FCCircularText not working
56jimalexander
Post by 56jimalexander »
I haven't included a file because I believe what I'm trying to do doesn't require any existing geometry.
I want to create a flat circular text which I will extrude and project onto a surface.
Having trouble adding FCCircularText with the Addon manager, I did a manual download.
1. download code from the internet. See FCCircularText.text
2. In Freecad menu: Macro/create
3. copy and paste code into editor. Name it FCCircularText
4. macro menu: Macros (see attachment "Addon"
5. select FCCircularText.FCMacro
5. select execute
Nothing happens.
Let me know what additional info I should provide.
Thank you,
Jim
OS: Windows 10 Version 2009
Version: 0.19.24275 (Git)
Branch: releases/FreeCAD-0-19
Hash: f4574cf02d08fedd0a416d798b7dfef0ca2b5579
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
FCCircularText.txt
(84.98 KiB) Downloaded 17 times
TheMarkster
Re: FCCircularText not working
Post by TheMarkster »
Works for me using your described method.
Snip macro screenshot-32bbbc.png (162.26 KiB) Viewed 833 times
Version: 0.20.25306 (Git)
Hash: 5f5b3d9b67136edda1f6738f1a83154990f7839d
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
mario52
Post by mario52 »
hi
for use "Execute" the macro with AddonManager you must unselect and reselected the macro and after click "Execute" the macro is executed and edited in the FreeCAD macro editor (for experimented user)
but if the macro is installed, use Image select the macro and "Execute"
here for create one button Customize_Toolbars
@TheMarkster actual version,
__Version__  = "0.20"
__Date__     = "2021/04/05" #YYYY/MMM/DD
mario
56jimalexander
Thanks for the suggestions.
I installed the latest version and all is good. Addon Mgr works and offered this macro. I added it and it opens.
However, I can't use the context button ("What's This"). When I click it and then select an item the arrow disappears and nothing happens.
Any suggestions. Or should I open a new post?
Thanks
