, 2021 1:08 pm Only the color of the toolbar changes, but not the icons.
the macro work fine just see
Tools > Edit parameter > User parameter:BaseApp/Preferences/Macros/FCMmacros/ToolViewReverse_ToolBar
for change parameters : color or not, loco or conventional view ...
Evgeniy wrote: Sat Jul 31, 2021 1:08 pm Is possible to use this mechanism to load SVG from python code?
normally yes
mario
Evgeniy
Post by Evgeniy »
openBrain wrote: Sat Jul 31, 2021 2:00 pm Yep, probably everybody did same as you since there : comment rather than changing the content...
You don't have to be particularly smart to judge someone.
The administration has not yet granted me the rights for confirm edits of source wiki pages.
Therefore, I have no special motivation to fix something, because my corrections may be lost or ignored.
Wiki have too many errors to create a topics for discussion every time.
Page fixed.
onekk wrote: Sat Jul 31, 2021 2:36 pm There is a "deprecation warning" that says that this page has to be deleted after the relevant (and I suppose working) informations are moved to:
For some reason I did not notice it.
"The information on this page that is still valid". Maybe valid.
I was found this incongruity about XPM by accident.
In fact, I am more interested in loading SVG format from string.
mario52 wrote: Sat Jul 31, 2021 4:33 pm Tools > Edit parameter > User parameter:BaseApp/Preferences/Macros/FCMmacros/ToolViewReverse_ToolBar
Confirm. It works.
Regards for comments to all.
